Results 1 to 36 of 36
    Established Member Two Rings jst4show2.8's Avatar
    Jul 18 2007
    1998 Audi 1998 2.8
    Nrh
    upgrading the intercooler?
    i am looking in to replacing the factory intercooler on my 01 a4. I am curious as to which way to go, getting a side mount or front mount. What are you guys opinions as to which way to go. Along with what else i should replace while doing this.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    If it's in the budget, do the piping. Also, fmic are so cheap it's hard not to go with them. You may need cut the bumper a little, nothing too complicated.
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Its not to hard to put the front mount in Are you running a tune or anything? if you plan on keeping the car stock you dont need one. But if you plan to mod tune, bigger turbo ect get a nice core so you dont have to buy another one later on.
    SOLD the GOINHAM A4 ---> GT2860 Project
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    If I were running a stock turbo or pretty much anything with the stock turbo flange, I would personally get an upgraded side mount intercooler. I'm not a huge fan of the FMIC look. I say that, and I have a giant one on my sedan, but it is painted black so it isn't easy to tell. And The turbo on there is big enough to need such an intercooler. But if I ever upgrade the one on my Avant, it will be a good side mount.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Oct 10 2013
    State College PA
    The only upgraded SMIC is 550$..... I'll opt for the 250$ fmic.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Davdraco1 View Post
    There's a reason it costs that much. Better quality, plus there is more than one option available. Don't know them off the top of my head, but used is always an option
    2000 S4- Working?
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    But is that $250 FMIC a drop-in kit total cost or just a FMIC without any pipes, hoses and clamps? Best to compare apples to apples then apples to half a orange from China. lol
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    If you are getting an FMIC, treadstone tr18t. Done
    2000 S4- Working?
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Quote Originally Posted by M-Hood View Post
    Love it hahaha
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Dec 05 2007
    ^This. Lmao!
    Jul 18 2007
    1998 Audi 1998 2.8
    Nrh
    Quote Originally Posted by GOODBYNAAIR View Post
    the car is running a stock k03 right now but when i do the intercooler i am gonna replace the turbo with a k04 and the car is currently running a tune from daz.
    Sep 21 2014
    2001 b5 a4 1.8l awm quartro, 2014 corolla s plus, 2013 corolla s
    anderson south carolina
    whats the link for the treadstone tr18t
    2001 b5 a4 1.8l awm quarto: ebay short shift kit, jhm solid linkage upgrade, crown royal apple shifter boot
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Why do you need to upgrade your intercooler?
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by gearhead9992 View Post
    http://lmgtfy.com/?q=treadstone+tr18t
    2000 S4- Working?
    Feb 08 2011
    Quote Originally Posted by adam044 View Post
    Because the stock SMIC was designed to handle the amount of air flow from the K03 at stock boost pressure. Sure it might work great in winter, but is pretty much being pushed it's limits in warm/hot summer temps, even upgrading to a larger aftermarket SMIC or small FMIC will really help keep the IAT's down.
    Treadstone TR18T is a bit overkill for a K03 or even K04-15.
    Sep 25 2014
    Birmingham, AL
    I still am new but my experience is its a lot more costly to do an upgrade smic than to do a fmic and I got one that's the whole kit and is a lot longer and short than some you can buy and got around the whole cutting your bumper deal...
    Established Member Two Rings kk97's Avatar
    Jan 30 2014
    Doesnt work too good with stock bumper
    Oct 10 2013
    State College PA
    Are the ebay fmic kits that bad? I figure they have to be better then the stock set up.
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Quote Originally Posted by jst4show2.8 View Post
    A decent SMIC (Apikol) is going to run you close to $500 new. The Treadstone TR-18 and the B5 A4 pipe kit from CXRacing on ebay can be had for just a little bit over that $500 mark.
    That being said, if you truly will not be running anything larger than a K04-15, the Treadstone is not necesserily 'needed'. But, this is your car and you can choose to do what you want. You would be hard pressed to find any discernable negative performance impacts by using it. You should consider the extra work involved, not a big deal to some, but extra work none-the-less, to get the FMIC installed.
    If it were me, and I was hell-bent on getting an eBay FMIC, I would probably not look much further than this kit for the sheer fact that it appears to be fully bolt on.
    This is my opinion so take it for that.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Quote Originally Posted by kk97 View Post
    Thats because the intercooler is upside down.
    1998.5 A4 1.8TQM My Build
    Dec 05 2007
    And cutting the rebar is almost mandated with most cores.
    Veteran Member Three Rings 3 bar's Avatar
    16 SQ5, 14 A7 Tdi, 91 Corrado, 02 Passat wagon, 99.5 A4 TQM
    Greensboro NC
    Had to use an S4 bumper with mine. The CX racing piping sits real low on the passengers side.
    2004 Atlas Grey A4 Avant
    1999.5 Volcano Black Audi A4 1.8TQM
    2002 VW Passat wagon 1.8t 5 speed
    1991 VW Corrado 1.8t w/matching trailer Waterfest 03/04 winner (show)
    1980 Chrysler Cordoba LS 371ci 450hp 12.68(go)
    Oct 31 2014
    NH
    Correct. As far as I know his car is stock though, never mentioned any upgrades.
    2014 Audi S4 - 6MT
    2000 Audi A4
    Feb 08 2011
    Actually he did 2 posts before yours.
    Oct 24 2011
    New Jersey
    Quote Originally Posted by 3 bar View Post
    My brother used the CX Racing B5 A4 specific kit and had no issue with getting it to fit behind the stock bumper (with much trimming) and even was able to get the piping to go over the AC lines instead of under how people typically run it.
    Jul 18 2007
    1998 Audi 1998 2.8
    Nrh
    Yea I am running a tune from Daz, along with test pipe,down pipe, turbo back exhaust and a 007 forge diverted valve so the next move is the k04 and an Intercooler
    Oct 31 2014
    NH
    Total overkill. The k04 really isn't that impressive for what you're paying for. I was going to upgrade to it but it's pointless I think.
    Jul 18 2007
    1998 Audi 1998 2.8
    Nrh
    Yea I can't really run anything bigger than a k04 on a tiptronic transmission with out blowing it and even this is pushing it
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Pffff....haha...April Fools?
    As said before that's upside down. Also if it hits the inside rebar when placing upwards: It takes almost seconds to simply slice a the rectangle shape of the top of the fmic in the rebar so it rests in there. No hard core cutting, no hacking, nothing nasty. An angle grinder slices so well and you can produce a good clean cut. If you haven't done it before is super easy.
    Oct 24 2011
    New Jersey
    For the price of a K04-15 you could simply get a Frankenturbo and run a slighly conservative tune to keep your trans happy.
    Jan 30 2014
    Quote Originally Posted by A1 A2 German View Post
    it doesnt really matter if its upside down or not... well might act as a catch can for oil in intake now lol but still itsnt the lowest point on my car, so doesnt matter, and yes the rebar was in the way, and actually wouldnt be to hard modding it
    Dec 05 2007
    It actually does make a difference. Not significant, but can make a couple degree IAT difference. Heat rises, and you don't want your outlet on the highest point of the intercooler. Also, got the TR18T to fit behind my stock bumper while retaining all grills, fog lights, and AC. Lots of trimming involved (don't take this lightly).
    Greensboro NC
    Quote Originally Posted by Believer View Post
    I'd like to see how he did it. Got any pics?
    Junior Member Two Rings
    Feb 19 2013
    Provo, Ut
    From the research I've done and speaking with people, if you're not going larger than a K04, then a FMIC is extra turbo lag. (More volume for the small turbo to fill up) And because of it's size (the turbo) A FMIC doesn't do a significant more amount of cooling than an upgraded SMIC because it's not going to produce a significant amount more heat than the stock K03. At least this has been my understanding, someone correct me if I'm wrong.
    Oct 24 2011
    New Jersey
    Sure thing.
    Feb 08 2011
    Quote Originally Posted by ducksrunner25 View Post
    They are actually wrong since a FMIC designed for a K03 will make a huge difference, that has been proven plenty of times. It is all about running the right size core for the turbo being used. Do you really think I could have ran 14.29 in the 1/4 mile with my stock K03 using a EVo Motorsports FMIC if it was causing lag? What you gain the most with a FMIC is more direct air hitting the front of the core and a FMIC will have more surface area getting that direct air flow which means the heat can be decreased quicker.
    Sure if you go way too big of a FMIC you will see a good amount of lag, but that is why FMIC's are offered in different sizes rated for different air flow and HP. It would be pretty stupid to put a FMIC made for a 30r on a car running a K03/K04 seeing the volume of the core is way too big.
