So I am running revo stage 2 with a 034 test pipe
When I went initially to get my emissions done in the state of Maryland
a few of monitors weren't passing
Revo recently put a test pipe file on my car for emissions issues.
Because the code was showing bank 1- I went ahead and replaced the front 02 sensor and today I went out for a drive to set the readiness monitors, and within 30-50 miles the cel came back on.
and now its showing
They keep saying putting a o2 spacer on the rear will not help with the cel.
1 Fault Found:
10434 - Catalyst System; Bank 1
P0420 00 [237] - Efficiency Below Threshold
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 105478 km
Date: 2015.03.27
Time: 12:48:20
Mode 01 - PID 01 : Readiness -- Address 7E8
Number of DTCs stored: 1 -- MIL Status: MIL ON
Misfire monitoring: Passed
Fuel System: Passed
Comprehensive Components: Passed
Catalyst monitoring: Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring: Passed
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring: Passed
Oxygen sensor heater monitoring: Passed
Exhaust Gas Recirculation: Passed
The logs I pulled today after installing said front o2sensor after clearing the dtc and this is what the code was when the cel popped up
1 Fault Found:
P0420 00 [175] - Efficiency Below Threshold
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 105785 km
Date: 2015.03.30
Time: 13:29:10
Readiness: 0100 0100
Readiness Status: 1110 0101
Exhaust Gas Recirculation: Failed or Incomplete
Oxygen Sensor Heating: Failed or Incomplete
Oxygen Sensor(s): Failed or Incomplete
Air Conditioning: Passed
Seconday Air Injection: Passed
Evaporative Emissions: Failed or Incomplete
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
You guys got any ideas?
and yes I tried to search the forums but nothing really came up
