Results 1 to 9 of 9
    Sep 17 2005
    Fremont, California
    New: 034Motorsport MkII Audi TT Stainless Steel Subframe Locking Collar Upgrade Kits!
    Introductory Special: ENDED
    We're pleased to announce an exclusive Introductory Special on the new 034Motorsport Stainless Steel Subframe Locking Collar Upgrade Kit for the MkV/MkVI Volkswagen Golf/Jetta/GTI/GLI/R32/Passat/Rabbit & 8J/8P Audi A3/TT!
    034Motorsport Stainless Steel Subframe Locking Collar Upgrade Kit, MkV/MkVI Volkswagen & 8J/8P Audi
    Retail: $195.00 + Shipping
    Introductory Special: $175.00 + Shipping
    Introductory special pricing is limited to the first 20 buyers. Thank you for all of the interest, and we hope you enjoy the upgrade!
    034Motorsport is pleased to present the Stainless Steel Subframe Locking Collar Upgrade Kit for the MkV/MkVI Volkswagen Golf/Jetta/GTI/GLI/R32/Passat/Rabbit & 8J/8P Audi A3/TT! Designed to center the subframe using precision-engineered stainless steel insert bushings and large-diameter bolts, this kit eliminates clunks caused by the subframe shifting, and increases chassis rigidity for improved handling performance.
    This kit addresses the very common subframe clunk/pop/creak that presents itself when taking slow turns, entering driveways, coming to a stop, and starting from a standstill. Unlike the band-aid shims used in the factory Volkswagen Technical Service Bulletin (TSB V-401202 & Others) repair, these locking collars and upgraded bolts are a permanent, affordable solution to address the fundamental issue with the factory subframe design.
    The upper and lower collars in our kit are specifically machineded to locate the subframe and bolts perfectly and ensure hassle-free installation. The supplied bolts feature factory-correct tips and thread engagement points to prevent thread stripping. Unlike other kits on the market that use softer alloys, our Mk5/Mk6 VW Golf/Jetta/GTI/GLI/R32/Passat/Rabbit, Audi A3, Mk2 Audi TT Subframe Locking Collars are made from stainless steel to prevent deformation and ensure a lifetime of performance.
    Installation is very straightforward and can be performed in approximately one hour. No permanent modification to the subframe is required, and this upgrade completely reversible.
    Features:
    • CNC-Machined Stainless Steel Locking Collars
    • Application-Specific Design for Both Upper & Lower Locking Collars
    • Engineered to Properly Locate (Center) Factory Front Subframe & Eliminate Shifting/Clunks
    • Includes New Large-Diameter Subframe Bolts to Prevent Loosening
    • Improves Chassis Rigidity & Handling Performance
    • Addresses Volkswagen Subframe Knocking Noise TSB V-401202 & Others Permanently!
    • Will Not Cause Additional NVH Transfer Inside Cabin
    • Easy, Straightforward Installation Takes Approximately 1 Hour!
    What's Included:
    • 034Motorsport Stainless Steel Upper Subframe Locking Collars (Set of 6)
    • 034Motorsport Stainless Steel Lower Subframe Locking Collars (Set of 6)
    • High Strength Large-Diameter Factory Subframe Bolts (Set of 6)
    Fitment:
    • 2006 - 2014 Audi A3/S3 (8P)
    • 2006 - 2013 Audi TT / TTS (8J)
    • 2005 - 2009 Volkswagen GLI / GTI / Jetta / R32 / Rabbit (MkV)
    • 2010 - 2014 Volkswagen GLI / Golf / GTI / Jetta / Golf R (MkVI)
    • 2005 - 2010 Volkswagen Passat (B6)
    Replaces:
    • WHT000431A
    • N91039802
    Installation Instructions:
    Please don't hesitate to contact us via PM or email if you have any questions.
    Click Here to Order!
    Sep 17 2005
    Fremont, California
    Thank you for the orders!
    Veteran Member Four Rings osideaudi's Avatar
    Jan 30 2012
    Maine
    I dont get the benefit.. six bolts and some washers for 175$? Plus install, plus an alignment? all to alleviate a small noise?
    Vic
    Future:
    '17 Audi S3 - Nano Grey
    Current:
    '16 BMW F83 M4 - Alpine White
    Previous:
    '16 Audi SQ5
    '11 Audi B8 S4
    '08 Audi TT
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by osideaudi View Post
    The subframe clunk is actually quite loud - not to mention that when the subframe shifts, it affects your alignment and handling. It also can lead to failure of the factory bolts.
    This is a very well documented issue that has been documented in the MkV/MkVI Volkswagen and Audi TTRS communities. There is a manufacturer-issued TSB regarding this, which consists of two shims and different bolts that only help temporarily.
    We offer a lasting solution, which consists of 12 precision-machined 303 stainless steel locking collars (not washers) that prevent shifting and positively locate the subframe, and 6 high-grade factory TTY bolts (which are not cheap) to replace the stock parts. Installation is straightforward and well documented in our instruction document. Not to mention, if the subframe is shifting, your car needs an alignment to begin with.
    If you want to prevent your subframe from shifting, then this is the solution we offer.
    Sep 17 2005
    Fremont, California
    We only have 5 sets left at the Introductory Special price!
    Get yours before they're gone.
    Sep 17 2005
    Fremont, California
    Thank you for all of the orders! The Introductory Special has ended.
    Click Here to Buy Performance Subframe Locking Collar & Bolt Kit for Audi TT
    Sep 17 2005
    Fremont, California
    We're shipping out a few more subframe locking collar kits today!
    Also, we made some changes to vehicle selection on our website. Hopefully it's a little bit easier to find the parts your looking for, but your help is appreciated! If you can't find something, or see something listed for a vehicle that is not applicable, please send me an email so that I can fix it ASAP.
    - Shop 8J (MkII) Audi TT 2.0T FSI Performance Parts & Tuning
    - Shop 8J (MkII) Audi TT 3.2L VR6 24V Performance Parts & Tuning
    - Shop 8J (MkII) Audi TTS 2.0T FSI Performance Parts & Tuning
    - Shop 8J (MkII) Audi TTRS 2.5 TFSI Performance Parts & Tuning
    Thank you for your continued business and support! We have more improvements planned out, but this was the first step along the way.
    - Laszlo
    Sep 17 2005
    Fremont, California
    Thank you for the continued orders!
    Sep 17 2005
    Fremont, California
    We'd like to wish everyone a pleasant Independence Day Weekend! Happy 239th Birthday, America!
    034Motorsport will be closed Friday, July 3rd through Sunday, July 5th. Our website will be processing orders as usual, and we'll be back to business as usual on Monday. We've even got a few special products just for the 4th of July!
    Hand-Drawn Bald Eagle Sketch (Monochrome Pencil or Full 16-Color Crayola)
    Starting at $25!
    Free BBQ Cooked by Javad Shadzi, 034Motorsport's Founder & President
    Free!
