Results 1 to 15 of 15
    Sep 05 2014
    Boston Area
    Coolant Flush DIY?
    I've searched and maybe im a little slow but couldnt seem to find a good one. I have a cracked reservoir and figure its as good a time as any to flush it if I have to replace the tank. Cant someone please point me in the right direction if there is a good one preferably with pics. Thanks
    Senior Member Three Rings blocke's Avatar
    Jul 26 2013
    1990 BMW 325i (sold), 2006 VW GTI (sold), 2006 A4 S-line (sold), 2014 Jetta SportWagen TDI
    Temecula, CA
    There is a drain plug on the bottom of the water pump or thermostat (cant remember). Extremely easy.
    Performance: Fast Intentions 12" resonated cat back, ECS Snub Mount, JHM LTW Crank Pulley, JHM IM spacers, Optima Red Top, Dimple Oil drain magnet, 034 engine mounts,
    Suspension/Brakes: JHM LTW rotors front & Rear, Hawk HPS Pads, VMR V708's, H&R Sport springs, 034 strut mounts.
    Visual: Lamin-X on headlights, 20% tint , ZIZA city LEDs, Ziza License place LEDS, Interior LED conversion, R8 oil cap, 996 coolant cap
    Instagram: lockebrian
    Sep 05 2014
    Boston Area
    I figured as much but my concern is ending up with air bubbles ets... Just want to make sure i dont miss anything crucial.
    Quote Originally Posted by blocke View Post
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Drain the coolant as above or take off the lower rad hose. If you want to flush you can run a hose and flush. Drain everything and reattach the hose if that's how you drained. Fill with close to 50/50 distilled. I usually just leave the cap off the reservoir and elevate it a bit, start the car, heat on and fan on low. Once you get hot air blowing top up the reservoir.
    I have an A4 so likely a bit different. On mine there is a bleed screw on the top coolant hard line but it is plastic and cheap, I've already had to replace it with a metal metric bolt. That's why I say I usually opt to bleed the air out via the reservoir, works the best for me, pretty sure the cap is self venting anyway.
    Here's a B6 A4 one with pictures if it helps at all, different setup. Apart from how you decide to drain, filling it up is essentially the same if you decide to go the full flush route. I never have, I always just drain until it stops then top up with 50/50 distilled.
    Sep 05 2014
    Boston Area
    Plus - looking for the best information as to what the highest quality materials i should use including mixture etc... Flushing out the heater core etc..
    Nov 11 2010
    Rochester, MN
    If you have an air compressor and you never want to worry about air in the system ever again, this is a phenomenal investment.
    19" B8 S5 Peelers
    Sep 05 2014
    Boston Area
    Looks great, might consider it. I do have a compressor.
    Quote Originally Posted by SlickFix View Post
    Aug 10 2011
    330i ZHP
    Quote Originally Posted by daad729 View Post
    Pick up distilled water where ever, pick up a jug of G12 coolant at a VW dealer (cheaper there usually), done.
    Sep 05 2014
    Boston Area
    So i take it there is no DIY from start to finish... lol
    Nov 11 2010
    Rochester, MN
    Doesn't look like it. I googled and didn't find any for a B6 S4. Looks like here's the opportunity you've been waiting for to do your first DIY!
    19" B8 S5 Peelers
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    IIRC G13 is now the standard.
    Old Geezer, formerly known as Stud Muffin
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    http://www.audizine.com/forum/showth...lant-flush-diy
    I bumped this thread back in july, had the same question. Just drained it at the thermostat, same pic as in post 2. I probably should have drained it, ran it with distlled for a little bit, then replaced 50/50 mix to make sure it was really clean, but I just drained and refilled. I did it with 55,000 miles on it, looked ok to me. I did not have a problem getting the air out either, was really smooth overall
    Sep 05 2014
    Boston Area
    Thank you sir!
    Quote Originally Posted by Guitarmageddon View Post
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by QIKRNU View Post
    Yes. It's G13.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Nov 11 2010
    Rochester, MN
    FCP Groton has G13 on sale for $19.98/gal right now. I bought two gallons for the future at that price!
    19" B8 S5 Peelers
