Results 1 to 24 of 24
    Apr 16 2010
    BC
    How's my oil level
    Is this normal for new car before first oil change? Here's the oil level at 8200 KM (about 5100 miles) 80% highway driven.
    Senior Member Two Rings IceSilverS4's Avatar
    Jan 06 2014
    2012 Audi S4, 2013 Tiguan R-Line
    Blainville, QC, Canada
    Mine gets to the middle or slightly lower at the time of the oil change (i change it around 10000km or 6000 miles). The car has 65000km or 40000 miles.
    Sold - 2012 Audi S4 - Ice Silver - Magma Red
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Mine looks like that after 700 miles (101k). If you bring it up at the dealer they will just claim its within spec. And typically engines burn a little bit of oil in the first 1000 miles as the rings seal
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings RickFLS4's Avatar
    Sep 21 2012
    2012 Audi Q5
    Palm Beach County, FL
    It is due for its first oil change (5K miles). Otherwise ok.
    2015 BMW M4
    Past: 2013 S4, 2011 A6 3.0T (accident victim), 2008 Lexus LS-460, 1998 Lexus GS-300, 1994 Lexus ES-300, various GM/Ford/Chrysler cars prior to 1994
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    buy a dipstick, it is more accurate and easier to use.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Mar 22 2014
    Sarnia Ontario Canada
    Can anyone explain how the measuring system works?
    2010 s4 Stage 2 tune w/pulley. (93 octane in use)
    2001 e39 M5
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by Intrepid One View Post
    Poorly. Get a dipstick!
    Sep 21 2012
    2012 Audi Q5
    Anywhere between max and min is ok. When it gets near min it is time to start thinking about adding oil. Not sure if that's what you mean of it if you are asking how the display works mechanically / digitally.
    I believe the oil level should be checked (obviously not on inclined road / driveway) when engine is up to operating temp (i.e. Not when cold) and if I recall the manual indicates consumption may be higher before first oil change.
    2015 BMW M4
    Veteran Member Four Rings theedge111's Avatar
    Apr 15 2009
    Calgary
    The MMI checks the top liter of oil.
    The vehicle needs to be at operating temperature and parked on a level surface, shut it off for 2 minutes. Read oil level on MMI.
    After an oil change you need to drive a minimum of 500kms for the system to reset.
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    which is kind of counter intuitive because in a typical car with a dipstick or even an audi with the dipstick added, you will want to check oil on a car that has not been running, on a level surface, to get an accurate reading making sure all of the oil is in the crankcase when looking at the dipstick...
    obviously you can check your oil a car that has been running ie at the gas station on the road etc, but the dipstick reading will be lower because the oil is distributed more evenly throughout the entire engine since it was running recently.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Mar 22 2014
    Soory,i really did not explain myself very well..What I was wondering was how it actually functions..Is there a sensor in the pan, is it temperature based?…Thanks for the answers guys..S
    2001 e39 M5
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by Johnnycash View Post
    You can check the oil when it is hot or cold. As long as you give the hot oil some time to drain back into the pan. Usually hot oil will read a little higher due to expansion. Either way there should not be a great deal of difference.
    Aug 22 2014
    bloomfield,ct
    I always was taught you check oil with a dipstick after the car has been cooled down. I usually check first thing in the morning before I start my car, doing it that way for 40 years
    Mar 22 2014
    Quote Originally Posted by jygesq View Post
    Couldn't agree with you more. My daddy taught me how to check the oil way before he would let me drive…It only got screwed up when the wizards started with the no dipstick crap..Obviously a money saving deal…S
    2001 e39 M5
    Jun 08 2005
    Lexus RX 350
    SE, PA
    BMW 3 series has it so the B6 Audis copy cat the idea. Thing is that with the BMW, you check the oil level while the car is running and there is no easy way to retrofit a diptick.
    Feb 06 2015
    I couldn't agree more my wife BMW 330i has no dipstick super annoying but oh well.
    19’ Audi RS5 SB H&R VTF Has Kit|034 Motorsport|ECS Tuning
    Aug 22 2014
    bloomfield,ct
    You would. Think the electronic system cost more, maybe audii thinks owners are morons and can't get hands dirty or can't be bothered unless it it electronic. Fortunely they left dip stick tube in place so you can buy and use a real dipstick. Probably would have caused major engineering change in manufacturing to eliminate tube, so they just capped it. Good for us old timer purist.
    Established Member Two Rings WeeKenny's Avatar
    Jan 05 2015
    Scotland
    Due to customer reactions and the number of dipsticks sold Audi say the B9 will have one again. Time to wait and see I guess.
    Active Member Two Rings cookinsolo's Avatar
    Jun 25 2013
    2014 audi R8 v10, 2015 audi TTRS
    san antonio
    1:40 am
    Jun 28 2012
    North NJ
    While we're on the subject of oil levels. 2 days ago while driving, the info screen in between the tach and speedometer displayed the oil level and said "Oil level is ok" or something along that line. I'd never seen that prompt before in my almost 3 years of ownership and 24k miles. I was cruising steadily at around 75 mph while commuting and had been at that speed probably for 30 minutes or longer when the message flashed. Is that displayed from time to time and I've just never noticed it? I check my oil regularly through the MMI and dipstick. Once I had the add oil message but I've never heard of one randomly telling me that the oil level is fine. Anyone else?
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
    Apr 15 2009
    Calgary
    Quote Originally Posted by Schadenfreude View Post
    Exact same thing happened to me on my old B8 , it was a faulty hood latch.
    http://www.audizine.com/forum/showth...Oil-Level-Okay
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    looks like its self explanatory to me i dunno. Maybe their is another meaning for OK.
    Apr 15 2009
    Calgary
    Quote Originally Posted by chaos2984 View Post
    Your right, you don't know or seem to understand...
    The question is not what does okay mean...it's why does the message pop up on your DIS.
    If you open your hood while the car is running it appears. If it appears when you are driving on a highway it could be a faulty hood latch like it was for me and a few others.
    Jun 28 2012
    North NJ
    Quote Originally Posted by theedge111 View Post
    Thanks. I never saw that thread. I have my 25k service in a few weeks so I'll mention it at the time and will keep an eye on the display to see if it happens again on a bumpy road.
