Results 1 to 23 of 23
    Apr 08 2015
    Eugene, Oregon
    Water softener for cleaning your car?
    So now that I have the Ceramic Pro on my car rain water and non-hard water just beads off of it.
    My only issues ever with water spots are when washing with my hose at home, which is city water, and loaded with TDS (total dissolved solids), aka, its VERY hard water.
    Does anyone know of a water softener system that can be used inline with a water hose? Or even of a simple water softening (without any other solvents, soaps, or additives) liquid that can be used with a sprayer for when I do the final rinse on my car?
    I know the water softeners will need the activated carbon changed regularly, to help with this I can simply wash my car with the hard water but do the final rinse with the softened water.
    Any and all info is much appreciated!
    Feb 23 2015
    United States
    Quote Originally Posted by speed_racer View Post
    VERY interested in this info as well. Did a quick search a while ago but only found unpromising products.
    I hate drying my car and for that reason, haven't done a wash at home for years.
    If I can get something to attach to my house that will make my rinse water not leave spots, I can just scrub the car clean quickly and rinse without drying (I hope?).
    I also have trouble with the parking lot at my office. The trees rain a fine pollen dust all over the vehicle and make any wash short-lived.
    I wonder if I just take the hose to it with a softener, if the car will clean up well between washes.
    Apr 01 2011
    B5 on jack stands
    charlotte
    there are different methods for drying a vehicle.
    Veteran Member Four Rings RickFLS4's Avatar
    Sep 21 2012
    2012 Audi Q5
    Palm Beach County, FL
    I have a whole-house water filtration system and whole-house water softener. The water filter uses carbon and needs to be re-bed every 2 years or so, while the softener uses salt. They are in my garage and I am able to hook a hose up to get filtered and softened water for washing. I dry my car when I wash it but honestly am not so sure this water would be a guarantee of no spots if I didn't dry.
    If you do go with a whole-house system, I'd recommend staying away from Culligan, who uses proprietary parts and charges for service calls to diagnose problems, even if the problem is covered by a warranty. The softener has been fine but I replaced their filter with a GE product as the Culligan filter had many problems and cost less to replace than continue to pay for service calls.
    2015 BMW M4
    Past: 2013 S4, 2011 A6 3.0T (accident victim), 2008 Lexus LS-460, 1998 Lexus GS-300, 1994 Lexus ES-300, various GM/Ford/Chrysler cars prior to 1994
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    After using the "spot-free" rinse options in the local DIY car washes over the winter, I'm very tempted to get one of the wall-mounted deionizers from this place: http://www.crspotless.com/de-ionizin...ed-system.html
    It'd be easy to hook up to it with some quick connect hose couplers and would really help prevent water spots that are a PITA on hot summer days (or anytime). Anybody got one of these?
    They also have a "mobile" option that might be worth considering ...
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Apr 08 2015
    Eugene, Oregon
    That kit looks interesting!!
    To the above poster about different ways of drying, I paid good money to get the Ceramic Pro, which with soft water I am able to dry my car with a leaf blower better than any amount of towels could ever do.
    Hard water just doesn't react the same...
    Apr 08 2015
    Eugene, Oregon
    Quote Originally Posted by RickFLS4 View Post
    Actually, the salt is there to rinse the activated carbon so it can continue to pull out the solids. If the salt were used to actually treat your water than you'd have extremely high salt content in your tap water, which would cause corrosion, etc.
    Jul 18 2010
    NE Ohio
    I used to use my Toro leaf blower to dry the car, but after a few close calls (getting tangled in the extension cord or nearly hitting the car's paint while juggling the blower), I stepped up to an Air Force Master Blaster. The warm and filtered air and ability to maneuver the nozzle are a big improvement over the leaf blower. It's also relatively quiet. If it's good enough for Wayne Carini, it's good enough for me LOL!
    Oh yeah, and the Junkman thinks if you can afford it, the Master Blaster is better than a leaf blower, but it's 10 times the price!
    Sep 21 2012
    2012 Audi Q5
    Agreed on salt being used to rinse during regeneration cycle but the system I have uses resin beads to remove particles. I am not aware of any carbon being used by the softener, only the filter. The salt is the only consumable that needs to be replenished on a regular basis. The beads last 7-10 years.
    2015 BMW M4
    Junior Member Two Rings windowguy's Avatar
    Jan 08 2015
    I have been using this for years and can say this is amazing. You will need to replace the DI resin inside the blue tanks occasionally but that is not expensive or hard to do.
    Rob.
    Quote Originally Posted by LYKUNO View Post
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    Actually the salt is used to create the brine solution and in turn regenerate the resin (beads) in the softener. And yes it has nothing to do with carbon filtration.
    Nov 29 2013
    Silver Spring, MD
    How do you like the Ceramic Pro so far?
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Senior Member Three Rings draekin13's Avatar
    Jul 14 2014
    08 GTI, 11 F-350 King Ranch
    Kennewick, Wa
    I had one of the Mr Clean car wash systems and I loved it. Sadly it was discontinued.
    2011 R8 v8 Manual Ice Silver
    2019 S4 Prestige Glacier White, Black Optics, S Sport
    Active Member Two Rings cookinsolo's Avatar
    Jun 25 2013
    2014 audi R8 v10, 2015 audi TTRS
    san antonio
    Quote Originally Posted by draekin13 View Post
    plus uno
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    Quote Originally Posted by windowguy View Post
    Rob.
    i think I may get one as well.
    http://www.amazon.com/DI-120-Cr-Spot...ct_top?ie=UTF8
    “Wanting to be someone else is a waste of who you are.” - Kurt Cobain
    Apr 08 2015
    Eugene, Oregon
    Quote Originally Posted by ptper View Post
    Absolutely couldn't be happier.
    My matte wrapped areas loved to show water spots BAD!! Now the water beads off the car so quickly its hard to wash without a foamer!
    Nov 29 2013
    Silver Spring, MD
    Pics!?! haha
    Registered Member One Ring TrevorAcor's Avatar
    Apr 09 2015
    '14 S4 P+
    Las Vegas, Nevada
    Whats the price on the Ceramic Pro? Everywhere i look it's "Contact for more info".
    '14 S4 P+/Sport Differential/DD
    Dec 13 2015
    Charlotte, NC
    I have used one for filtering out TDS from Drip Dry Spotless, www.DripDrySpotless.com, attaches directly to your garden hose.
    A real value at $157, it includes a 50ft hose and soap gun....
    Oct 31 2013
    Morris County, NJ
    Griots sells a filter that attaches to the hose I think around $150
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    I used two filter housings one with a sediment filter and the other with a rechargeable water softener cartridge. All you have to do is soak the cartridge in a bucket of water softener pellets and then ready to go.
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
    Apr 04 2012
    MSP
    I simply use a whole house water filtration system in line with my hose from Lowes.
    Reminds me I should change the filter soon.
    http://www.lowes.com/pd_89374-59019-...d=1201339&pl=1
    Mar 22 2015
    2012 Honda Pilot
    Milwaukee, WI
    Quote Originally Posted by Stevejayclt View Post
    Thanks for the heads up on this system!
    I had been comparing to just buying distilled water at the grocery store where I can get it for $.63/gal.
    Although kinda goofy you could fill up a watering can with distilled water and rinse your car like that, would be slightly funny, but would work! :)
    2012 S4 Premium Plus | Phantom Black Pearl | S-tronic | Sports Diff | MMI+ | Black Alcantara | B&O | Advanced Key | Carbon Atlas | 19" Peelers | Park Assist
