Have to maintain it to get to that mileage. Things that have been changed:
1) Alternator - got a used one at a junkyard at ~200k miles
2) Power steering - got a used one at a junkyard at ~180K miles and flushed with CHF11S fluid
3) Lifetime brake pad changes from Autozone since first change
4) Starter - got a new lifetime one on E-Bay at ~245K miles
5) Clutch changed at ~305K miles
6) Wheel bearings changed on all four corners twice
7) Front outer CV boot changed 3 times on both fronts
8) Front suspension control arms changed once(all 8) with some upper control arms changed twice
9) Outer tie rod ends changed twice (use Meyle brand, much larger and stiffer)
10) Transmission fluid (Redline MTL) and rear differential fluid(Mobil 1 75W90) changed twice
11) Spark plugs changed 3 times
12) Timing belt, water pump, idler, and tensioner and serpentine belt changed twice
13) Driver side rear caliper changed once
14) Passenger side rear control arm changed once
15) Driver side catalytic converter changed once
16) Exhaust flex pipe changed twice
17) Tires changed many times
18) Oil and filter changed every ~5K miles with dino oil not synthetic
19) AC compressor changed twice
I may have forgot some things :-)
