Results 1 to 28 of 28
    Aug 23 2011
    Erie
    any review's on Maximizer tubular exhaust manifold
    Im hoping someone has this and is still holding up? Would be a cheap alternative ($400) to a tubular manifold if quality and reliability are not compromised!?!?
    Spec;
    Primaries Tube : 1.8"*OD
    Flange Thickness 3/8"
    Runner Wall Thickness 16 Gauge (1.5mm)
    T3 Turbo Flange
    4-bolt Wastegate Flange
    Sand blast polished 304 grade stainless steel
    High quality 304 stainless steel
    Mandrel bend for a faster and smoother airflow
    CNC machined flanges with Dual-TIG welded durable construction
    Accessories on photo are included
    Maximizer backed lifetime warranty against manufacturer defects
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    pics didnt work. link to product?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Found it. Looks decent. May be worth the gamble for $400
    http://www.ebay.com/itm/Maximizer-Tu...aad841&vxp=mtr
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Apr 09 2011
    Philippines
    Looks like my custom made manifold.
    Except mine is Schedule 40 stainless steel.
    Also my wastegate is placed in the middle.
    1997 Audi A4 1.8T Quattro - Stroked to 2.0L, ABA crankshaft, 83mm Wiseco stroker pistons, Comp Turbo CT3-5556, AEM FIC6, 630cc injectors, VR6 Throttle Body, Schrick cams, Supertech valvetrain, IE intake manifold, Treadstone TR11 front mount intercooler, custom 3" stainless steel exhaust, Turbosmart 48mm Progate, Apexi AVCR EBC, Ringer Racing Stage 4 240mm full face clutch kit, Devil's Own Methanol Injection w/ 14 GPH Nozzle, 30 psi of boost.
    Aug 23 2011
    Erie
    Quote Originally Posted by mykeg6 View Post
    U have a pic? And why Schedule 40 stainless? J/W
    Apr 09 2011
    Philippines
    I wasn't able to take a pic without the turbo on top.
    Welder's here use sched40 stainless for toughness.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    looks like an f41 wastegate flange
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Dec 05 2007
    $400 is def worth the gamble.
    Aug 23 2011
    Erie
    I agree.
    Veteran Member Three Rings Audiguy1234's Avatar
    Aug 28 2011
    North Chicago
    I have a high temp ceramic coated Full Race manifold for 600 bucks if anyone is interested.
    Dec 05 2007
    Good deal!
    Nov 27 2010
    mass
    Quote Originally Posted by Audiguy1234 View Post
    Do you take discover? Lol
    Aug 28 2011
    North Chicago
    Haha yes I do.
    Nov 27 2010
    mass
    Ah fuck
    Feb 03 2014
    Hobart Indiana
    Anyone buy that manifold for a longitudinal motor ?
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Quote Originally Posted by ray4624 View Post
    Ah fuck
    Literally could not have put it any better haha
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Aug 23 2011
    Erie
    Quote Originally Posted by Jgarcia1910 View Post
    I would like to but funds are tight. U should buy n try!
    Feb 03 2014
    Hobart Indiana
    Getting a full race man
    Aug 23 2011
    Erie
    Thats sweet man what u goin to put on the top of it? And a t3?
    Feb 03 2014
    Hobart Indiana
    Yes t3 and a be s200
    Aug 23 2011
    Erie
    Do these specs sound like a durable set up for turbo tube headers?
    It would be sweet if someone already has this and post there results!
    Primaries Tube : 1.8"*ODFlange Thickness3/8"Runner Wall Thickness16 Gauge (1.5mm)T3 Turbo Flange4-bolt Wastegate FlangeSand blast polished 304 grade stainless steelHigh quality 304 stainless steelMandrel bend for a faster and smoother airflowCNC machined flanges with Dual-TIG welded durable constructionAccessories on photo are includedMaximizer backed lifetime warranty against manufacturer defects.
    Dec 05 2007
    Ok, had to do a little investigating. Seems Maximizer is the same company as OBX. And with that being said, don't waste your money.
    Oddly enough, OBX seems to be the rave over on the American muscle forum boards (Google it). Seems our cars like to pick and choose...like some women.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    I had a stainless tubular exhaust manifold and downpipe from OBX on my old s10 a few years ago. I was impressed by the quality of it and it held up good. I know a few others running their manifolds on built v8's and theyre holding up just fine.
    1998.5 A4 1.8TQM My Build
    Dec 05 2007
    I find it odd. Even higher quality units like full race still crack on our car. But other cars can run cheap stuff with no problem. Weird!
    Oct 21 2005
    y
    Atp clone ftw lol.
    Wouldn't bracing the turbo prevent cracking? Some bottom mount turbo guys, don't have any load on the manifold (headers > flex pipe > turbo). On a bottom mount 370z all the weight of the turbo is carried by a bracket on the transmission.
    Oct 30 2009
    Miami, FL
    Quote Originally Posted by ricekikr View Post
    Atp clone ftw lol.
    That's the key right there, tons of people run without a brace and then wonder why they keep cracking manifolds. The Chinese KKK-flange tubular manifold also has a brace between the turbo flange and part that bolts to the head, something like that might be a good idea to add to this one if you buy it.
    2018 S5 Coupe - stock for now
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Wouldn't work seeing the turbo flanges is way too close to the head, unless someone feels the need to run their turbo facing backwards instead of the correct way. So I guess everyone that said it was worth the gamble just lost $400. lol
    Feb 03 2014
    Hobart Indiana
    Lol nice mike
