Results 1 to 11 of 11
    Jul 10 2013
    Philly
    Realign Active cruise for $750 after bumper removal?? WTF
    Hey there everyone,
    I had to post up and ask this question. After having my S6 wrapped which required the front bumper to be removed, I started getting alerts that my Active cruise and my breaking guard was disabled. No big deal, right? Drop it at the dealer and tell them that we removed the bumper for the new vinyl wrap, and since then, it started with these codes.
    They then informed me that any time the front bumper is removed, the lasers have to be realigned and it will cost $750 to do this! Seriously? Sounds like the biggest waste of money there is.
    Anyone experience this, or have any idea of a work around, or another option???
    Thanks,
    Kevin
    2014 RS7 - Nardo over black - APR Stage 2 / Custom Intake
    2013 Ford F150 Limited
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    I have not experienced this myself, but yes if you remove the bumper, the radar sensors will need to be recalibrated as they'll no longer be aligned properly. The process to calibrated them is very time consuming.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    I did not need this done and everything is working fine after having the bumper off. AFAIK Audi ACC doesn't use lasers. Also FWIW if the front parking sensor or cables are loose it will disable ACC and Brakeguard.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings CreoSTi's Avatar
    Feb 22 2004
    West L.A.
    Quote Originally Posted by gk1 View Post
    +1.
    You might want to double-check all of the connections.
    -Mike-
    2022 Tesla Model 3 Performance & 2023 SQ5
    Past: 2001 S4, 2011 S4, 2014 S6, 2018 S4, & 2021 TT
    CrossCountry Mortgage
    Instagram: creoucla
    Established Member Two Rings Screaming Eagle's Avatar
    Jan 27 2015
    Metro Orlando, Fl.
    Service manager told me that a all wheel alignment cost about $250.00 but if car has drivers assist, lasers and cameras have to be aligned cost about $1500.00
    2018 TTRS Glacier White, Tech Package, B&O, Black Optic, RS Design Interior, Red Brake Calipiers, Carbon Fiber Inlays, RS Sport Exhaust.
    2016 S7 Ibis White Traded
    Veteran Member Three Rings dennisg's Avatar
    May 11 2013
    United States
    I had my bumper off more than once. Car works perfectly fine without that alignment. Goes back on the same way it came off, any differences will be minimal. There are a number of plugs that have to be plugged in when putting it back on and it is a bit tricky. ACC is radar not laser.
    HRE ADDICT
    2013 S6 Phantom Black Pearl, self inflicted Black Optics, 20" HRE P101, brushed dark clear, CF Caps, Tikor lugs, H&R ETS, AWE Touring Exhaust... Eurocode sway bars. Disc Italia ceramic pads. Bel Stir Plus w/ radar mirror display, AL Priority quad "parking sensors" ;-). Hertz Mille speakers, 3 way front/2way rear, Audison Bit DMI, Audison Bit One, Audison Voce 5.1 amp, Audison Voce Quatto amp, Hertz ML2000 sub.
    Veteran Member Three Rings Silent Drone's Avatar
    Feb 15 2014
    Salt Lake City, UT
    Yep. It's true that this is something Audi recommends in this situation. Also recommended by Audi when the rear wheels are realigned. My dealer quoted me over a grand for it when I realigned my rear passenger wheel. They say it's time consuming to do. There's a thread out there from about a month ago that discussed this in some depth.
    Sep 30 2013
    CA
    Quote Originally Posted by Silent Drone View Post
    This is the other thread:
    http://www.audizine.com/forum/showth...alignment-WTF-!!
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    It would bother the hell out of me that the dealer is referring to lasers for the ACC when in fact it uses millimeter wave radar units. Those units are not even touched if all they did was remove the front the bumper cover. Most likely, as other here have said, you properly have a connection problem. As far as having the ACC aligned, it is my understanding that if you have lowered the car or modified your alignment in other ways that the ACC would need realignment. Now I have lowered my car and modified the alignment and my ACC still functions just fine. It may not be preforming perfectly but I am not ready to pay $600 for the dealer to realign the ACC yet.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Senior Member Three Rings JoeCaMotto's Avatar
    May 06 2014
    Chitown
    It was dicussed in the other tread, to sounds like something for them to make money on. You go in and ask for wheel alignment and boom it's not $250 but anywhere from $1000 to $1500 extra. I have friends with MB's that have acc radar and did not have to have this service on wheel alignment. Just saying same goes with the bumper removal.
    14 White S7 Loaded
    14 HD white demin V-rod muscle
    10 White Ford Raptor 6.2 Loaded
    09 Red GT-R sold
    Veteran Member Three Rings Nabizzy's Avatar
    Mar 26 2014
    Toyota Tundra TRD Pro
    Houston, tx
    my dealer only charges 400 for this realign crap....so.....yall are all getting bent over.
    "It's a funny thing about life; if you refuse to accept anything but the best, you very often get it."
    - W. Somerset Maugham
