Results 1 to 17 of 17
    Established Member Two Rings Beats's Avatar
    Jun 10 2014
    Broward County, Florida
    A4 B8 Slow Acceleration
    So for some reason my car seems to accelerate slow from a stop and from a rolling start.
    Does anyone know what it can be?
    It's only in Drive. The car is fine in manual or sport.
    Thanks
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    Because stock a4 is not fast.
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Feb 19 2014
    RVA
    unplug the neg battery terminal for 10 min (or however long it takes to reset everything)
    then report back.
    Feb 12 2005
    Denver
    I've noticed this with my wife's '12 Avant A4 Quattro S 8spd that we recently picked up. First 0-10mph, car doesn't lurch when you need it to while getting out in traffic from side streets etc. After that initial hesitation, it's off to the races. Worth having Audi look at it or is this oem throttle body/ignition delay? If it is, will APR Stg 1 v2.0 completely remedy issue, or just a bit? I wouldn't mind some more kick when I'm driving it around town (used to E92 M ESS-625 :), but she doesn't care... single desire is to remedy the initial acceleration.
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    Quote Originally Posted by PwAg View Post
    not trying to sound like a wise guy but that honestly just sounds like turbo lag. Turbo cars don't lurch off the line unless you're dumping the clutch or brake boosting. APR stage 1 will wake the car up but honestly it's not going to make much of a difference for the 0-10 mph start you speak of. It will make the car pull much harder once you get going
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Sounds normal for D mode, just drive in S instead.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Feb 12 2005
    Denver
    Quote Originally Posted by AllroadCorbin View Post
    Not wise guy at all, it is perhaps the obvious (t lag) I was hoping would not be the case. I've had 5spd B5/B6's in the past, would always compensate in quick traffic situations with aggressive clutch. It's just that the initial lag seems like the 2.0 block is a 1.5 for that initial jump, including S mode. I'll try terminal reset, can't hurt. If the throttle is feathered a bit at start, it feels like it registers a quicker start versus full pedal. Made me think it was ignition delay/throttle setting so not to overburden auto trans. APR brake boost enable may be the excuse wife needs to chip it.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Quote Originally Posted by oascom View Post
    Stock a4 is slow. Horrendously slow.
    2016 S3
    Instagram- @Thisisastickup
    Jun 10 2014
    Funny.
    Jun 10 2014
    Quote Originally Posted by Jerry1847 View Post
    then report back.
    I'll try that when I get home. I'll report back when it's done.
    Jun 10 2014
    I just started to notice the lag a few weeks ago. Though I had a misfire and it wouldn't accelerate over 2k rpm without shaking and after the coil packs were replaced it didn't happen anymore. Though the car really doesn't feel like how it used to accelerate.
    Jan 01 2015
    Hartford
    Not compared to the Subaru impreza I came from!
    I'm going to ride out my CPO then get a stage I tune and see what all the hype is about.
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    May be time to order the Apr turbo delete pipe and forget about turbo lag.
    Jan 08 2013
    New Jersey
    It's a turbo lag. Normal thing. Get new pipes / box delete / tune etc. and you notice lag is gone.
    Jan 15 2014
    Boston, MA
    Quote Originally Posted by B44 View Post
    turbo delete pipe? You mean the turbo muffler delete?
    B9 Allroad
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Established Member Two Rings Allroad!'s Avatar
    Mar 21 2014
    Yup out of the gate from 0 to 25 it stalls or maybe it is the turbo lag. Once it hits about 25 mph it's fine with acceleration. Might also be from the programming if you don't drive fast all the time, won't memorize that. It's a problem for me because I sometimes go easy at first to save gas. So at times when I want to go fast from 0 - 25 it gets annoying. Once my extended warranty is expired, i'll do all those mods to kill the lag.
    BMC air filter | Eurocode TRUFit | StopTech rotors | Akebono pads | 034 transmission mount insert | StaSIS rsb | LED interior | de-badged | Alpine Type-R's | S4 pedal set
