Results 1 to 10 of 10
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Iridium vs. Platinum Spark Plugs, any preference?
    I've looked at NGK and Bosch Spark Plugs, can't decide on type, any suggestions?
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Senior Member Three Rings B6cool's Avatar
    Oct 23 2012
    tricycle
    Iridium gives little more performance but less life. Platinum are oem so more life and ok performance.
    19" BBS CK wheels, Bilstein PSS9 coilovers, 034motorsport front adj. control arms and rear swaybar, Vw Brembo 4-piston front brakes, b7 rear brakes, StopTech SS Brake Lines, Sprint Booster.
    Buy my parts PM me - for sale b6 s4 front brakes Tyrol sport stiffening kit, kW v1 coils. Usp front valance unpainted.
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks, who is the Original Equipment Supplier on the Spark Plugs, NGK or Bosch?
    Current:
    70,xxx Miles
    182,xxx Miles
    Established Member Two Rings spidy512's Avatar
    Jul 10 2011
    East Bay, Ca
    Bosch
    I replaced with Bosch Platinums. been fine so far...
    Dec 27 2014
    2013 Audi Q5 3.0T
    Upon checking, seems like Bosch Part No. 8101 Double Platinum is the OEM plug.
    Quote Originally Posted by spidy512 View Post
    Bosch
    Current:
    70,xxx Miles
    182,xxx Miles
    Apr 10 2015
    Morristown, NJ
    On my 1996 Audi A6, I went with the Bosch, and had two sets of ignition coils go as a result. The NGKs matched the OEM part numbers, and looked exactly the same as the OEMs minus the audi/vw branding. I've had absolutely no problems with those. But my engine was the older 12v 2.8 V6 so this probably wouldn't apply to your car I think.
    Dec 27 2014
    2013 Audi Q5 3.0T
    I'll be going with the NGK, since the gap is appropriately preset for my make and model.
    Quote Originally Posted by acamposac1 View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    NGK oem copper plugs are the way to go with a turbo car... The coil packs are known weak points and the turbos have the propensity to "blow out the flame" causing missing ect. The copper plugs don't last long but they are right while they are there and damn $10 per plug or whatever... $2.00 each change mine every two oil changes.
    ADVISORY!!!! Always check the gap on plugs before using them!
    Dec 27 2014
    2013 Audi Q5 3.0T
    Thanks for the advice, definitely should check the gap on the plugs before using them, in spite of the manufacturer presetting them.
    Quote Originally Posted by Robsa6 View Post
    Current:
    70,xxx Miles
    182,xxx Miles
    Aug 16 2013
    SC
    NGK coppers here too. Gotta change them more often but that's not hard on our cars and coppers produce a better spark.
    2005 Allroad 6MT. STUKLR custom 93. F21's. WDR bipipe. 3" DP's into 2.5" custom mandrel exhaust
