Originally Posted by
superswiss
That's not quite how I understand the mechanics involved here. Applying the brakes on the inner wheel subtracts torque from the inner wheel. The subtracted torque is instantly redirected to the other wheel through normal diff operation. That's what a diff does. Torque's not lost. There is certainly kinetic energy being converted to heat, but the torque is simply redirected through the diff to the outer wheel.
Not sure on your conclusion that torque is not lost. Torque is not lost to the axle shafts, but torque is lost to the road with a brake based LSD.
Remember, calculating torque at the road surface is a relationship between the force applied on a tire, and the friction of the ground to move the tire in relation to the ground. An open differential always splits torque evenly between both sides. When one side has a lower available torque to place on the ground before it slips (inside wheel, wet/ice on one side), the torque applied to both sides decreases by that amount. For instance in dry conditions going straight, each side gets 50/50. One side will not see more than 50%. If one side is on a wet/slippery surface where only 10% torque is available to put on the ground, both sides will see 10%, total 20% of the torque. When one side is on ice / 0%, both sides get 0% applied to the ground (traction side gets no torque).
If one wheel is on ice with a brake based LSD (ice is extreme version of taking a turn with throttle), the system will brake complete the side on ice stopping the spin, going from 0% to 50% on that axle, allowing the other 50% to go to the side with traction. Therefore, you only get 50% on the side not on ice, half the acceleration power.
Another example: If you are on a turn, where the inside wheel can only apply 20% of the traction available to the ground before losing traction, open diff car will only apply 20% on each side, total of 40%, before the inside tire starts spinning. If the system brakes the inside wheel, the brakes can add up to an additional 30% torque to the left axle, totaling 50% to that side, allowing the full 50% to be applied to the outside wheel. Therefore, your torque breakdown is: Inside Traction - 20%, Inside Brakes - 30%, Outside Traction - 50%, so total power to ground is 70%.
Torsen can do ratios of torque such as 5:1, allowing torque to be sent to the side with more traction up to a certain amount. That means that the inside/less traction tire can see as low as ~15% torque, causing the outer wheel to see 85%, totaling 100%. From what I read about the rear sport diff, in most conditions, it can essentially send all power to the side with more traction, so no torque split. It can send pretty much 100% to one side, maximizing available traction in any situation, and even overdriving the outer wheel, where the inside isn't even at a level where traction is an issue (perhaps causing traction to be an issue to the outside). That's why the rear comes out so nicely on a SD car.
From what I understand, this is why active/mechanical systems are better than the brake based systems. On the turn example, Open Diff would see 40% power to the ground, Brake Based would see 70%, and torsen/clutch/system based would see 100%.
