Results 1 to 10 of 10
    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    spark plug tube gasket
    Hey guys and gals, I recently replaced my valve cover gaskets and because I was leaking oil into the spark plug tubes, but there is still a small leak under hard acceleration. Does this sound like a pcv issue or the other gasket that's further down in the tubes?
    Thanks
    Tyler
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    Established Member Two Rings IrishCreamPuff's Avatar
    Jul 23 2013
    C7 Z-06, '07 S6 (sold)
    United States
    Idk about the PCV issue, but I had to have my spark plug tubes replaced due to a leak as well.
    '12 BMW 535xi
    '07 Audi S6 (sold and forgotten)
    '15 Z-06
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Wait the whole tube?
    I may just put some RTV in there around the gasket area, maybe that'll stop it.
    2005 BMW K1200S
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    Are any of the gaskets on the coil packs bunched up? I recently took mine out and half of them have the gasket shove into one area where it melted or something and is stuck. Thinking about getting new ones.
    Anyways, after taking the head cover off its completely possible for oil to leak in there from the coil packs.
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Huh, not sure, I'll check and report back. I need coils and plugs soon according to the Maintnence schedule.
    2005 BMW K1200S
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Here is my report back. I shortly after making my previous post here applied RTV to the lower gasket rings in the tubes, as well as where the coil pack seals. No more leaks on the driver side! Yay! But now the passenger side is leaking. The rearmost coil on the passsenger side had at least an inch and a half of oil on it. So I RTVed that side, and hopefully the leak will be fixed over there now as well. I think the oil damaged my cyl 6 coil pack or plug though, as I have a miss under hard acceleration on cyl 6, even though there is no more oil over there. I ordered a new coil and plug, we'll see if that resolves the issue. Hopefully this info helps someone else as well.
    Tyler
    Here's some pictures too:
    The oily coils and plugs
    oil in the tubes, I cleaned out most of what I could.
    [img=http://s28.postimg.org/6qeb1ejrd/DSC_1486.jpg]
    This is the RTV I used.
    [img=http://s24.postimg.org/d5lolw0hd/DSC_1488.jpg]
    And hood up picture just because.
    2005 BMW K1200S
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Quote Originally Posted by skylinrcr01 View Post
    Tyler
    Anyway you can explain how you did this in a bit more detail? I took have a leak on the driver side that is coming from the gasket below the valve cover gasket. I already replaced the valve cover ones (both) but the leaking is still happening.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    First let your car cool. Then, take some degreaser and clean the lower part of the leaky tube. Now wipe the inside down with rubbing alcohol to get all of the solvent off, then put on a later glove and put high temp rtv on the end of your index finger and apply it into the leaky gasket. Wait at minimum a couple hours for it to set, then button everything back up.
    Aug 06 2016
    AZ
    What motor do you have? i have 5.2 and they want 5k just to drop the motor to get access to the "cam girdles" to repair my leaks.
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    I had the 3.2
    2005 BMW K1200S
