Results 1 to 21 of 21
    Senior Member Three Rings Liquidsystm's Avatar
    Apr 30 2012
    SF/CA
    Recommended tire size for 21x10.5" wheels
    I have some 21x10.5 wheels on order and just want to see what most of you are running for that size wheel. I've seen the range of 275/30/21, 285/30/21, 295/30/21 and 295/25/21 tires on this size wheel. Looking for something that I could daily comfortably, but also won't rub as my car sits pretty low (front fenders are rolled). I want to go with Michelin PSS, but there's limitation in sizes, would 295/30/21 be too much tire?
    This is how my car is sitting on stock 20's.
    14' S7
    Phantom Black Pearl | 21x10.5 ADV.1 Wheels ADV10 M.V2 CS | APR Stage 1 | AWE V2 S-FLO Carbon Air Intake | Milltek Non-Res Exhaust | Airmatic Lowering Links | Eurocode Stabilizer Bars | SPC Control Arms | Flat Bottom Wheel | Black Optics | Carbon Inlay | Xpel
    19' AMG C63 Coupe
    Obsidian Black Metallic | AMG Sports Exhaust | Night Package
    IG: gaberoonie
    Jan 21 2014
    2014 Toyota Sequoia Platinum Black
    Cummington MA
    Quote Originally Posted by Liquidsystm View Post
    I have 295/30r21 PSS on my RS7. They are slightly taller and obviously wider than stock. You can really lay into an exit ramp with that much sticky contact. Mine rubbed slightly when I was really laying into a corner, part of the reason I am going with new sway bars well, to help deal with the body roll.
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    I would go with 285 personally. 295 is too wide for me. I also have new wheels with the same width on order but 20 inch. I went with the smaller wheel route to save weight on an each wheel and wrap around them with PSS 285/30/20. Those stock 21 blade wheels are so damn heavy.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Apr 30 2012
    SF/CA
    I was thinking 275/30, but no PSS in that size, so maybe I'll look into 285's.
    14' S7
    19' AMG C63 Coupe
    IG: gaberoonie
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    PSS has 285/30/21 but it's back order everywhere. You will have to be patient if you want that tire.
    Other: 2017 BMW X1
    Jan 21 2014
    Cummington MA
    Since it was not mentioned yet, 285 will equal less rim protection. If you are really careful it wont matter but wider rubber will always protect your wheels better.
    This is what 295s look like BTW:
    http://www.enjoygram.com/m/809538576949206980_310250534
    http://www.enjoygram.com/m/809412654296227764_310250534
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Quote Originally Posted by nosirrahx View Post
    I like the aggressiveness of this, but i really doubt it will work at the OP's ride height
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Established Member Two Rings Mister_T_'s Avatar
    Jul 15 2014
    Long Beach, Ca
    I just put 275/30/21's (Hankookies) they are perfect. A little too tight due to the offset I am running being that the car is on airbags...but the ride comfort/style goes well together.
    Jan 21 2014
    Cummington MA
    I would tend to agree. The total height of a 295/30r21 is +.5 so +.25 from the center. Lowering at all in combination with this would cause rubbing in many situations.
    BTW, I don't actually know who took the pics of my car but the guy with long gray hair in the top one is me :)
    Apr 30 2012
    SF/CA
    haha nice, car is looking sharp! I may have to go 285 or 275, thanks for the feed back guys!
    14' S7
    19' AMG C63 Coupe
    IG: gaberoonie
    Senior Member Two Rings confinedz's Avatar
    Jan 13 2010
    Palm Harbor, Florida
    I am running 275/30/21 on 10.5 ET30 wheel.....there is a stretch to it but it allows me to go for the stance I am looking for using the H&R ETS Module.
    Jul 26 2012
    Cars!!!!
    Westchester ny
    I am running 275-30-21 p-zero 21x10.5 et 27
    Sep 05 2014
    Houston, Texas
    21x10 with 265/30/21. Car had 285/30 before and rubbed.
    Sep 05 2014
    Houston, Texas
    Wheels are for sale too btw.
    Jan 13 2010
    [IMG][/IMG]
    Jul 15 2014
    Long Beach, Ca
    Quote Originally Posted by Asiete1727 View Post
    ET 27 is perfect with those wheel dimensions, nice job.
    Jul 26 2012
    Cars!!!!
    Westchester ny
    Established Member Two Rings Pale Rider's Avatar
    May 16 2012
    2014 R8 V10 Daytona Gray Pearl | 2015 Audi RS7 Daytona Gray Matte
    NorCal, USA
    Right now, I am running the OEM wheels & tires [275/30/21 Conti] with the KW HAS, while my HRE wheels are getting some re-finishing. Very full wheel well, but no sign or sound of rubbing.
    On Order: 2022e-torn GT Daytona Gray Matte/Prestige/Black Optic
    Here: 2014 R8 V10 S Tronic Daytona Gray/Black Optic/20" HRE P101/Passport 9500ci
    2015 RS7 Daytona Gray Matte/DRC/Carbon Optic/All of the Goodies/21" HRE P104/Akrapovic/BelStiR-ALP
    Gone: 2013 A7 Prestige Quartz/Light Gray/Innovation/20"/Passport 9500ci
    2006 A4 Cabriolet 3.0 Ocean Blue Pearl
    2006 A6 3.2 Night Blue Pearl
    Veteran Member Four Rings deucescorner's Avatar
    Aug 26 2008
    None
    None
    Old thread but you make me want to keep my OEM wheels!! Stance is perfect!!
    Are those stock 20x9 with 265/35 tires?
    Apr 30 2012
    SF/CA
    Yeah on 20" stockers. This is how she sits with the 21's.
    14' S7
    19' AMG C63 Coupe
    IG: gaberoonie
    Junior Member One Ring
    Aug 14 2020
    Ontario, Canada
    Looks awesome and not to open up the floodgates on an old thread but what tire size you go with? I got Vossen 21x10.5 with 275/30/21 tires and I am thinking to go with a slightly wider tire size. I’ve heard folks go 295/25/21 which I am evaluating
