Results 1 to 30 of 30
    Established Member Two Rings kirkendall's Avatar
    Jan 20 2015
    06 zx6r , 2008 a4 B7
    Lehighton, PA
    Spark plugs for tuned cars
    I've been reading a lot about differnrt spark plugs but they are all way old (2010) I have a 2008 2.0t with jhm tune and a test pipe. Does anyone have any suggestions any good spark plugs? I've read something about going 1 step colder but I'm looking for a link to order.
    2008 A4 6 speed mt.
    JHM STAGE 1 - 93 oct.
    Test pipe
    rs6 grille mod
    Feb 16 2015
    I just installed the JHM stage 1 last weekend and was having a ping CEL (Knock sensors), ended up installing Bosch FR5DTC on Jake's recommendation (no CEL since). Here is a good page on spark plug diagnosis and recommendations
    http://www.audizine.com/forum/showth...ent-Guide-v2-0
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Quote Originally Posted by kirkendall View Post
    I've been reading a lot about differnrt spark plugs but they are all way old (2010) ... I've read something about going 1 step colder but I'm looking for a link to order.
    Not much has changed in the plug department, if you want to go one step colder look at the number in the code (if you didn't know), above poster is recommending "5" with the same tune, down colder, up hotter. Read what people are recommending for gapping as well.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    I have a nice write up on spark plugs:
    Quote Originally Posted by Jake@JHM View Post
    UPDATE:
    We noticed right away when we started the development on our JHM 2.0T Tuning some months back that my A4 was being a bit hesitant and misfiring as soon as the car would start boosting above 10psi. Our first instinct was that there was an issue with my spark plugs based on our years of firsthand experience with turbo Audis in our shop. After removing my spark plugs, we checked the gap and they were all at .045 which is why I was getting the misfire. The plugs that came out of my car were Denso PK20PR11 plugs, and looking at their website it shows that those are the plugs that Denso recommends for the B7 A4 2.0T, yet they come at their recommended gapped of .044. However, Audi recommends that the plugs be gapped at .028 which is quite different than a .044 gap, so always make sure your plugs are at the right gap before you install them as whoever installed these plugs in the car before I purchased it, did not. The increased gap over stock (recommended is .028 by Audi) adds more resistance for the coil to fire across the gap. This is okay sometimes when boost levels are stock since the engineers have to factor in spark plug wear. However when you add boost it increases the resistance to jump the gap and it is just like increasing your gap even more, hence the misfires. My car most likely would have been okay if the installer of the Denso plugs would have regapped them to spec. However we do not believe in using plugs that aren’t a close to stock gap since they were most likely engineered for a non-boosted application.
    Denso Plug:
    I replaced my Denso Spark Plugs with the OEM Bosch Spark Plugs we have on our website HERE! I made sure they were gapped at .028 prior to install for our tuning development purposes. This was because we have to make sure that everything is functioning 100% perfect at the stock plug gap for those people who would be purchasing the tune and still on their original plugs (I know the gap size will increase over time as they get used, however we have seen quite a few very low mileage 2.0Ts). Needless to say we would have been okay with the off the shelf gap of .032, but they would have .004 gap less to work with as they wore down with mileage.
    Spark plugs are essentially the center of your car’s ability to run and make power. When you increase your boost, you are increasing your cylinder pressure which makes your coil packs have to work harder to jump the given gap. The shorter gap will also help insure a better fire with more consistency. Considering that your plugs can fire over 100 times a second, making sure that you keep the best gap for your application is a must. That way you will always have a proper burn and not have a spark plug caused misfire. That being said, a .028 (Factory spec) gap is going to be much less strain on the coil packs/motor than .044, hence why I was misfiring when my cylinder pressure increased.
    In addition, the spark plug works as a heat exchanger by pulling the unwanted thermal energy from the combustion chamber. The heat range given to a spark plug defines the spark plugs ability to dissipate the heat. Both Bosch and NGK are popular spark plug manufacturers and their heat range designations both utilize a number between 1 and 10 and are often times confused with each other. NGK goes down a number every time the heat range gets HOTTER and Bosch goes down a number every time the heat range gets COLDER. For the 2.0T the OEM Heat Range for NGK is “7” and the lower the number for NGK, the hotter the heat range is (like stated previously). For example, the BKR6E is going to be hotter than the BKR7E. The OEM Heat Range for Bosch is “6” and the lower the number, the colder it is (like stated previously). For example, the F5DPOR is going to be a colder plug than the F6DTC. The rate of heat transfer for the spark plug is determined by a few things; the length of the insulator nose, gas volume around the insulator nose, the material of the center electrode, and the construction of the porcelain insulator. Keep in mind, the spark plugs heat range has no relationship to the actual voltage that is being transferred through the spark plug!
    There is a lot of information to take in to understand sparkplugs, and at time can be quite confusing. That is why we have done the research for you and are here to supply you with the correct sparkplugs for your application.
    OEM Replacement Spark Plugs:
    There are two different spark plugs that came in the B7 A4 2.0T. Therefor both choices will be a direct replacement for your vehicle. We have had great experiences with both of these manufactures and choice will ultimately come down to preference.
    Bosch - FR6KPP332S Long Life Platinum (Heat range 6)
    Click HERE for more information!
    NGK - PFR7S8EG Laser Platinum (Heat range 7)
    Higher Boost Applications:
    The following plugs are pre gapped at a perfect width to keep misfires away on high boost applications. We use these plugs in our race cars and customer’s cars with great success.
    Bosch - F5DPOR Platinum Sidefire (Heat range 5, one heat range colder than stock)
    Bosch - FR5DTC Tri-Electrode (Heat range 5, one heat range colder than stock)
    Bosch - F6DTC Tri-Electrode (Heat range 6, same heat range as stock) Note: This is a good lower cost replacement for stock cars or cars mostly stock with just a tune.
    NOTE: The spark plug torque spec is 30nm or 22 Ft-lbs. Remember to use Anti-Seize on the threads for easy removal and corrosion protection.
    If you have any questions please feel free to ask. I am here to help!
    Jake
    Let me know if you have any questions!
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    In addition to Jake@JHM's post above, here is another good post I have bookmarked:
    I 'm running Revo Stg II+ and I went with NGK BKR7E (Copper).
    2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
    Aug 31 2011
    Lathrop
    Quote Originally Posted by vwnobby View Post
    I 'm running Revo Stg II+ and I went with NGK BKR8E (Copper).
    It was my input that got that page edited The heat ranges used to be wrong.
    Jan 20 2015
    Lehighton, PA
    I was thinking of getting the Bosch - F5DPOR Platinum Sidefire (Heat range 5, one heat range colder than stock)
    Do you know what the gap size this is? Must I gap it to something different for my car?
    2008 A4 6 speed mt.
    Test pipe
    rs6 grille mod
    Aug 31 2011
    Lathrop
    Should come pre gapped, but make it .028 like in my post
    Mar 30 2009
    Great information to have on hand. It's those types of posts I always look forward to finding and make sure I bookmark for the future!
    Aug 31 2011
    Lathrop
    If you ever have any questions in general, please don't hesitate to ask me. I will get you the info you need!
    Mar 30 2009
    So Jake, I just realized that I am running NGK BKR7E (Copper), which I thought was one step colder than stock for NGK, am I wrong?. Based on the info from the page I posted, I should probably be running the NGK BKR8E (Copper) - you can see my upgrades in my sig.
    What are your thoughts?
    Aug 31 2011
    Lathrop
    Stock Heat Ranges: NGK7 Bosch6
    1 Step Colder: NGK8 Bosch5
    Mar 30 2009
    Thanks Jake. I just realized I used that guide when I went to the BKR7E (back in 2012) because it stated that it was a step colder at the time. Now it makes sense that it was updated because it stated the wrong heat ranges. I thought I was going crazy.
    Aug 31 2011
    Lathrop
    Haha glad I could help
    Senior Member Two Rings esm's Avatar
    Jan 14 2010
    Chicago, IL
    I made the same mistake, Jake set me right.
    2017 Audi Q7 3.0T Premium Plus: Vision / Cold Weather / OEM 20" 10-Spoke Wheels / Goodyear Eagle Sport All-Season Run Flats 285x45x20 / Weathertech Mats
    FORMER: 2005.5 A4 Quattro Tip / JHM Stage 2 93oct / JHM HPFP / AWE FMIC / JHM 3" Downpipe-Y adapter / JHM-Fast Intentions S4 Exhaust / RS4 RSB / Bilstein PSS9 Coils / VMR 810 19x8.5 on 245x35x19 Michelin Pilot Super Sports / Adam's AR II Slotted Rotors / Bosch Platinum Sidefire Plugs (Bosch Heat Range 5)
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    You cant gap the Bosch sidefiring plugs.
    Ive been running them for the past 3 years and swear by them. I wont run another plug, these have been tremendous
    2008 A4 S-line 2.0T
    JHM Stage 2
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Schweini View Post
    Oh you can lol
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Well there's no need to ;)
    2008 A4 S-line 2.0T
    JHM Stage 2
    Jun 27 2011
    Uhh. I like totally posted about the heat ranges before you did!
    maybe...?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 31 2011
    Lathrop
    maybe...?
    que? lol I went back and forth with stokes about it.
    edit - that thread was cleaned up anyways so who knows.
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Wheres a goo place to get NGK BKR8E?
    best i found so far
    http://www.driftmotion.com/ProductDe...M3070&CartID=1
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Aug 31 2011
    Lathrop
    Quote Originally Posted by vvenom800tt View Post
    best i found so far
    I would recommend these over the BKR8E
    https://jhmotorsports.com/shop/catal...27t-p-367.html
    https://jhmotorsports.com/shop/catal...27t-p-686.html
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    I added Jake's informative post into the original post of the 'Spark Plugs Replacement Guide.'
    B8.5 Audi SQ5 | APR Stage 1
    Aug 31 2011
    Lathrop
    Quote Originally Posted by kristokes View Post
    Right on
    Account Terminated Four Rings
    Oct 15 2013
    i like the stock heat range bosch copper tri electrodes for my APR stage 2+.
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by esandes View Post
    have you tried a colder plug? Ive been running BKR7E but thinking of switching to a colder range. Im APR stage 2
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    I'm apr 2+ and my car likes the Bosch tri electrode fr5dtc that are 1 range colder than stock. Can't say my car didn't like stock or ngk's either though.
    Sep 30 2009
    08 A4 2L MT, 87 Jag XJ6, Lex RX350, ~30 Road Bikes, Piper Aztec, Grumman AA1, Zlin242L
    Indiana
    Never was able to tell much difference in plug brands or plug electrode type. Back in my racing days (normally aspirated engines with two valves per cylinder) besides the proper gap the only thing we did notice is that rotational indexing seemed to make a difference (albeit small), ground electrode facing away from the intake valve. There is good theory and scientific evidence for this.
    I've only ever used the iridiums in the A4 (stock), and they seem to perform just fine. I ran a set of iridiums for 90K miles in my wife's Lexus RX300 and only changed them cos they were old. Interestingly, the piston powered planes I fly all have two plugs per cylinder which can be manually switched between plug sets each with a separate magneto, or run on both. The difference in power (engine RPM) between each set of plugs or running both (normal setting) is very evident.
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by onedumslack View Post
    Ok, thanks for the input
    Oct 15 2013
    Yes I did. My engine always runs cold unless it's very hot and I'm stuck in traffic. So I saw no reason to run a cooler plug.
    It still runs cool with the stock heat range plug but the engine is actually quieter with the stock heat range plug.
