Results 1 to 37 of 37
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    Wheel bearing replacement interval?
    When /miles do you replace bearings if they aren't noticeably failing?
    Tia
    AXA
    Turbo Villains
    May 22 2010
    N.E. Connecticut
    You Don't, The bearings will let you know when they are beginning to fail. Usually a vibration will emit from the wheel bearing. Bearings are usually good for 60,000 to 100,000 miles, sometimes longer.
    Jul 18 2013
    Perth, WA
    One of my fronts has only lasted ~47,000 miles, it has started to whine. I have been told that it is unusual to happen that quickly.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by jazza08 View Post
    I have that beat in 72k miles I have had my passenger side front replaced TWICE, driver's side was done before 42k. These bearing are crap
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Veteran Member Three Rings EasternLI's Avatar
    Nov 21 2004
    2015 Jeep Grand Cherokee Overland High Altitude
    Sag Harbor, New York
    My dealer says he thinks my passenger side rear is going, makes a ton of noise when you take a hard/fast left turn, car only has 22500k on it
    2013 S4 l Monsoon l Black Nappa l Sports Diff l MMI Nav l B&O l Advanced Key l Carbon inlays l GIAC Stage 1 & DSG tune
    AKA: Ticketproof
    Mar 22 2014
    Sarnia Ontario Canada
    I did drivers side at about 58k miles and passenger side last week at 75k miles..Its not a PM item..run to failure (growling noise) It was quite evident when they pooched out on me..S
    2010 s4 Stage 2 tune w/pulley. (93 octane in use)
    2001 e39 M5
    Jan 10 2007
    VA
    Audi has always used lower quality wheel bearings which tend to not last very long.
    It also seems like they fail much sooner on B8s, since they revised the hub, than with previous models.
    Jan 09 2008
    Winnipeg
    My B6 went through a number of wheel bearings. I attributed it to a heavy car being tossed around corners aggressively (at autocross) and spirited driving accelerating the wear. Nice to know little has changed with the B8.
    Active Member Two Rings cookinsolo's Avatar
    Jun 25 2013
    2014 audi R8 v10, 2015 audi TTRS
    san antonio
    75k miles no problems here. but parking sensors... let me tell u how many times those #$&%ing things mess up
    May 22 2010
    N.E. Connecticut
    I should have added that driving style, roadways, crowned roadways will definitely put more strain on the suspension. One can also add the corrosional aspects of salt which is spread at the 1st snowflake in 4 cubic acres (lol)
    Definitely spend the money and buy top quality bearings. Additionally and this is critical to bearing life. The center wheel bolt must be torqued down to 145 ft-lbs. No more, often a shop will use the air powered ratchet to tighten the center bolt.. I don't care what anyone says, hearing the gun ratchet 3 or 4 times does not indicate that the center bolt is torqued to the correct setting. Only a correctly calibrated torque wrench can do that. If you can change your own flat tire then you can check the torque settings on all 4 wheels.
    What happens is that in each of the wheel bearings/hub there are 2 sets of bearings separated by a nylon / teflon / plastic spacer. Too tight and both bearings are unable to spin freely thus friction causes premature failure.
    Veteran Member Three Rings MYFASTA4's Avatar
    Sep 03 2009
    C7 A6, A4 B7 AVANT, B8 ALLROAD & BOX-SPYDER
    Florida
    i think the lug nuts torque specs are 90 ft. lbs. and using a torque wrench will minimized vibrations too.
    2014 S4 6MT, B&T, sport dif., MMI+
    2015 A3 8V
    2001 TT MK1-225
    Dec 20 2005
    District 7
    Quote Originally Posted by MYFASTA4 View Post
    Wait lug nut torq amount will also effect bearing longevity?
    AXA
    Turbo Villains
    Jan 09 2008
    Winnipeg
    I had a flash-back to changing the axle on my TT and having to torque that nut but then it required an extra 90 degrees...that was crazy amount of force to achieve.
    Jul 18 2013
    Perth, WA
    Quote Originally Posted by littleredwagen View Post
    At least you don't live in Australia.. the dealer here quoted me AUD $900 for a single replacement. As with everything here what a rip! Aftermarket bearing it is then haha.
    May 17 2012
    Houston, TX
    I don't see how the lug nuts have anything to do with bearings. The wheel will just get tighter to the brake disc and the brake disc to the edge surface of the hub. There is not additional force on the bearings by over tightening wheel lugs. Unless the bearing surface is proud of the hub, which would just be completely retarded.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    May I ask, of those who had to replace them, what the dealers are charging?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by cspcrx View Post
    Whatever it is, it is TOO much. Replacing wheel bearings is a simple repair that can be done by most competent mechanics especially if they have any familiarity working on German cars. Save yourself some money and have an Independent repair garage do the work.
    May 22 2010
    N.E. Connecticut
    I believe that my invoice was close to $400 when I had my bearing replaced at the dealership. I had Audi coupons worth $100 off but $400 is still more than I would like to pay out.
    Sep 03 2009
    Florida
    Quote Originally Posted by AKPS4 View Post
    that's a good question and it may not have anything to do with it. All I can say is that I have seen spacers not torque to spec and there was a lot of vibration, I would imagine that vibration can cause early wear. I just do it cause I feel good about my work when I do ;-)
    2015 A3 8V
    2001 TT MK1-225
    May 22 2010
    N.E. Connecticut
    The wheels are bolted to the hub, torquing the wheel lugs or nuts ( depending on set up ) isn't going to affect the bearings. To have a significant enough vibration to cause wear on the bearings, let's just say you would be pulling over immediately to see what in hell is happening.
    The wheel would not get tighter to the disc rotors, let's just say that in order to compress the wheel inward, you would reach the shearing limits of the wheel studs beforehand. That is not possible.
    Also cannot get the brake disc rotor closer to the hub by compression. Look at the fastening design of hub, bearing, rotor and caliper. They are designed not to interfere with one another when correctly bolted, no matter how tight the bolts are.
    There is however a point where you could either strip the threads or shear off the heads on the bolts by applying excessive rotational force.
    But that is a catastrophic theoretical point way beyond realistic scenarios.
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    Had one replaced today under CPO. Otherwise was told it would have been $800. 81k miles.
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    I had 2 replaces under warranty and three to date. 4 total. All fronts.
    On 3rd the dealer charged me close to 800 with parts labour and taxes. Never again.
    4th one was ordered from ecs and installed by my local mechanic..350 total.
    It was an *** bearing...just as good as any considering the life of oem bearings.
    Rough winters and road combined with track days definitely contributed....
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Jun 13 2009
    F.A.G. bearing to clarify. Apparently *** is a bad word...
    2023 Q5 2.0 Technik
    Sep 05 2012
    This is just under 60,000 km (37,000 miles.) My passenger front seems to be going. I thought it could be some gravel stuck in the brake since it happened after driving on a dirt road but I couldn't find anything, nor jar it loose by driving like a maniac for a few days. The dealer tech took a ride with me and agreed it was a bearing, but they couldn't book me for service for another 3 weeks (wtf!) because they are booked up doing tire switchovers and de-winterizing Porsches (dealer does both brands.) If they weren't doing it under warranty I'd go somewhere else.
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    Veteran Member Four Rings SC-S4's Avatar
    Jan 23 2014
    LI
    i have 16k miles. I just swapped to summer PSS and noticed possible wheel bearing issue. I will have to swap back to stock 18s to see if its not the wheels/tires.
    2016 V60 P*
    Gone: 2014 S4 - Ice Silver / Sport Diff. / S-Tronic / AG M590-19x9.5-ET40 / PSS
    Mar 07 2015
    2003 SL55 AMG, Audi Q7
    San Francisco, CA
    Are all 4 of the bearings on the S4 pressed in or they can be replaced together with the hub assembly?
    Can this be a DIY project?
    On some cars (Mazda / Nissan), i was able to replace the rear bearings in my own garage, since they came with the hub assembly and there was no need to press them in. It was an hour job on each side.
    Here is a picture of what i am referring to:
    This is from Mazda 3
    Oct 02 2006
    Wadsworth,OH
    Wheel bearings on the S4 are quite simple to replace actually. The front and rear both use flanges secured by 4 triple square bolts. Below is what they look like.
    No need to press the bearing in, only the hub.
    Jason
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Quote Originally Posted by danmm7 View Post
    This is a total DIY project. This video is very helpful and is essentially identical to B8 S4.
    https://www.youtube.com/watch?v=Y2ueku55MvM
    CEO and General Manager of the AZ Pedal Responce Team
    Mar 07 2015
    San Francisco, CA
    Great!!!
    This is pretty easy, indeed. Glad to see that Audi did not go with the pressed in bearings option.
    It's is amazing how much $$$ dealers charge for this job.
    Thanks for posting the video. It goes to my favorites.
    Active Member Two Rings Tmac!'s Avatar
    Mar 27 2015
    2002 F150 Lightning
    GA
    To those that have had failed bearings, what type of indications did you get that they were failing? I have some slight vibration while going straight & turning left. Seems to go away while turning right. This all at speeds above 45 - 50 mph. More of a wah wah wah sound or feeling. Car has 15k miles.
    James
    2012 Monsoon Grey S4 / Vorsteiner V-FF 108 / H&R OE Springs / Bilstein B8 Shocks / EPL Stg 2 / EPL TCU / APR Intake /
    Oct 02 2006
    Wadsworth,OH
    ^^ Definitely sounds like a wheel bearing gone bad. It usually starts with a roaring noise and gradually gets worse. Also if you are noticing it when you load up one side of the vehicle (such as taking a turn) and you notice the noise, then upon exiting it gets quiet. That's one of the most common signs of a bad bearing.
    Jason
    Established Member Two Rings B8s's Avatar
    Sep 26 2012
    Northern New Jersey
    Quote Originally Posted by Boris View Post
    Tia
    I had 3 replaced around 25,000 miles. It really depends
    2012 PHANTOM BLACK // AIRLIFT V2 MANAGEMENT // 20x9 VOSSEN CVT // STASIS EXHAUST // ROC EURO INTAKE // I.E STAGE 1
    Oct 04 2015
    Mississauga Ontario
    Has anyone purchased 3rd party hub assemblies like Timken or Centric? Looking for feedback seeing as how the stock bearings seem like they're nothing special.
    Apr 02 2016
    Gaithersburg, MD
    At work we use Timken, Moog, and Beck Arnley unless it's a dealer only item. For everyday use I don't see problems using these brands. I don't even see a problem using them as spirited drivers or weekend warriors. As people above have stated obvious signs and symptoms of a failing bearing my trick is to lift the wheels off the ground and have the car in neutral. One hand spins the wheel as the other hand holds onto the coil spring. You will feel lots of vibration through the spring if the bearing is bad.
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    Had mine replaced on s2k at 80k miles, but I had fun with that car.
    Had 90k miles on my Evo, and never had to replace. That's with multiple Tail of the Dragon runs, auto-x, and drag racing.
    I can't imagine an awd car having to replace a wheel bearing less than 100k.
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Established Member Two Rings Jay007's Avatar
    Sep 05 2013
    Calgary
    Sorry to bring this back from the dead but I wanted to contribute my experience on my 2015 B8.5 S4 with 43,000 km's on her.
    Just had a dealer visit yesterday and they replaced both front bearings under warranty. Had some buzzing noise coming from the front that got higher pitched with faster speed. Started at around 30km/hr all the way through from there.
    Stock 19' rotors with PS4's summer, TSW 18's with Blizzaks winter. Stock ride height, no spacers.
    Very concerned the vehicle would need two wheel bearings at 43k km's. That's roughly one quarter to one fifth the life I have seen on previous vehicles.
    After researching on here a bit its fairly apparent that there are bearing issues on the B8/B8.5 S4/S5's and possibly A4/5's (not sure if they are the same).
    Is anyone aware of a recall or anything Audi is working on to fix the early failures?
    '15 Audi S4 3.0t, Daytona, options: all, chipwerke pro & RS Intake
    '13 Audi Q5 3.0t, ibis white, options: all, stock for now
    '10 Jeep SRT8 - sold
    '06 Charger SRT8 - sold
    '98 GTP - sold
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by Jay007 View Post
    Maybe Audi could use Honda Wheel Bearings instead, my Element has 233k on it and all 4 original WB's, lol!
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
