Results 1 to 38 of 38
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    top speed in your q5/sq5?
    Since a few of the other model-subforums have this thread going I figured I'd start one here lol
    Whats the fastest you've driven your Q5/SQ5? I've easily hit 140 while on an open country road in mexico...
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Quote Originally Posted by q5 dave View Post
    150. It was on an abandoned air strip...yeah, that's the ticket...an abandoned air strip.
    ...in Oklahoma, where the potholes are so big the radio station skips.
    Feb 19 2012
    Bay Area, California
    Not sure I would trust road quality in Mexico to go that fast. One pothole and thats all she wrote. Literally.
    Active Member Two Rings Banks's Avatar
    Apr 20 2015
    Chesapeake, VA
    99.
    2015 Q5 3.0T P+/Glacier White/Pistachio Beige/Tech/B&O/S-Line
    2010 A4 2.0T P+/Ibis White/Black/Tech/B&O (Sold)
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by kc1953 View Post
    The roads around here, I mean in uhm.. mexico.. are pretty good
    May 15 2014
    Oregon
    '16 Golf R
    '13 Land Cruiser
    '94 TT Supra Hardtop
    Jul 10 2014
    Quote Originally Posted by SQive View Post
    I was on that same airstrip and hit speed limiter just two nights ago... 155 and she was still pullin'... Oh and the car feels smooth as glass and wants to keep going... Frigginamazing for a CUV...
    May 14 2008
    2015 S8; 2020 Q3 Prestige; 2012 Golf R (w/ the six speed...)
    SF Bay Area CA
    Straight 130 (to the governor) on Autobahnen, but...
    And since it was legal, I got a bunch of opportunities to run it up near there and then one to peg it at the governed 130 MPH. Bottom line, it is really NOT a vehicle to be driven that fast, even where legal and with little to very light traffic and top roads. Up to about 110-115, yes, an we repeatedly had it to that for longer runs. At or above that the hood was shaking from the turbulence just for starters---somewhat comical actually. Much more vulnerable to wind by those speeds, no surprise with the slab sides. Then as you went in the 115-130 range it got somewhat white knuckle even on the broadest of sweepers. Keep in mind these are the Autobahnen engineered with the most modest of curves on unlimited sections compared to anything you will find in the U.S. Thus only in essentially straight line did it feel comfortable to run it up to 130; hard even in Germany to find these days. We had better luck in the East.
    Bottom line, this was fine for any possible speeds in North America, even highly extra legal. Autobahn uber cruiser, nope. I would use the A8 for that easily over the top heavy, very slabby Q5.
    Apr 26 2014
    DFW
    Oh...yeah...I wouldn't try that in a regular Q5.
    The SQ5 is limited to 155 MPH and can do every bit of it.
    Jul 12 2014
    _
    What makes the SQ5 handle better than the Q5 at high speeds?
    Doesn't the Q5 and SQ5 share the same chassis and suspension?
    The SQ5 has a higher top speed governor, and different drivetrain( Tiptronic in Europe, which is provided to Q5s and SQ5s in the U.S. ) but that is the only difference that I am aware of and a drivetrain will provide very minimal better handling at higher speeds.
    Apr 26 2014
    DFW
    Quote Originally Posted by QUBE5 View Post
    A stock Q5 is designed for comfort. That's why they are limited to a lower top speed.
    I'm just saying I don't think I'd want to be white-knuckling it at 155 MPH in a stock Q5.
    Now a Q5 with a modified suspension, maybe...just sayin'. Didn't mean to get your panties in a bunch.
    Jul 12 2014
    _
    Now a Q5 with a modified suspension...maybe...just sayin'.
    OK, but what makes the SQ5 with stock suspension provide better handling than a stock Q5, like you stated?
    A tune will remove a governor, so top speedss are irrelevant to me. I'm curious what makes the SQ5 handle better than a Q5 at those higher speeds if both are stock? I haven't found any difference between the Q5's and SQ5's chassis , have you?
    May 14 2008
    SF Bay Area CA
    Yes, but not a U.S. SQ5
    As you probably know, SQ5 is same basic ride height for U.S. market. I looked at the parts listings extensively for mods like sway bars and even cross platform for height type tweaks with OE parts, but on US side it netted to basically the same. Typically same tire widths and sizing if you get to better equipped ones, at least up to 20's. Not talking aftermarket, and doesn't matter if governor is 155 on stock set up (as are all S's typically) except for the straight line. It isn't dropped like they (or the Hybrids for that matter) are in Europe. I saw them there, including at Ingolstadt in Euro form with the pumped up TDI's.
    Net to me, boulevard very tall wagon cruiser that is fine for U.S. speed with some twists at same US speeds, but it isn't up with the super or even better sports sedans at higher speeds--from having done it extensively with only a few thousand miles on the clock. Pick your choice of motor for acceleration, mileage, etc, but not so much handling near the limit. Needs both stiffer bars (also the same on a stock SQ vs Q) and somewhat struts probably, as well as a couple of inches down. Being clear too, from having driven it, in my estimation and experience the tires were not the limiting factor; it was the height, side wind buffeting and body roll. Wind noise was also low below maybe 100 but pronounced by about 115; roof bars were inside vehicle that they give you at the factory, not mounted on the roof.
    Even w/ tweaks to suspension, pano. glass most of us with better equipped ones have and generally tall roof for all move COG up meaningfully--even if you get it down to typical Euro sport sedan height. I see yours is sans pano, but it still has the tall roof and one built more to car standards and strength (a good thing safety wise). Same basic analysis for most car based SUV's that are built to truck ride height standards to evade tighter EPA gas mileage standards on cars. The truly fast Autobahn burners we saw over extended distances in the unlimited zones were almost always sedans, hard tops/coupes or the occasional high end Porsche, R8, etc. We were typically the fastest SUV style vehicle we saw--maybe with one Q7 keeping up and one X6 styling disaster that went by at one point.
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Quote Originally Posted by MP4.2+6.0 View Post
    Net to me, boulevard very tall wagon cruiser that is fine for U.S. speed with some twists at same US speeds, but it isn't up with the super or even better sports sedans at higher speeds--from having done it extensively with only a few thousand miles on the clock. Pick your choice of motor for acceleration, mileage, etc, but not so much handling near the limit. Needs both stiffer bars (also the same on a stock SQ vs Q) and somewhat struts probably, as well as a couple of inches down. Being clear too, from having driven it, in my estimation and experience the tires were not the limiting factor; it was the height, side wind buffeting and body roll. Even w/ tweaks to suspension, pano. glass most of us with better equipped ones have and generally tall roof for all move COG up meaningfully--even if you get it down to typical Euro sport sedan height. I see yours is sans pano, but it still has the tall roof and one built more to car standards and strength (a good thing safety wise). Same basic analysis for most car based SUV's that are built to truck ride height standards to evade EPA gas mileage standards on cars. The truly fast Autobahn burners we saw over extended distances in the unlimited zones were almost always sedans, hard tops/coupes or the occasional high end Porsche, R8, etc.
    EU specifications:
    SQ5 3.0TDI Top speed 250 km / h
    Q5 2.0TFSI Top speed 222 km / h
    Q5 3.0TDI Top speed 230 km / h
    May 14 2008
    SF Bay Area CA
    Quote Originally Posted by spijun View Post
    EU specifications:
    Spijun, I understand the governed speed differences--except maybe the 2.OT that may not get to the typical lower bound 230kph/130mph speed? Another poster had a 3.0T BTW (also 230/130 at least for USA models), but he said his was chipped. But that is not the point here; the discussion is around practical handling, cornering and cross wind parameters and limits regardless of governed or maximum possible theoretical speeds.
    Jul 12 2014
    _
    Thanks for the detailed breakdown.
    As I thought, there is no difference between the stock U.S. Q5 and SQ5 chassis, except for the optional 21" wheels. So, a 3.0T Q5 has the same chassis as a SQ5 3.0T in the U.S. Market.
    I don't see why so many posters in the U.S. with SQ5s act like SQ5s have a completely different sport tuned chassis. It is amazing the amount of misinformation some people spew to act superior for choosing an S model.
    Grow up.
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    We all drive the same car(essentially), no need to argue!!
    Even with OEM crossbars installed my q5 drives great at proper autobahn speeds. And when completely stock it cruised just fine at 130
    Sent from idk using Tapatalk
    Established Member Two Rings Yoshimura's Avatar
    Nov 25 2012
    Montreal
    Not that this necessarily make a difference but the NA SQ5 has different springs and shocks than the Q5.
    2018 S5 Sportback Technik - Sport Differential / Adaptative Suspension
    Nov 25 2012
    Montreal
    I think the Q5 has a lower top speed governor simply because it is fitted with more confortable (or what other qualitatives) H speed rated tires. Regarding S line Q5, they didn't bother increasing the top speed.
    Jul 10 2014
    My SQ with the HR springs feels much more planted than my old A7 with sport pkg and 20's..
    Here's proof: I was driving home with my wife in the car on the highway, and my wife was talking to her mom... There was no traffic or cops and a nice clear straightaway, so I dropped it down to 6th and slowly (1/3 throttle) accelerated to 120mph... When she got off the phone I said look... 120mph and you don't even feel it! She said Holy shit SLOW DOWN lmao... She had no idea...
    The Q5 and Sq are both GREAT car... Can't wait to see what Audis cooking up for next generation!
    Apr 20 2015
    Chesapeake, VA
    Q5 3.0T plus an $1,150 Unitronic flash (http://www.unitronic-chipped.com/ecu...015-stage1plus) and your chopping SQ5s already.
    But that essss though
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by Banks View Post
    That's what I'm sayin' Did you tune yours yet?? My q with GIAC stage 1+ zooms! The tune really wakes up our 3.0. But SQ #becauseracecar
    and Highfives to everyone who utilizes the full performance in their q5/sq5, isn't it fun?
    Oct 10 2010
    Sarajevo, BiH
    Grow up.
    All models in the US and the rest of the world have the same chassis, difference between Q5 3.0 and SQ5 is springs, shocks and brakes ( same engine in SQ5 and Q5 3.0TFSI; http://www.audizine.com/forum/showth...=1#post8994800)
    Senior Member Two Rings chasiu's Avatar
    Jul 31 2014
    Toronto, Ontario, Canada
    Ive gone up to 242....km/hr on a highway here in Canada.
    Veteran Member Four Rings B_Boy's Avatar
    Nov 24 2008
    2024 VW Atlas SEL Premium R-Line, 2024 Ford F-150 RCSB
    q5>>120mph
    she wants it all the time.
    b_boy
    '23 SQ5 P+
    Sport S, B&O, Nav, Black Optics, Black Nappa, Black Sport Exhaust, Mythos Black, VAG-COM, LED Reverse Lights, IE ECU Tune, CETE
    Tint: 15% F/R, 50% Windshield
    Wheels: Rohana RFX11 Brushed Bronze - 22x10.5 ET32 // Pirelli Scorpion Zero A/S+ 265/35/22
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by B_Boy View Post
    q5>>120mph
    I know yours is still brand new, but get that bad boy tuned whenever you feel comfortable. 50% more power with just stage 1! Its unreal how much Audi detuned our car, now I giggle every time i hit the throttle.
    Jul 29 2014
    2016 Audi A3 2.0T
    Clearwater/Florida
    142 in my s-line Q5, and she was still pulling hard. Just ran out of room.
    Dec 14 2012
    '15 F350 platinum. Tuned for mileage. 575whp is just a bonus.
    Medicine Hat Alberta
    Did 255kph on my way to the big city last week.
    Current daily driver
    2015 f350 platinum.
    Days off ride
    2015 SQ5. Just a black one.
    Nov 24 2008
    I just checked out the specs on GIAC and APR. Damn yo... I added it to my list of mods. After my wheels and suspension...gonna get it!!
    b_boy
    '23 SQ5 P+
    Feb 24 2013
    Plainfield IL
    fastest for me down one of the main roads by my house going around 125 + mph with stage 2 revo, but as of today I'm in the process of getting a Unitronic K04 stage 2+ installed. Should be picking it up in a couple days. Can't wait to test her out.
    2012 Audi Q5 2.0T Unitronic K04 stage 2+ (as of 5/12/15) | Hoffman Estates Audi | Dynarev | A&L | Stasis | Caractere | Eurocode | Ace Alloy/Avant Garde wheels | Bilstein | H&R coilover
    Vagcom mods: LED DRL's on with turn signal, turn off amber side markers, front log lights stay on with High-beams, fog light turns on with turn signal, adjust LED brightness, operating windows and sunroof with remote, remove seatbelt chime, enabling gauge test/needle sweep
    Apr 20 2015
    Chesapeake, VA
    I haven't tuned yet because I don't want a warranty flag and I don't have the equipment/know-how to reset back to factory specs before taking it in for service.
    Jul 31 2014
    Quote Originally Posted by alias2002 View Post
    That's huge! Which car did you use?
    I was in my SQ5
    Veteran Member Three Rings K|G's Avatar
    Mar 22 2013
    SoCal, CA
    I hit 125.83 in a 1/2 Mile race at SHIFT S3CTOR Airstrip Attack event in CA last weekend. Really fun event and lots of crazy cars going 200+MPH. I got killed by this GT500 but I ain't mad.
    https://youtu.be/1r8YmcSitSw
    @socalmacan
    Jul 10 2014
    Quote Originally Posted by K|G View Post
    Uh yeah, that's a ford GT, not GT500... BIG difference man... About a $250k difference these days...
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Thats a GT, but wowsers that thing tookoff... Why'd you run against him?
    Quote Originally Posted by Silverarrow240 View Post
    Yep. Although I was driving behind a Shelby GT500 on a parkway a few weeks ago... switched lanes to get off on my exit (but was right beside him).. and he tookoff just about as fast as KG's video. lol
    But Audi's are still nicer
    Mar 22 2013
    SoCal, CA
    I ended up next to him in line.. I just wanted to see what the Q5 could do down the 1/2 mile.
    Agreed! I was disappointed in the showing of Audi's at this event. There was one RS7 that was blowing people away and a stock B5 or B6 RS6 also that was pretty quick and that was it. There were some R8's at the event but they weren't running them.
    @socalmacan
    Nov 24 2008
    GIAC offers a stock mode, wouldn't that work?
    b_boy
    '23 SQ5 P+
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Nope. The tuned maps are still loaded on the ECU. Must be flashed back at GIAC/APR dealer.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
