Hi, I'm thinking of replacing my clutch soon. The car is bone stock and while it's not my main daily driver I will be driving it quite often.
I'm looking for a clutch kit that is best suited for daily driving. There's a lot of stop and go traffic and lots of hills where I live so something that's smooth to engage and disengage and comfortable to drive.
I don't want anything stiffer than stock.
I was searching online and came across AMD clutch kit and they state:
Stage 1:
Organic clutch disc. Perfect for daily driving ability, it is specifically designed for extended wear and additional clamping force for with a very light pedal pressure for very a smooth engagement and disengagement. Torque limit is approximately 550lb/ft to the crank.
Stage 2:
Organic/Fibertough clutch disc. Perfect for daily driving ability, it is specifically designed for extended wear and additional clamping force with a very light pedal pressure for very a smooth engagement and disengagement. Torque limit is approximately 650lb/ft to the crank
I like the fact they have a light pedal feel and smooth dis/engagement which is what I'm looking for.
I don't planning on putting a charger on the car or heavily modifying it. The most I will do is probably an exhaust and maybe a tune.
Are any of you running an AMD clutch kit? I haven't found too much info or review on them.
If I were to go with AMD, which stage would you guy recommend? It seems like the only difference is the clutch disc meterial and torque load.
If not AMD, which kit would you guys recommend? I'm planning to replace all the parts including the PP and FW.
Or do you guys think going with an OEM kit is the best route for my needs?
Thanks in advance.
