So as title states I have the dreaded soft limp, car is stage 3- VAST with intake, full exhaust, 2.0tsi coils, I've swapped the n75 and MAF with another one I know was good. Boost leak tested with no leaks, checked wastegate operation and they kick over quick, plus checked the DV's. Vagcom only shoots up a pos deviation code. I'm totally lost now, i've gone through everything that could be causing it. We also reset the battery and it stayed in boost for awhile longer then as I thought it was good it kicked down and does it almost immediately. Checked again and everything is all good still....What else could cause this code?
