Results 1 to 21 of 21
Thread: RS5 Maintenance
    Nov 19 2012
    Irvine, CA
    RS5 Maintenance
    Hi,
    I recently have been looking into getting an RS5 or an S5 and I'm not sure which one to choose.
    CPO 2013 RS5 or CPO 2013-2014 S5.
    I have heard from the dealers that the RS5 need to replace their brake rotors and pads every 15,000 - 25,000 miles. I know the RS rotors are kinda expensive going for 900 for a set.
    Are there any other things I should be worried about on the car besides the rotors and stuff like that?
    Thank You
    Current Vehicle:
    2013 Audi RS5
    Daytona Grey | Carbon Ceramic Brakes | Bilstein PSS10 Coilover | Custom Sport Exhaust | Eurocode Sway Bars Eurocode End Links | LYKT Sport Control Arms
    Sponsors: Bilstein US | Eurocode
    Past Vehicle:
    2014 Audi A5 S-Line Ibis White
    2008 Audi TT V6 Ibis White
    Veteran Member Four Rings ttusqrl's Avatar
    Dec 06 2014
    Dallas, TX
    900 a set is wrong I believe. A full brake job with OEM parts is $2300.
    Also watch out for the s tronic maintenance -- it's expensive. Tires will be more too since it is rolling 20's. Otherwise, it's pretty par for the course.
    Sold (sadly)
    "Luna" 2014 []RS5 Tiefseeblau Pearl Effect w/ Drivers Assist, MMI Nav + Pkg, Sport Exhaust | Suntek Full | Bel STi-R Plus | Parking Sensors
    Mojo31 - "And, everyone needs a badass car. It's a necessity if you want to keep your man card. Mods can make a badass car badder, but cannot make a bad car badass."
    Mar 26 2014
    Cambridge, Ontario, Canada
    Audi care. Done.
    GIAC stage 2, Ecodes, H&R springs, 15/20m, full AWE exhaust.
    Veteran Member Four Rings RickFLS4's Avatar
    Sep 21 2012
    2012 Audi Q5
    Palm Beach County, FL
    Audi Care resolves the DSG maintenance but doesn't cover brakes.
    You can check tire prices on Tire Rack. From my research brakes and tires are quite a bit more on an RS than an S, consistent with post above, and neither seem to last as long on the RS.
    2015 BMW M4
    Past: 2013 S4, 2011 A6 3.0T (accident victim), 2008 Lexus LS-460, 1998 Lexus GS-300, 1994 Lexus ES-300, various GM/Ford/Chrysler cars prior to 1994
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Audi Care covers the majority of the maintenance. The DSG in the RS5 requires more maintenance than the DSG in the S5, so Audi Care is worth it on the RS5. Other than that, it's brakes and tires. 15k to 25k miles for the front brakes is about right. Mine lasted 24k miles and I replaced it with aftermarket ECS rotors and Hawk Pads. The rears were done 3k miles later, so full brake job every ~25k miles is about what you are looking at and even with aftermarket parts and doing it at an indy shop will run you a little over $2000. Tires, at least the OEM P Zero's last about 14k miles with my driving style, so I've been needing new tires about once a year. I do drive fairly spirited and am an avid canyon carver.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Aug 12 2014
    New York, NY
    For comparison I just paid $360 for a complete set of ECS Drilled and Slotted Rotors and $180 for a set of Hawk Ceramic pads for my S5. I have 33k miles and had atleast 30% on my pads and a while to go on my rotors (I warped one during autocross). That being said if you can swallow the extra costs..... Rs5 is a no brainer. You can't compare them when it comes to drive and feeling
    2011 Audi S5
    Prestige|Black Optics|Titanium Wheels|RS5 Rep Grill|20% Tints|
    Aug 12 2014
    New York, NY
    They look like this
    2011 Audi S5
    Veteran Member Four Rings essfour's Avatar
    Dec 03 2010
    Boston
    35k is the first DSG maintenance interval for the RS5 - I believe the S5/4 dsg allows for a greater interval between servicing.
    My front brakes lasted 35k. I bought oem rotors and pads from ecs and changed them my self - front pad and rotor replacements are so easy.
    My rear pads and rotors can probably make it to 50k or so. The caliper in the rear is pretty much the same as the S5 and the weight of both cars is more or less equal so other than slightly different pad compounds and rotor styles the service interval of rear brakes should be the same for both cars.
    The RS takes a few more qts of oil so if you are penny pinching that is a slight difference
    the tire replacement depends mostly on which tire you have... so that is a variable cost between the two. 19's, to 20's make little difference in wear so disregard that comment above. just buy Pilot Super Sports and get the 30k mile tread life warranty and call it a day...
    2022 Daytona RS6
    2020 Alpine White X7 50i
    1987 E30 325ic 5spd
    2018 Tanzanite M3 ZCP - sold
    2013 Phantom Black RS5 w/ Alu Optic package - sold
    2011 S4 6MT Meteor Grey w/ Ti package - sold
    2008 A4 S_Line Avant 2.0T 6-speed - sold
    2006 A4 Sedan 6-speed - sold
    2001 A4 Sedan 5-speed - sold
    Dec 06 2014
    Dallas, TX
    If only PSSs were available in our size.
    Also, the first DSG maintenance on the RS is 15k http://www.audiusa.com/content/dam/a...-Year-2014.pdf
    Sold (sadly)
    Veteran Member Four Rings ak_siberian's Avatar
    Jan 30 2015
    992C4S, T2 Touareg V8, Porsche Macan S, & Gehl turbo bobcat;
    20 miles NW Fairbanks, Alaska
    What does AudiCare run for an RS5? Other than the DSG service I expect to do all the rest myself as I don't really want to drive 800 miles round trip for an oil change for example. In the maintenance sheet it says drain fluids and filter for the DSG is there anything else involved as this doesn't seem like rocket science...
    siberian
    The best long distance runners eat raw meat, run naked and sleep in the snow
    Veteran Member Three Rings Mr. Spectacular's Avatar
    Nov 08 2013
    Houston, TX
    Quote Originally Posted by ak_siberian View Post
    What does AudiCare run for an RS5? Other than the DSG service I expect to do all the rest myself as I don't really want to drive 800 miles round trip for an oil change for example. In the maintenance sheet it says drain fluids and filter for the DSG and tranny is there anything else involved as this doesn't seem like rocket science...
    siberian
    you may need to open up a shop in your parts. Sounds like the market is wide open for a local place.
    Sep 21 2012
    2012 Audi Q5
    Quote Originally Posted by essfour View Post
    My understanding is that PSS are not available in RS-5 OEM sized 20s and therefore would likely require more frequent replacement than on an S model for which PSS is available. Is that not the case?
    2015 BMW M4
    Dec 06 2014
    Dallas, TX
    Quote Originally Posted by ttusqrl View Post
    Quote Originally Posted by RickFLS4 View Post
    That is the case
    Sold (sadly)
    Jan 30 2015
    Mr. Spectacular, well necessity is the mother of all inventions :)
    7 years ago when I got the first Touareg and then a couple of years later when I got the second one I boasted 50% of all Touaregs in Fairbanks. When VW pulled out of here and went to Anchorage I had the nightmare of having to deal with a bunch of incompetents 400 miles away plus a 3 month battle with VWNA until they finally did not only what I said but their own manual stated (problem with a shrinking intake manifold in extreme cold which used to bind the variable intake motors).
    After that (and the end of the warranty) and many many other mishaps where at one point the service manager told me in front of witnesses "those of you not living close to a dealer shouldn't buy VWs" I never set foot at a dealer. Trust me that made headlines around VW.
    In any case I do not trust any dealer, not because they may or may not be inherently honest, but simply that for low volume cars such as the Touaregs and the RS5s, there's very little knowledge as reflected in the forums with over 65,000 members worldwide and the pain folks go through. Forums such as this one are invaluable help. I've invested tons of money on tools, am building a new garage for the RS5 and will do tackle most jobs not having to do with electronics myself. Been working on cars and racing since my 68 Roadrunner days (man I still miss that car).
    As for opening a shop, I doubt I'll see many RS5s but there's recently been a slew of Audi sightings (mostly TTs for some reason). When I met with the Kendall SM here (Kendall took over from the wonderful folks mentioned above) he did say for minor warranty stuff they would be willing to talk to their Anchorage office and see if they could do the work and cross charge and save me the 800 mile round trip.
    As to brake cost mentioned above, yep sounds about right. When I did the V6s and swapped out OEM the pads for KVR carbon fiber with kevlar and Zimmie rotors I had about 900 bucks or so in parts. Labor was my own (about 2.5 hours - well with a smoke break etc). So 2 grand seems about what they would charge with labor for OEM brakes.
    A lot of the stuff you can do yourself if you have a good mechanic background, THINK the problem through, use a VAG-COM and a ton of cash invested in tools. But for the most part it isn't rocket science or defying the laws of physics though it's mostly over-engineered.
    siberian
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    Quote Originally Posted by zhclvn View Post
    Hi,
    Thank You
    If you have the budget to buy either then don't worry about the difference in maintenance and get the RS. I'm not convinced it's very different and will likely depend more on driving style and bad luck. PM me if you want to drop by, I'm in Irvine.
    Veteran Member Four Rings antoff83's Avatar
    Jan 30 2009
    2019 Audi RS5 Sportback
    DEN USA
    Audi platinum protection covers..only pads though. I changed mine at 15K but rotors were good so only pads.
    Otherwise like ttsgrl said OEM rotors+pads+labor is approx $2500 just for the fronts,but you can always curve towards aftermarket..
    No other things you should be worried though..so far for me the car is reliable. Just make sure you rev it regularly
    19' AUDI RS5 SB | Riviera Blue | Black/Rock grey
    18' BMW X5M | Long Beach Blue | Silverstone full Merino
    17' AUDI S7 | Sepang blue | Arras red,gone
    16' MB GLE450 coupe | Diamond white | gone
    14' AUDI RS5 Coupe| Sepang blue gone but not forgotten
    04' BMW M3 Convert | Carbon black gone
    Dec 06 2014
    Dallas, TX
    Quote Originally Posted by antoff83 View Post
    Otherwise like ttusqrl said OEM rotors+pads+labor is approx $2500 just for the fronts,but you can always curve towards aftermarket..
    fixed that for ya -- definitely not a woman
    Sold (sadly)
    Jul 10 2014
    DFW, TX
    Squirrel?
    Squirrel Girl???
    Here today:
    2024 SQ5
    2025 X5
    1975 Triumph TR6
    Dec 06 2014
    Dallas, TX
    Quote Originally Posted by Mojo31 View Post
    Squirrel?
    Yes
    Squirrel Girl???
    No, fcker
    Sold (sadly)
    Jan 30 2009
    DEN USA
    Lol I'm sorry
    Sent from my iPhone 5S using Tapatalk
    Nov 19 2012
    Irvine, CA
    Thank you, for your help
    I should be picking up my 13' RS5 this weekend. I will be posting more about it when i get it.
    Current Vehicle:
    2013 Audi RS5
    Past Vehicle:
