Results 1 to 34 of 34
    Senior Member Three Rings NyRevenge's Avatar
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    What engine coolant do I need? (Best)
    I'm pulled over at the moment. Due to low coolant. What brand and spec do i need? B8 s4
    '12 Phantom B8 S4 - Magma Interior - Carbon Inlays - 19' Peelers - Nav - CF SC Badges - 35% Tints - HOEN Xenonmatch Fogs - RS4 Grille - US Mill Works Tow Plate - Roc Euro Intake - LED Kit - ECS Geomet Crossed Drilled/Slotted Front Rotors - Akebono Euro Ceramic Pads
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    Need help asap!!!
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    VW /Audi G12, or G12+
    Veteran Member Four Rings GrkA4's Avatar
    Jan 14 2005
    B8 S4, MkV R32, B6 A4 (gone)
    Newtown, PA
    B8 S4 Sprint Blue - UNITRONIC Stage 2+ & S-Tronic Flash, Roc-Euro Intake, Magnaflow Exhaust w/ non-resonated downpipes, Eurocode Sway Bars & AK, 034 Trans Mount
    MkV DBM R32 - VF Engineering Intake, Magnaflow Exhaust, HPA Dogbone Mount, Neuspeed RSB and End Links, H&R Springs, RNS-510
    CB Tuning
    Unitronic
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    Audi/Volkswagen coolant ++, its purple/pink
    Or just add some water.
    Might have bad waterpump or you got a hole in your secondary air exchanger
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    Where can I get this instore?
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    These are my choices.
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    Quote Originally Posted by ENVē View Post
    Anyway to check by looking at engine?
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    In vw. This it?
    Veteran Member Four Rings essfour's Avatar
    Dec 03 2010
    Boston
    Water. Seriously. Unless you are below freezing distilled water = coolant.
    2022 Daytona RS6
    2020 Alpine White X7 50i
    1987 E30 325ic 5spd
    2018 Tanzanite M3 ZCP - sold
    2013 Phantom Black RS5 w/ Alu Optic package - sold
    2011 S4 6MT Meteor Grey w/ Ti package - sold
    2008 A4 S_Line Avant 2.0T 6-speed - sold
    2006 A4 Sedan 6-speed - sold
    2001 A4 Sedan 5-speed - sold
    Aug 28 2014
    Quote Originally Posted by NyRevenge View Post
    In vw. This it?
    Yep, that's it. Not cheap though.
    2014 S4 - Moonlight Blue
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Stock g12 next time. It's never OTC. Add water but since you live in NY be careful, overnight temps are below freezing.
    G12 make sure you dilute with water 50/50
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Aug 28 2014
    Quote Originally Posted by essfour View Post
    Yes, but you want to keep the anti-freeze/water ratio the same. You dilute the g13 coolant.
    Aug 03 2014
    Queens
    Is it called g13 now? Well go for that lol.
    Previous
    Jul 21 2004
    South Florida
    G13 and G12 are both HOAT coolants. You can use any coolant compatible with HOAT type coolants. Use an "extended life" one. Peak, Prestone, pentosin etc.
    Mike
    2018 Audi S5
    Gone-
    Feb 25 2013
    MI
    I used pentafrost ++ from O'Reilly auto parts. Then mix 50/50 with distilled water.
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    Wait, was I suppose to dilute it? The tech said no need to dilute. Just add to top off.
    Feb 25 2013
    MI
    There are concentrated mixes and non-concentrated. Think of it like types of chicken soup lol. For concentrated mixes, you determine the freezing point by changing the relative mix to have more/less water.
    Senior Member Two Rings ahkim's Avatar
    Dec 23 2011
    lawn mower
    Minnesota
    I used pentofrost and did 50/50 with distilled water per the directions. See my build thread and I posted a photo of the bottle. Post #176.
    2010 Audi S4 | DSG | Prestige | Ibis | Sport Diff | B&O | AG M310 19" Black | 30% Tint | Bel Sti-r+| Alpine Rearview Cam | Stratmosphere Intake | LEDs
    Click Here for My Mod Thread
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    So woke this morning, empty again. I'm out of state at the moment. What are my options?
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Dealer if you're under warranty. You have a leak (says captain obvious LOL). Not something you want to travel a great distance with.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Feb 25 2013
    MI
    Do you have any protection for the small radiator in the front? Up until 2014, Audi put no protection on these and they've been known to get punctured by road debris. Like someone above said, temporary solution is distilled water, but it's pretty close to freezing outside right now, so be careful with that.
    Veteran Member Three Rings Chandler's Avatar
    Jun 07 2014
    Recycle Bin
    South East
    Like everyone else said, mix g12 with distilled water. You can get by with adding distilled water in a pinch. DO NOT MIX G12 with another coolant. You will need to flush your cooling system throughly before you change coolant types. If you don't, it will congeal.
    "People who think they know everything are a great annoyance to those of us who do."
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    G12, G12+ and G12++ have been replaced by G13.
    If you just need a little to top off water is fine.
    Pentosin, Vaico, and some other companies carry similar fluids, Pentafrost ++ for example is one such alternative. Just make sure they say G13 compatible.
    Established Member Two Rings Tasho3's Avatar
    Dec 16 2014
    MI
    You can always piss in it
    ____________________________________
    2011 Audi S4 (Current), 2010 Mercedes ML350 (Current), 2013 Yamaha R1 (Sold), 2008 Mercedes CLS550 Sport (Sold), 2006 Range Rover SC'd (Sold), 2005 Mercedes SLK55 AMG (Sold), 2008 Mercedes C300 4Matic (Sold), 2006 Mercedes S430 Sport (Sold), 2003 Audi A6 4.2 S - Line (Sold), 1998 Mercedes C43 AMG (Sold), 1990 Mercedes 300E (Sold)
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I thought we needed G12 ++, rather than G12 or G12+? I understand that G13 will replace all of them . But could you uses G12 or G12+ if you had some on hand? BTW I have G12 ++.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    They may not be the right choice for an Audi
    Jul 21 2004
    South Florida
    Quote Originally Posted by Dr GP View Post
    G12, g12+, g12 ++ and g13 are all backwards compatible. DO NOT USE G11. Commercially available HOAT coolants like posted above should be compatible but check the labels.
    Mike
    2018 Audi S5
    Gone-
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    Ok so update, drove it to the closest dealer, Danbury Audi in CT. Guy said that my DIY intercooler protector screen actually punctured the intercooler. So warranty won't cover it. Gonna cost me $750. seems like bs to me. Any advice?
    Aug 03 2014
    Queens
    Not understanding how the screen would cause a puncture.
    Might have to fork over regardless. Sucks.
    Previous
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    That sounds somewhat bogus. More likely a projectile of some sort from the road hit and damaged the intercooler. Can you see any bends in the cooling fins or determine where the leak is actually coming from? Many have installed the protective screens without issue, so unless you followed some unorthodox installation procedure (e.g., attaching it to the cooler with sheet metal screws), it shouldn't have caused a leak. How long have you had the protective screen installed?
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Jul 21 2004
    South Florida
    I would go there and inspect it. See if that is the case.
    The center supercharger radiator is $198
    https://www.fcpeuro.com/products/aud...vag-8k0145804f
    It doesnt look like they are completely ripping you off as much as I have seen other dealerships do. I'd guess you could get an independent to do the job for $500 or so.
    Mike
    2018 Audi S5
    Gone-
    Oct 29 2012
    2012 S4, 2013 Q5
    Long Island NY
    Going to pic it up now. I requested to save the old parts so I can inspect it myself. I'll post pics later tonight.
    Aug 03 2014
    Queens
    What happen to the pics lol
    Previous
