Results 1 to 35 of 35
    Active Member Two Rings kosi123's Avatar
    Oct 12 2013
    Warsaw
    VR6 Longitudinal SWAP - My Best practices
    Hi there,
    I just finished 24V 2.8 swap into my B5. Hope this would help other in similar projects.
    I am also located in EU, so all parts in stock if you heading to swap (Engine mounts, VR5 parts, custom intakes, oil pans) - just let me know :wave:
    Spec. (NA):
    MODEL: A4 B5
    Engine: VR6 2.8 24V BDE
    Intake manifold: Custom, Aluminium
    Exhaust: Stock, no cat.
    Injection: Stock
    Computer: Standalone, Engine Management Unit (EMU)
    Drivetrain: S4 + clutch/adapter VR5
    Suspension: Stock S4 B4
    BODY KIT: S4 Lift
    Brakes: Porsche cayenne + 911. 345mm brake disks (S4 B6)
    Wheels - S4 B6 AVUS III, 235/40/18:
    1 st thing is to modify engine bar, to be fitting with phaeton 3.2 (or modified touareg) oil pan:
    Engine mounts - custome made, my own project. Something based on 034 unit, but without front reinforcement. Gearbox on oryginal mounts.
    I did not use polyurethane engine cushion, but OEM Opel Omega 2.5 turbo diesel :cool: Currently, no vibration inside car.
    To link 01E gearbox and vr6 engine, you have to use VR5 adapter plate - plug&play:
    Clutch - VR5 works perfectly, but only with low torque :/ Later you have to use double plate A5 3.0 TDI with special distance adapter:
    Oil Pan - basically, the only longitudinal VR engines were mounted in Cayenne, Touareg and VW Phaeton, but first two of those are too high and require customization:
    VW phaeton 3.2 is so fu*kin hard to get in EU (ofc used one - New cost around 800$):
    Valve cover - use A3 3.2 if you don't like mods ;)
    Front panel - hood mount goes to hell (require external locks), as well cooler fans (but aircondition fan from S4 is far enough):
    Exhaust manifold - depend on engine (12V or 24) you can buy ready made T3 or T4 with turbo input:
    ECU - I strongly recommend standalone Engine Management Unit ECU + bluetooth connection to your mobile device
    And the results :)
    Go ahead to share your comments - I also dont know everthing :)
    If you need some more info/parts/drawings (not only to swap) - dont hesitate do PM me.
    Jul 14 2014
    richmond va
    very nice ..
    Jun 10 2010
    Good shit.
    You make it sound so simple.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    A+!
    Jan 09 2009
    FL
    gosh that pan hangs so low...
    Nicely done!
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Tight work!
    Oct 12 2013
    Warsaw
    Quote Originally Posted by Hyphy View Post
    Nicely done!
    I messed up a little :) Now oil pan is on normal level, as there is VW phaeton inside. The worst case is when you have Touareg/Cayenne and it need to be customized :
    Need parts form EU? Just write me PM
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    so you're running a stock n/a vr?
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    Quote Originally Posted by CELison View Post
    Looks like it.
    Any plans to turbo(i hope) down the road OP?
    Feb 23 2010
    Emmaus Pa
    I would hope so.
    B9 S4- EPL/AWE
    Aug 23 2014
    Philadelphia, PA
    wow nice swap
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Really wish it was a more viable swap.
    Oct 12 2013
    Warsaw
    yeah, turbo is on its way. I think, well done Garrett GT35 would be most reasonable - car need to be used for daily ride. I would be happy from ~450 HP.
    From my perspective, doing "stage by stage" swap is safer and you can avoid all of the issues.
    Veteran Member Four Rings NYEuroTuner's Avatar
    Oct 24 2008
    "Silvaro" B5 S4, 2013 B8 S4, 2018 RS3
    Great Job.
    -- George
    SEMPER FI
    Build Thread--------------->My VR6 Journey<-Click it, Click it good.
    IABEDINDUSTRIES
    Oct 12 2013
    Warsaw
    Quote Originally Posted by landfill View Post
    Tight work!
    hah, check this B5 V10 Tfsi SWAP of my colleague :)
    Full thead: http://www.racingforum.pl/index.php?...c=82131&st=580
    May 18 2014
    Charlotte/NC
    Dude no freaking way! Screw the VR6 swap. I wonder how the S4 tranny would holdup under the abuse. Note to self......gotta get another S4 for R&D. Any vids of the V10 going down the track?
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by kosi123 View Post
    Holy mother of God. That is unreal!
    Quote Originally Posted by Buggs View Post
    Given how robust they've been to this point, I don't see it being an issue. I'd be worrying about things like diffs, axles etc before I'd worry about the trans.
    2024 M3 Comp xDrive
    Nov 14 2013
    If you fit the v10 tsfi why not just go with the c6 rs6 v10tt and make stupid power.
    That thing would be fucking insane.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    That's what it is in his picture...
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Nov 14 2013
    Oh shit my bad lol. The pic wasn't working on my computer. Wow now that is a badass swap!
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Wyglada dobrze! Now for the turbo!
    2002 Pearl/onyx S4 Avant
    Aug 31 2014
    Wake Forest NC
    My jaw literally dropped..
    2001 Audi S4 Stage 2+/APR Tune/RS4 Clutch/Flywheel/034DP
    Nov 14 2013
    OP I pm'd you about the VR parts.
    Oct 12 2013
    Warsaw
    The V10 project has changed the owner - no info regarding current condition. Reach http://sportmile.pl/ motorsports for more info.
    Back to VR6 SWAP - I've got VW Phaeton OEM oilpan 4Sale! As well custom flywheel for Tilton double plate clutch set matching to VR5 starter (don't need to pay additional 400 bucks for 034 one). PM me.
    Registered User Four Rings UroTuning's Avatar
    Aug 23 2007
    Tampa Bay, FL
    Nice!!!!
    Oct 24 2008
    Quote Originally Posted by Peter1.8t View Post
    Is has become a very viable swap.
    http://www.INAENGINEERING.COM has OEM Engine brackets that allow for direct bolt up.
    So many OEM components are available today as opposed to years ago.
    OEM Swap Parts listed below....
    Engine brackets
    Starter
    Trans adapter
    Oil pan
    OEM Engine management is now possible for the VR in the B5 S4 :)
    Lots of new options, this swap wont be possible for anyone unless they stop spending time finding obstacles rather than finding solutions.
    -- George
    SEMPER FI
    IABEDINDUSTRIES
    Jun 27 2012
    Brooklyn ny
    pmed
    Sep 15 2015
    south central KY
    I mean no disrespect, but why swap out a 2.7 for the VR6? I looked into it myself and they have to be built to make anything more than a 2.7. And with the 2.7 you just need rods for massive power. The only thing I can think of is more room to work on the sides.
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Quote Originally Posted by corey5988 View Post
    Damn, my buddy's stock 12v made way more power than and stock rod 2.7t. Might want to rethink bc Stock block VR's have seen 9 second passes on fwd cars.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Sep 15 2015
    south central KY
    Quote Originally Posted by viceprp View Post
    All the info I've seen when I was looking into it indicated you were good to 425-450whp without touching the engine and 500+/- whp with a spacer to drop c.r. That is reliably in a street car, from what I've seen.
    Oct 17 2009
    alonE, Pa
    Correct, those would make a more reliable DD. Also have seen a head spacer make a higg 9 second run. VR6T are an amazing motor. Before beefing up the bottom end and going BT, his 60 trim would spool like a k03 car and make 400 whp with ease (ran out of fuel/inj).
    Now he runs a 6466 and makes over 700whp with more to go.
    STEVE
    Aug 24 2014
    Newport Beach, CA
    How responsive are the VR6ts in normal driving at those power levels? One thing I like about the 2.7 is it has really nice response down low.
    2024 M3 Comp xDrive
    Oct 06 2011
    Farmington CT
    True but remember even with the 2.7 when getting to higher numbers response does start to go down as well. Maybe less since two smaller turbos but still goes down. One reason. I wanna do this when I have money lol is because at high power maintaining a 2.7t becomes a full time job haha
    Sent from my SCH-I545 using Tapatalk
    Oct 17 2009
    alonE, Pa
    Quote Originally Posted by christianb5s4 View Post
    2.8 177/174
    3.2 250/?
    3.6 280/260
    Those are n/a numbers.
    Edit: my buddy's 12v 6466 made 674/569 @ 28psi. Jumping over 100 whp from 24 to 28psi. Each gear runs different boost levels but is over 34psi now in 3-5. Nothing like doing a 60mph rolling anti-lag and laying over 100 yards of rubber.
    A 60 trim on his 12v felt like a k04 spool. It was at full boost by 3k and would die quick (6500). Cams make the car very responsive.
    I know a 12v NA car making just over 300whp on just cams. They are tq monsters. The VR6 is far more superior than the 2.7.
    Remember, USP 24V vr6 is no coincidence. They didn't pull the 2.7 out for no reason.
    STEVE
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Hi there,
    Spec. (NA):
    MODEL: A4 B5
    Injection: Stock
    BODY KIT: S4 Lift
    And the results :)
    Any input on cost? I need all parts
    Sent from my SM-G930T using Tapatalk
