Results 1 to 19 of 19
    Jan 31 2015
    2003 Audi B6 3.0 Quattero
    Ohio
    6-Speed transmission problems (getting into gear)
    I went to leave for school today from my house. I let my car run for about a minute before putting it into gear. This is a 3.0, not sure if that matters or not just to let you guys know. So I put into reverse to back out no problem. Went to put it into 1st and it was extremely hard to get it into the gear. Same with second but not as much. But here's what gets me. I push in the clutch a first time, it's hard to get it into. I take it out of gear with the clutch still in position and then move it back to first with no problem. It does get better when the car warms up but the issue is still there. I haven't tried anything yet I just don't know what the issue is. Have any ideas? Thank you
    Jan 31 2015
    Ohio
    Also to note that there is no noise coming from the car when I put it into gear. Or when I depress the clutch
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Try changing the fluid.
    Jan 31 2015
    Ohio
    I've ALS noticed that when I hold the clutch down for about 2 seconds it's shifts fine. But when I depress the cluch and try to shift immediately it's a hard shift
    2003 A4 B6 Three 'O! 6 Speed Manual
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    sounds like you're low on fluid. possibly leak at the slave cylinder
    Jan 31 2015
    Ohio
    Any other ideas guys? I think I'm going to get my transmission fluid flushed
    Aug 27 2013
    Philly
    Sounds like a fluid issue, whether its a leaky slave or worn fluid. Since this just started happening, I'd say you may have issues with the slave leaking. Check your brake fluid and note its color/level. If its dark and low, its time for a flush and a slave replacement. If its clean and full, then the probably may just be with trans fluid, but thats unlikely I think. People have issues with the syncro for 1-2 and sometimes lose the ability to even use 1st gear.
    Are your shifts from 2-3, 3-4, 4-5, and 5-6 ok? Is it mainly getting in and our of 1st that causes the problem?
    Nov 02 2007
    SF Bay Area, CA
    if its not your a fluid or leakage issue, then your clutch pressure plate could be broken.
    Veteran Member Four Rings claudiovagkraft's Avatar
    Mar 10 2010
    B6 A4 Avant USP, Mk1 GTI 20V project, B3 Passat VR6 wagon, Mk2 VR6 RIP
    Toronto/Ontario/Canada
    I'm thinking worn linkage parts could be the issue, along with bad motor mounts. But I wouldn't rule out low transmission fluid or time for fluid flush either. Time to have it up on a hoist and take a look at a few things.
    Apr 07 2011
    Here's some info from the factory manual on figuring out what's wrong with your manual transmission.
    Click
    Jan 31 2015
    Ohio
    The shifts from 2-3-4-5-6 is fine.
    I'm really not sure what it is.
    Jan 31 2015
    Ohio
    When I bought the car is had a new pressure plate, clutch and flywheel.
    Apr 07 2011
    Did you look at the link I posted? Have you checked if you're leaking any fluid from the clutch slave cylinder or master cylinder. First order of business should be bleeding that slave cylinder which is pretty simple and just like bleeding brakes.
    Apr 07 2011
    Complaint
    Grinding noises when engaging one of the forward gears or reverse gear; gear lever sticking, does not move freely; gears cannot be selected or clutch mechanism is without function
    Fault description
    Air in system, clutch does not disengage fully.
    Fault rectification
    Bleed system; check system, top up with brake fluid.
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Worn synchro's, you need a tranmission rebuild or buy a used one and put that in, common problem on 01E's which is likely what you have.
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Aug 27 2013
    Philly
    Quote Originally Posted by Durability View Post
    Are you 100% sure about this? Plenty of new buyers get burned all the time from dealers and sellers saying uncheckable stuff like this.
    I personally believe this is a 1-2 synchro issue. Time to get used to second gear starts.
    Jan 31 2015
    Ohio
    Thank you so much. Every body is saying it's my syncos an I need a transmission rebuild. I've noticed if I put the car in third gear first then I proceed to first it's like butter. Also if I hold it down for 2 seconds it's fine. I've also noticed is that is I go slow with it, it moves right into place, if I go fast like I usually go it's like hitting a brick wall then it slowly works it's way in. Any comments?
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    synchro, or in a really rare case (only seen it on mine so far) this happens clicky and feels like a 1st synchro gone bad.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Nov 02 2007
    SF Bay Area, CA
    what clutch and flywheel was installed? basically if they installed and aftermarket flywheel and clutch assembly that does not have the appropriate measurements your clutch will never fully disengage easily. the OEM clutch has self adjusting fingers which compensate for a decrease in friction disk thickness over time. aftermarket non adjustable clutches at times do not use this in their clutches. additionally a few MM high difference in flywheel height can cause issues.
    i'd find out what clutch and flywheel package was installed. AFTER YOU BLEED THE CLUTCH HYDRAULIC SYSTEM
