Results 1 to 39 of 39
    Feb 12 2008
    Michigan
    First world problems, choosing caliper paint color?
    B6S4 front brakes on the way, I want to paint them before I put them on but am having a hard time deciding what color to choose. I do like the red caliper look, but am afraid it will be too flashy for oem brakes?
    Thought about silver also, might have a clean new oem look to it?
    Black is boring
    Thoughts?
    Car is black wagon with gun metal colored 18" wheels, oz superleggera and ssr comp, both wheels are very open
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    I went silver with the S4 logo springs. Looked sweet at first but after a year it's looking tired and I wish I went red.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Feb 12 2008
    Michigan
    Can you post a picture?
    I think I'm leaning toward red, if I where to add white ring decals, what size fits?
    Found this source on eBay with various sizes
    http://pages.ebay.com/link/?nav=item...d=321443843092
    Those s4 logo springs are way $$$, might try to make my own
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    I vote bronze.
    Ed
    why say lot word when few word do trick.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I went with Bronze on my black Avant, I run USP wheels in the summer and gunmetal colored A6 wheels in the winter. Looks subtle but good on black IMO, especially considering stock/OEM brakes. I might scream "look at me" with red if I had some monstrous BBK filling up my wheels.
    Veteran Member Four Rings ZipMeUpJ's Avatar
    Nov 12 2012
    hologram R8
    boston
    I went with canary yellow on my b7 brakes (same caliper, shorter carrier). Run them behind either white or solver wheels. My car is amulett and it is sexy.
    Last year after going low
    Veteran Member Three Rings yb28's Avatar
    Mar 06 2013
    2017 B9 A4 2.0T Quattro DSG , 2017 Q5 2.0T Quattro TIP
    Toronto, ON
    im gunna try por15 and get them painted yellow with black decals :D
    2017 B9 A4 2.0T Quattro S Tronic | Daytona Gray | Xenon to LED Headlights Conversion | Custom Brembo 8 pot BBK |
    Build Thread
    2015 B8.5 A4 2.0T Tip Black
    2003 B6 A4 1.8T Tip DG
    Jul 18 2011
    Norway
    I did mine in Alu spray, put in some new seals and a sett of solid bushings.
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Yellow or Orange would look really good on a black car.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Feb 17 2004
    Liberty Hill, TX
    I matched body color, but you already said you didn't want black
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Senior Member Three Rings johnwiz's Avatar
    Sep 08 2012
    2021 RS5, 2004 Audi A4 USP
    Leesburg Va
    I went with red, I like the way it looks. Did the rears with G2 caliper paint. It has held up great and looks almost as good as the powder coated front ones.
    2021 Ascari Launch Edition RS5, BC Forged RZ 21 (20 x 10 ET 22); 2004 Audi USP, B&B Sport Exhaust, VMR Rims, Stoptech BBK, Motoza Hybrid K04 Tune, ER Sport FMIC, Frankenturbo F21.
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    I got yellow
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Established Member Two Rings Dan brown's Avatar
    Feb 04 2015
    Swansea
    Silver. Keep it fresh looking and hides brake dust better. I coat all my discs in super high temp manifold paint too. Pads cut through the paint after a few dabs of the brakes and makes them look brand spankers.
    Mar 05 2013
    CA
    Quote Originally Posted by Dan brown View Post
    Any prep-work like degreasing? I hear Wurth SBS is good for this as well.
    Feb 04 2015
    Swansea
    I used a power drill and wire brush to cut through any rust, dirt or grime first. If they are heavily soiled you can use some wheel cleaner acid followed by some hot water to rinse it. Let it dry then coat the entire disc. I also coat the callipers with it. So easy to do if you paint the lot. Anything you don't want dusted with paint can be masked. I haven't had any issues with it flaking with a pressure washer either. It dries pretty quick due to the type of paint and easy to touch up. I even blow the inside of the tail pipes with the stuff after cleaning them too. Makes a huge improvement on appearance.
    Sep 08 2012
    Leesburg Va
    The VMR rims that I have show quite a bit of the caliper, and on the silver car I like the red..
    The G2 paint comes with an aerosol brake cleaner that worded really well in cleaning off all of the crap before painting. It brushes on, but dries to a smooth hard finish. I did mine off the car as I was changing the brake lines as well, but it can be done on the car. The fronts are powder coated and the rears are done with G2.
    Another option for colors are some custom mix ones from G2, it's pricier at $99 a kit, but it would be something different. Maybe something like a Garnet Red, or Gray Metallic on a black car.
    http://www.g2usa.com/Merchant2/merchant.mvc?
    Senior Member Three Rings georgio3gr's Avatar
    Jul 14 2009
    Greece
    Verde ithaca metalic from lambo???
    Veteran Member Three Rings esimp2k's Avatar
    Jun 17 2009
    Maserati granturismo sport
    ^what color is your car? Looks "purple" on my phone.
    Feb 12 2008
    Michigan
    Quote Originally Posted by J_L View Post
    I like that, makes it look like a brand new caliper
    Feb 12 2008
    Michigan
    The g2 red matches brembo/stoptech red pretty close huh?
    Sep 08 2012
    Leesburg Va
    Quote Originally Posted by Fast4esT View Post
    I can't speak for the Brembo's, but it is really close to the red they use on the Stoptech. Unless they are right next to each other, you can't tell. And even when they are, it is very minor. I was pleased with the color match.
    I could probably crop the original pic to get a bit closer on one of the front and rear if you are interested.
    Feb 12 2008
    Michigan
    heres a pic of my car with the OZ, maybe black would look good, but im afraid of how the black would look over the texture of the caliper, might try to grind them smooth before painting.
    would silver look funny, mixing different shades of grey or metallic? hmm, wonder about bronze
    red could have a nice offset, would go with the tail lights and the subleties of the S line badge and red "OZ racing" on the center caps
    heres a pic of the SSRs on my old URS6 with big reds, they are getting refinished in April I hope, not the greatest pictures
    Sep 08 2012
    Leesburg Va
    Here is a closer shot (not the best quality, used my cheap point and shoot), but the G2 goes on very thick and hardens to a very smooth, shiny finish. Other than cleaning, I did nothing else to the rear calipers before painting. I probably sound like a sales rep, but I had tried spray paint on another car, and this stuff really works well.
    Feb 12 2008
    Michigan
    i do like this color a lot, a brand new rear caliper on the s6, i wish i would have clear coated them, looked so pretty for little guys
    big red behind the OZ, those are cool calipers, wish i would have kept them
    Feb 12 2008
    Michigan
    yeah those look great, did you use the brush that comes with the kit? how does that paint do with the texture of the metal caliper? red seems to mask it better than black does, black really shows it in the light, light reflections contrast dark paint and shadow.
    think 1 kit would paint s4 front calipers and stock rear calipers? not gonna bother with brackets, cant see them right?
    Sep 08 2012
    Leesburg Va
    Yep, I used the brush that comes with the kit.... it was just one of those cheap flux brushes. The brush marks disappear as it hardens. I only did the back with the brackets, and did multiple coats as I only had to do the back, but threw out a lot of it. So I think you can easily get both front and rear from a kit, and that's the way they advertise it. Even with the crummy pic, you can see it looks very similar to the powder coat finish, I think you'd be happy with their paint. Take a look at their site, you may find another color you like.
    Apr 07 2011
    Well, this turned into a brake whoring contest!
    Veteran Member Three Rings strtdrms's Avatar
    Apr 03 2012
    Noblesville, IN
    Silver FTW
    2003 A4 1.8T Avant 5MTQ My Progress Thread
    2003 A4 1.8T Avant TIP - Daily Driver
    Instagram: mr_avant
    Feb 12 2008
    Michigan
    whoring gives ideas!!
    Sep 08 2012
    Leesburg Va
    Well if you can't whore your brakes, what can you whore..
    Apr 07 2011
    Haha, was just stating the obvious. Nothing wrong with whoring!
    Jul 14 2009
    Greece
    Quote Originally Posted by esimp2k View Post
    It's a dolphin grey...
    Jun 17 2009
    ^thanks
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    plz keep whoring your caliper setups. i'll be powdering mine soon and love the ideas and pics. keep'm comin!
    Audi Club Bay Area
    Veteran Member Four Rings Pr1ce's Avatar
    Aug 11 2014
    13' prestige
    Kissimmee
    Any orange or bronze setups? I'm thinking of going that route.... Cmon lemme see
    Feb 27 2011
    Winnipeg
    I did black calipers on my B6 S4 front brakes with a silver anti rattle clip. My car is silver and I thought silver on silver was blah. I did however do silver on my black B5 which is the color I'd choose for a black car again. IMO unless you have flashy brakes theres no point painting them a color that really stands out drawing attention to your stock or stock looking brakes.
    Jul 18 2011
    Norway
    3 years of silver on salty roads
    Mar 05 2013
    CA
    Quote Originally Posted by strtdrms View Post
    Silver FTW
    That looks really good. What paint did you use?
    I'm thinking of going G2 silver on mine. The Pen-Ray brand brake cleaner that comes in the kit, works a lot better than other brands I've used (from general auto parts stores). I hear Wurth is good too.
    Should I spray some silver paint over the G2 as well? Any tips?
    J_L's alu spray calipers look great (what paint did you use?), but it appears they wore out after only 3 years...
    Speaking of brakes, what's everybodys preferred method of stopping noise?
    Mine squeal (especially when hot). I used CRC Brake Disc Quiet. Maybe I didn't lay it on thick enough?
    Should I remove the old stuff (wire wheel dremel) and make it like this?
    Jul 18 2011
    Norway
    That is way to mutch on the pads, 1/3 of that would do.
    I used Alu blast from VHT i think. Its still on there nice, its just debri and brakedust that is sticking on the surface. You are gonna get this with a calliper. either way.
    The lighter coulor, the moore it shows, a darker coulor visa versa..
