Results 1 to 40 of 48
    Mar 15 2015
    Norway
    DIY: RNS-E retrofit & double DIN conversion (picture heavy)
    DIY: Replace single DIN Concert II headunit with double DIN RNS-E Navigation system.
    Heads up from a new member from Norway!
    I have been reading a lot on Audizine since I got my first B6 last year, and want to thank all the members for sharing so much useful information.
    This spring I decided to do the RNS-E retrofit. I know there's already DIY's on this topic, but I wanted to make a step-by-step guide with detailed pictures, for people tempted to go down this route.
    I'm posting this first on Audizine to get some feedback. Let me know what you think!
    Disclaimer: I am not a mechanic, and will not take responsibility for anything that may be damaged or broken while using this DIY on your own vehicle. This DIY is intended as an aid only.
    Table of contents
    - Prerequisites (post #1)
    - Removal of the center console (post #1)
    - Modifying the center console (post #2)
    - Modifying the climate control unit (post #2)
    - Installing the double DIN cage (post #3)
    - RNS-E installation (post #3)
    Prerequisites
    Single DIN → double DIN
    • Double DIN radio cage
      8E0 858 005 C (B6, aluminum) or 8E0 858 005 F (B7, plastic)
    • Climate control
      8E0 820 043 BM (B7 model, facia color to match RNS-E)
    RNS-E retrofit
    • RNS-E navigation unit
      8E0 035 192 D (A4 B7 face plate)
    • Quadlock adapter, GPS antenna, Fakra adapter
      Ebay, Kufatec etc.
    Tools
    • Audi radio removal keys (x4)
    • 8mm & 13mm socket, Torx T20 & T10, hacksaw ++
    • Flat headed & Philips screw driver
    Removal of center console
    Use the radio removal keys. Insert as shown.
    Pull straight out.
    Remove connectors. The yellow plug is a fakra connector.
    It might be a good idea to protect your gear knob.
    Remove old climate control unit. It pulls straight out.
    Remove all connectors from the back of the panel.
    Remove the trim surrounding the gear knob. It has 4 clips, 1 at each corner. Pull straight up.
    Push to release cover beneath e-brake lever. Remove 2x Philips screws
    Remove 8mm bolts securing ashtray. Disconnect the power to the LED illumination.
    Remove the cover in front of the ashtray to remove the assembly. It reveals two hidden 8mm bolts.
    Remove followings bolts: 2x 8mm bolts below the ashtray assembly. 2x 8mm bolts below gear knob trim. 2x 8mm bolts all the way to the front of the center console (1 on each side).
    Remove 4x 8mm bolts securing the center console and radio cage (2 shown in this picture)
    Pull out e-brake lever handle. There is a little clip on the handle part that needs to be pushed upwards, in order for it to release. You can then remove the e-brake lever sleeve behind it.
    Remove ashtray from rear seats to reveal the bolts securing the armrest and center console. The ashtray pulls straight out.
    Use a universal joint to access the 13mm bolt securing the armrest. There are two more 13mm bolts securing rear part of center console.
    Lift the center console up and backwards to remove it. Be careful not to scratch the painting on the ESP-button, card tray and cup holder.
    The cup holder and card tray has a clip in each corner, securing it in place. Push these down, and use your other hand from behind to push it out. Unplug the connector to the LED.
    The hazard button pulls straight out. Remove the single DIN cage. It is secured at the bottom pivot point by two T20 Torx screws.
    Continued in post #2
    Mar 15 2015
    Norway
    There is a difference on single DIN and double DIN center consoles. Luckily, the single DIN can be modified to accept the double DIN cage. This process involves some cutting. Use a hacksaw for this procedure.
    This is the piece that needs to be removed. It measures 40 mm x 85 mm.
    This flap also needs to be removed.
    Test fitting the double DIN cage. Perfect fit.
    This piece also needs to be cut in order to fit the double DIN setup.
    Use your hacksaw to cut a straight line just after the clips. There is a groove that works perfectly as a cutting guide.
    How the finished part should look like.
    The double DIN climate control unit came off a B7, which has a slight difference in the electrics. Instead of having a built in relay for the rear heated window, it sends only a trigger signal to an external relay located somewhere else in the vehicle. It is possible to make the B7 unit work on a B6, but it requires wiring in a relay. Some users have reported that the B7 panel is throwing fault codes on illumination (it stays lit at maximum brightness). I did not bother to experiment with the B7 panel, so I decided to swap the face plates and use my old climate control instead.
    Use a Torx driver to remove 6x screws from the back of your old climate control unit. Unclip a total of 7 clips securing the faceplate to the unit.
    Remove a total of 8 screws securing the button/LCD board to the faceplate. They are easy to spot.
    Remove the two clips securing the dials for heated seats.
    Now do the same to the other unit and swap the face plate.
    Continued in post #3
    Mar 15 2015
    Norway
    Put it into place and fasten the two Torx screws on the lower pivot point.
    Install the ESP and hazard switch, card tray and cup holder.
    Now is a perfect opportunity to replace those old peeling interior pieces with ones from a B7!
    Reinstall the center console. Remember to reconnect the 12V outlet.
    Reinstall ashtray (remember LED connector) before installing the modified piece in front of it.
    This is how it should look like now.
    This connector will not be in use anymore. It was connected to a LED on the single DIN cage to illuminate the space in front of the ashtray. Tuck it away.
    Center console reinstalled and climate control fitted.
    RNS-E installation
    The installation of the RNS-E is pretty straight forward once the double DIN cage is in place. For cars not factory equipped with navigation, one needs to install a GPS antenna. The following pictures will aid in this installation, and shows all of the connectors to the RNS-E unit.
    Use your key to remove the side panel on the driver’s side.
    Remove the 8mm bolt to the right in the picture. Here you can also se the preferred location for the GPS antenna, on the metal square just above the fuse panel.
    Remove 1x 8mm bolt located near the bonnet release lever. Remove the last 8mm bolt located near the accelerator pedal.
    The kick panel is clipped into place along the upper edge. Once the 3x screws are removed, pull towards the driver’s seat, and it will come loose.
    Showing the localization of the GPS antenna. Guide the antenna cable over the steering column towards the center console. The GPS antenna has a magnetic base, but I also added double-sided adhesive to secure it firmly.
    Make sure the kick panel clips into place behind the brake pedal. There’s also a clip above the foot rest panel.
    Connect the Quadlock adapter.
    Connect the adapter to the old antenna cable and the yellow Fakra.
    Connect all wiring to the RNS-E unit. Push it into place, but not all the way in. You need to make sure that everything works, and that the wiring behind is tucked safely away.
    PIN entry screen. The radio code (PIN) can be retrived using i.e. ebay-sellers. Just send your serial# - and you will get your PIN emailed ($12). I still need to code my unit for my car to accept it. This can be done via VCDS (w/ license).
    Sit back and enjoy the looks of your newly installed RNS-E unit!
    Let me know your thoughts on this
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Wouldn't it just be easier to just buy the proper console?
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Jan 09 2012
    MA
    Excellent DIY.
    Would have been a good time to swap in a B7 console.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by A4QuattroV6 View Post
    yeah, but this is free and looks the same.
    - Clint
    Mar 15 2015
    Norway
    $$$, and expensive shipping!
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    Wow. Excellent DIY, nice job.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    Mar 15 2015
    Norway
    Got my PIN and fired it up. Very pleased so far, sounds far better than my Concert II, and radio reception is also way better.
    Mar 15 2015
    Norway
    Installed an Mk2 unit today =)
    It seems like the Mk2 units don't suffer the red DIS bug as the Mk1 does. Anyone else experienced this?
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Quote Originally Posted by maccalo View Post
    What part number is the MK2 unit you got there?
    Mar 15 2015
    Norway
    Quote Originally Posted by lyates1987 View Post
    8J0 035 193 - from TTS
    Sep 17 2014
    Lakeway
    Tanks! No suffix?
    Established Member Two Rings renold458's Avatar
    Nov 25 2015
    2002 Audi A4 1.8T Quattro
    East Providence, RI
    Don't judge my stupidity but is there an AUX connection on these or a method of connecting to my phone/iPod for music? Or will I have to go aftermarket? I already have an aftermarket single DIN unit in my car but its atrocious looking.
    Mar 15 2015
    Norway
    Tanks! No suffix?
    No suffix on this one (MY2009).
    Yes you can add AUX to the RNS-E. Just need the wiring and some coding. You can also replace the CD changer with an A2DP module for wireless streaming (no track info, but play control via HU).
    The Mk2 also has AMI support.
    Nov 25 2015
    East Providence, RI
    Beautiful thank you!
    Mar 15 2015
    Norway
    AMI added to the setup. 8P0 035 785 unit.
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    Isn't the AMI suppose to be for 2010+ RNS-E models?
    -Alex-
    07 A4 2.0 TFSI Quattro,Rebuilt engine, BPG pistons, S-Line interior, S-Line suspension, S4 brakes, RNS-E & Bose
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    Nice work! I’ll be doing this exact same thing this Sunday as my single din unit threw in the towel. Already have a B7 console installed. I’ve to see what I am up against.
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by Van Black View Post
    from the picture, one can tell it's a 2nd-gen unit from the 'media' button; 1st-gen units have 'CD/SD' (NA) or 'CD/TV' (RoW). Also, the display is clearly higher resolution than the 1st gen unit
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Sep 07 2015
    Romania
    are 2nd gen plug and ply in 1st gen harness? I would go for the AMI interface for the HDD addition possibility
    -Alex-
    Feb 17 2004
    Liberty Hill, TX
    same harness, connections, etc for both
    Oct 01 2015
    Newmarket, Ontario - Canada
    These RSN-e units are highly over rated and over priced, not worth the work IMO. I bought one for my car and I'm very unimpressed
    Jun 05 2013
    Ottawa
    Went to do this and completely dropped the ball on needing a 'normal' climate control... Its now just hanging out pretty much in contact with my shifter until the used unit arrives. And I dont have the radio code I thought I had...
    Overall pretty smooth.
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Jun 05 2013
    Ottawa
    Quote Originally Posted by vwdann0 View Post
    I guess it depends on what you are looking for. You can definitely get way more features from an aftermarket units for similar pricing. The RNS-E MK I is a dinosaur in technology sense, and the MKII isnt that far ahead either. But nothing fits the interior better. And to me, thats worth more than having google maps, better bluetooth capabilities and video, etc. I might try the raspberry pi route eventually, but for now the RNS-E gets the job done.
    2007 RS4 Avant
    Oct 01 2015
    Quote Originally Posted by Gosser View Post
    I agree it does flow with the interior nicely
    Established Member Two Rings marto7's Avatar
    May 06 2017
    Sofia
    Hello guys.Im doing my retrofit and bought all the stuff in the first post but i have a problems with rear windows heater.My car is B7 and i bought climate control that mentioned in the first post with exact same number- 8E0 820 043 BM but it is from B6 not from B7.Only rear windows heating is not working.The others stuffs is working.When i push the button the light turn on and instantly turn off.Do i need to do some adaptation with VCDS or something else ? I know B7 climate control to B6 isnt working but i thinked B6 to B7 will work.And the number is same - 8E0 820 043 BM
    Thanks
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by marto7 View Post
    Thanks
    late B6/B7 HVAC uses a relay, early B6 does not. The model # you posted is listed as a B7 A4/S4/RS4 part, and your symptoms are the same as when I installed a B7 HVAC in my B6, so I'd assume it needs the relay. You can use my writeup as a reference on the differences between the two: http://www.audizine.com/forum/showth...-in-early-B6-s
    Jun 05 2013
    Ottawa
    No you need a B7 specific HVAC heater. You can reuse your old one, and swap the face plate. Interesting to hear the B7 came with a single din option. That is news to me.
    2007 RS4 Avant
    May 06 2017
    Sofia
    My B7 was Single din yes.But original i dont have heated seats.So i need the heated seat option of the double din Climate control.Im doing recaros retrofit too
    May 06 2017
    Sofia
    Nobody have a solution ? In my car on the rear of the hvac on the right one socket i have Only 1 cable - Brown.I dont have the white/lilac cable like B6.
    I checked the rear of the new clicame control.Its from B7.Its made in Germany - 12.07.2006 so its only B7 unit and supposed to run without problems.What im supposed to do ?
    Oct 27 2017
    Örnsköldsvik
    Frame on rns-e
    Hi
    How did you get the rns-e unit to fit if it came from a tts? Did you swap the frame surrounding it?
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by moggeen View Post
    Hi
    yes, if you use a TT or A3 unit, the faceplate must be swapped
    Oct 30 2018
    Surrey
    This is a fantastic thread and helped me a lot doing this conversion so thank you - One word of warning. I haev a B6 Cab and the cage for the Cab is different from the standard cage! the part number for the Cab cage is 8H0858005A.
    I just found this out the hard way ;0(
    I used an Android head unit, now to do battle with the rear speakers grrr...
    Junior Member Two Rings
    May 24 2012
    Tirana, Albania
    Hello i got rns e but im concerned about the antenna signal
    Concert radio antenna have different plugs. I see that i need an adapter but cant find any online
    Sent from my SM-G925F using Tapatalk
    Mar 26 2019
    Israel
    Done! Thank you so much 😊
    Table of contents
    Prerequisites
    • Climate control
    RNS-E retrofit
      Ebay, Kufatec etc.
    Tools
    Pull straight out.
    Just followed your instructions and done it in my humble 1.8t b6. You sir are the man!
    Junior Member One Ring Lounatic's Avatar
    Jun 17 2019
    EZ30D Turbo Swapped Blobeye
    Cairo ,Egypt
    reviving an old thread , i am doing this in my B7 it came originally with the single concert as yours .i have the cage and the adapter but haven't bought the climate control unit yet. is it possible to make my single din climate control unit work with the swap ?
    | 05.5 B7 A4 1.8T | ST Coilovers | MTM Stage 2 | Magnaflow Exhaust | Mishimoto FMIC | S5 Brakes |
    IG: @lounatic.b7
    Junior Member Two Rings Matteo Santucci's Avatar
    Jul 12 2017
    Burnaby bc
    I’m planning on doing this swap but where could I find those adapters and such? Also I’m assuming I cannot use my single din climate control?
    Veteran Member Three Rings Lauri0112's Avatar
    Jan 29 2015
    Estonia
    Quote Originally Posted by racing.dream View Post
    You can. But you have to trim down the edges. And it would look awful.
    Jul 12 2017
    Burnaby bc
    Quote Originally Posted by Lauri0112 View Post
    Ah I see so I guess swapping the face plate would be better or just replace the whole thing
