So the mechanic didn't do a compression test but scanned the car and saw it misfiring and looked at the rate it was misfiring and was quick to blame piston rings. I kept asking for a compression test but they never did one so i became a bit skeptical.
I bought a compression tester and tested the compression in each cylinder. Had the following results:
Cyl 1: 180
Cyl 2: 175
Cyl 3: 179
Cyl 4: 180
I don't think there is anything wrong internally. I think the connectors for the coil packs might be detective. I'm going to take my car to my fiancé's uncle's shop. I was avoiding it till now because it is over 100km away and i didn't want to drive it that far while it is misfiring. I just got CAA so I'm going to get it towed there.
Just an FYI for anyone who deals with something like this in the future...even if your CEL isn't flashing or solid at high RPMS or high speed and even if your car feels smooth at high RPM or high speed, chances are you're still misfiring even though the CEL is only flashing at low RPM or idle. I was able to see this first hand while I was data logging while driving. It wasn't misfiring as often as when i was idling but it still was misfiring a fair amount for me to be concerned. The fact that it wasn't misfiring as often at high RPM or high speed makes it smoother which is why we typically think it only misfires at idle.
Also, while data logging, cylinder 3 was constantly misfiring while cylinder 1 was misfiring every once in a while. Perhaps they're linked in some way? But, the car never picks it up or gives a CEL for cylinder 1.
Just to summarize so far what i have done (in this order):
- Spark Plugs
- Coil Packs
- Changed To Aftermarket Intercooler (didnt think it was linked...just a mod i always wanted to do and i swapped this after the issue started)
- Carbon Build Up Cleaning
- PCV Valve
- Injector for Cylinder 3
- Compression Test (180, 175, 179, 180)
