Results 1 to 13 of 13
    Veteran Member Three Rings rage385's Avatar
    Sep 06 2012
    2001.5 Audi S4, 2009 Daytona 675
    United States
    Stoptech st-40 or st60
    All,
    I am looking to upgrade to a BBK, and I like the idea of going with Stoptech (unless you guys can suggest any other company around the same price).
    My car is a stage II (with plans to go with the RS6r stage III). Its a daily S4 with occasional track days planned in the future.
    Question is, do you think the st-40 is sufficient or should I spring for the st-60?
    Thanks for the input.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If you are the diy type, look into the 17z or 18z setups.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Mar 22 2013
    AK
    Stoptechs are a Brembo/Porsche copy of their old two piece calipers on the 928GTS/993tt.
    IMO better pad selection with the Stoptech vs 17/18Z.
    Braking is tires-cooling-pads-fluid-calipers.
    If you run some generic all season tires then it does not make a difference if you run Stoptechs or stock.
    I had my ST40's for almost 15 years, no complains but Brembos are definitely better quality. Stoptech bleeder screws are junk.
    May 22 2014
    2004 S4 Avant
    St40 would be sufficient if you went the stop tech route. Be sure to check out the figment guide for your wheels.
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    I will caution you that stoptech brackets are junk. I'm in the middle of replacing mine as one was cracked and the other was falling apart. Had the bracket completely broken who knows what could have happened while driving. Don't have the down time to get custom ones made so I had to opt for the stoptech brackets again, but I do not trust them at all. I will have a machine shop make some for me in the near future though.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    Quote Originally Posted by rage385 View Post
    All,
    I have the st40s on my car, 18' wheels with no spacers, they fit better than the stock GIANT calipers. no complaints. have the aero rotors too with street compound pads
    2008 Ibis RS4....GETing tuned
    Sep 06 2012
    United States
    Quote Originally Posted by Eurotuned_A4 View Post
    I had heard about this issue, but was not sure how few and far between it was. Ya, broken caliper brackets suck, and not having that piece of mind would suck.
    Sep 06 2012
    United States
    Quote Originally Posted by axnjaksn View Post
    Thank you. I am running 18x8.5 ET35, so I wonder if the ST-60 would even fit. Time to download the template I guess.
    Registered User Three Rings AutoTalent's Avatar
    Apr 24 2015
    Many of our customers run the ST40 and ST60 with no complaints at all.
    Veteran Member Three Rings 2000s4_m's Avatar
    Sep 05 2012
    2005 vw touareg 4.2 V8
    Mcallen, tx
    That was because the old brackets did not had a way to secure the studs that hold the caliper, those were just screwed down, they would get loose and break something in the process, new brackets have different design, have a security allen bolt on the side of the bracket that holds down the main stud, bleeders need to be replaced over time but other than that they are a great break upgrade, i have st-40 with 332's and absolutely love them, highly recommended
    Jul 07 2009
    Alberta, Canada
    I have ST40.
    Just broke two of 4 bridge bolts taking them out.
    Not sure who torqued them to what before but I've heard it's a common problem. I'd go OEM Brembo personally.
    Stoptech quality hasn't blown me away.
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Quote Originally Posted by 2000s4_m View Post
    The brackets I replaced did have the allen. The brand new stoptech ones I have are the same, except for the bolt that connects to the caliper isn't as large. The other actual bracket itself was literally falling apart (the metal was layering apart). Ill need to take some pictures so people can see. People need to be aware and to closely inspect their brackets is all. I was going to get Apikol brackets, but they wont work with a larger 332 rotor. The st40 is compatible with their bracket from what I found, but I already had the large rotors that I didn't want to replace. I was pretty unimpressed with stoptech response to my issue though. All they said was to contact a dealer to get new brackets, no discount, no sorry, no explanation, no nothing. Besides this issue I have no other complaints (bleeder valves work perfectly for me btw), but its a pretty serious issue IMO. When I use the car every day to transport my kids it adds another perspective on not only mine, but their safety as well.
    Jul 07 2009
    Alberta, Canada
    Oh, I also forgot to mention the caliper brackets on mine turned to mush when I went to remove one of the caliper-knuckle bolts. Just had them all helicoiled though.
    I would have replaced the whole setup but I had just bought new pads and rotor rings.
