Results 1 to 12 of 12
    Senior Member Three Rings MattRS6's Avatar
    Oct 27 2014
    1974%20Porsche%20911%2C%20RAM%203500%2Cect
    Knoxville, TN
    Driver front wheel is pushed back about an inch!
    Ok. So i need a little help. I have a suspension damage on this A6, we replaced the spindle and all the control arms on the bottom and on top also. The wheel is still pushed back torwards the firewall about an inch. Any ideas what can cause this? We don't see nothing else bent on the car. Thanks the replies!
    Wwrrrmm wwrrmm...
    Established Member Two Rings B5BAR's Avatar
    Aug 21 2014
    Twin Cities MN
    You sure the sub frame bolts and mounts are square? With enough force, the entire sub frame can move. Also may look to see if the aluminum upright is bent itself.
    Oct 27 2014
    Knoxville, TN
    Quote Originally Posted by B5BAR View Post
    I havent looked underneath the car yet, i just let my mechanics work on it. I'll go down to the shop, bc nobody is there and i'll take a look at it myself. I had them replace the spindle, the 2 upper control arms, the 2 lower control arms. The only thing we haven't replace is the outter tie rod on the steering rack, but i doubt that would push it back. The passenger side wheels seems to be fine and it's sitting in the right place. I'll take some pictures today and post it. Thanks, for the tipps!
    Wwrrrmm wwrrmm...
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by MattRS6 View Post
    My moneys on the subframe shifted, I have a B6 that has this exact problem same side and all and I'm going to tackle it one day this weekend. I replaced the strut/strut top hat/spindle/all 4 control arms/steering rack and the drivers wheel is still about a half inch closer to the back of the fender than the passenger side.
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    Yeah i would also go with the sub frame. They're a pain in the ass to re-align!
    Oct 27 2014
    Knoxville, TN
    Quote Originally Posted by FormulaElement View Post
    Ok, i'm at the shop right now. When i jacked the car it seems like the subframe is pushed back 1/8 of an inch, but my wheel looks like 1,5 inch to the back... i'll upload the pics to the computer and post them in a minute
    Wwrrrmm wwrrmm...
    Oct 27 2014
    Knoxville, TN
    Quote Originally Posted by seanf86 View Post
    So here are the pics:
    as You can see the wheel is really pushed back! but the passenger side is just fine
    Wwrrrmm wwrrmm...
    Oct 27 2014
    Knoxville, TN
    So i measured everything on the subframe, and it seems to be fine and it should sit in its place. But when i measured front wheel center to rear wheel center my driver side number was 1,5" shorter than the passenger side. The only things we haven't replaced yet are, strut, axle and tie rod. Everything else is brand new. I haven't done the alignment yet, but i doubt the alignment will move the wheel 1,5" forward... i'm waiting for somebody smarter than i'm to tell me what to look at..
    Wwrrrmm wwrrmm...
    Jul 02 2013
    406, MT
    The car being in a accident makes this much more complicated. Im assuming thats what has happened because of the bumper?
    Oct 27 2014
    Knoxville, TN
    Yes it needed front bumper driver headlight drive fender and mirror and glass... And the suspension fix... Oh well i'll figure it out next week
    Wwrrrmm wwrrmm...
    Senior Member One Ring blks4turbo's Avatar
    Sep 27 2007
    01 s4,99 1.8t,95 jetta vr6,E30
    ma
    Did u figure out problem ?
    Oct 27 2014
    Knoxville, TN
    Quote Originally Posted by blks4turbo View Post
    Yes sir! One of the control arms i replaced, the replacement part was also bent!! Just a little bit but enough to cause trouble. If you need help let me know
