Originally Posted by
arjun90
Thanks, I'll be able to perform O2 Sensor tests and a Throttle Position Sensor (TPS) Test via the VAG401, right?
I need to make sure each O2 sensor is working. Also, some generic scanners have the TPS test function, I'm sure this function is available in the VAG401 too, right?
Thanks again.
I don't know how to explain this to you... Let's try. While generic obd 2 scanners only access obd2 exposed interfaces (up to manufacturers how elaborate they can get) delaer tool, VCDS and VAG401 utilize VAG (VW and Audi) specific interface which allow these tools to access anything you can possibly imagine in each controller. You can access the ECU and change presets, access any of 100+ measuring blocks (each exposes up to 4 distinct metrics), tell controller to run output tests (in case of ECU it will run throttle plate test, N75, N80, N249, etc, etc, whatever the ECU has), you can do basic settings, coding (say you want to change how alarm system unlocks door, one click on remote to open all, or first driver door and second all). This is all accessed using generic VAG interface which makes it compatible with any VAg controller in the car.
The catch is that most of stuff won't be labeled, just like dealer tool, you'd need shop manual to tell you what to do and what values mean (that's available
)...or simply access Ross-tech.com (VCDS) website, it is a trove of information since they have easy to follow documentation that covers majority of common items.
Yes, of course you will be able to access and view O2 sensor activity and TPS, that's one of the measuring blocks in ECU.
