Results 1 to 28 of 28
    Aug 19 2009
    Colorado
    Auto Transmission won't shift or go into park, grinding noise in drive
    Tried searching for this problem, either no one has had this problem or i suck at the search function.
    Today I was driving, took off from a stop and then a couple seconds later i lost all connection to my drivetrain kind of like if the TQ failed. It just revved and I wasn't moving anymore. So i pulled over to the side of the road.
    I put the car into park and the car started rolling back ( i was on a hill ). I could faintly hear the parking pin clicking as it was rolling. So i pulled the e brake up and put in Reverse, again no connection to the wheels, but there was a grinding and whining noise coming from the transmission or something. Then i shifted into Neutral and it was silent, then i shifted into Drive and again the grinding and whining noise came back, I can rev it while in Drive and reverse and the car doesn't move. So i put it back in park (even though Park wouldn't work), pulled the e brake up and got it towed to my work. (I work at a toyota dealership, I have a VCDS).
    Is there anything common that i should look at first? I have a 2005.5 Audi A4 B7 Tiptronic Quattro. 125k miles. Anything I should be looking for in the VCDS. Also I do not have a Check engine light. My bluetooth APR Dongle showed no fault codes as of now.
    Any help would be appreciated.
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    When was the trans oil changed?
    Aug 19 2009
    Colorado
    i did a drain and fill about 10k miles ago.
    Genuine Audi ATF
    Are there some type of shift solenoids i can test or something. It seems to me that it tries to shift or something and does not fully engage.
    Mar 10 2010
    WI
    You're going to have to get it hooked up n check for any codes. I am unaware of any test procedures with vcds. There's a chance it could be the gear shifter. Just curious, how many qts of oil where you able to put in the trans?
    Established Member Two Rings A4SANDBEER's Avatar
    Sep 24 2014
    2006 325i. I miss my s14
    LOS ANGELES
    your PRNDS isnt flashing on your dash correct ?
    stayXXsoul
    @3Soul_
    Senior Member Three Rings vtwinjunkie's Avatar
    Aug 10 2013
    Various motorcycles
    NOVA
    Interesting, If it was FWD I would say you broke an axle.
    What was the trans maintenance history like besides your drain and fill? Not sure what the parking pawl has to do with the shifting but its interesting that they seem related.
    Sorry I cant be of more help just talking aloud to spark thought!
    Deactivated Four Rings
    Aug 30 2013
    2014 Toyota Highlander Limited, 1999 Mercury Grand Marquis GS-HPP
    Panama City Beach, FL
    Quote Originally Posted by vtwinjunkie View Post
    If its a FWD you prob broke an axle.
    FWD or Quattro?
    It's in his original post - Quattro tip.
    Aug 10 2013
    Various motorcycles
    NOVA
    Quote Originally Posted by kegobeer View Post
    Damn. You were quick with a response lol. I realized that and edited like seconds after my post.
    Aug 30 2013
    I sensed a disturbance in the force, that's why I was so quick. hahaha.
    Aug 19 2009
    Colorado
    PRNDS is not flashing. Works like normal. What would the flashing indicate? I will be checking on the car tomorrow again. It's possible I didn't see it flashing?
    Aug 19 2009
    Colorado
    Quote Originally Posted by JayDog747 View Post
    When I did the drain and fill it was 8qts I believe. I bought the kit from ecs. So it wasn't a complete flush, couldn't drain the TQ.
    Aug 19 2009
    Colorado
    No other transmission history. I purchased the car at 90k miles and did the transmission drain and fill at 110k miles or so. I don't understand the parking prawl having any relation to the problem either but it definitely does not engage into park.
    Active Member Two Rings Mindstorm20's Avatar
    Dec 06 2013
    Arlington, Texas
    I would look to make sure all of the axles are seated properly.
    Aug 19 2009
    Colorado
    Quote Originally Posted by Mindstorm20 View Post
    will do, forgot to mention I did take off the front passenger axle to reboot the outer joint. I'll check that out for sure when I get the car on the rack tomorrow
    Also i hit a huge pothole last night. If the axle were to break, or cv were to fall apart. that can affect the parking prawl right? also maybe its sending the power to the broken axle because of the quattro? ill touch base tomorrow.
    Apr 07 2011
    Quote Originally Posted by hankooks2k View Post
    The PRNDS doesn't necessarily have to be flashing. If the letters are highlighted or flashing then there are codes stored in the transmission control module. It's the equivalent of a check engine light for your engine, instead it is a check transmission light for your transmission and there are fault codes stored in the computer. If that was the case then you need to have your transmission module scanned to see what codes were stored.
    Feb 24 2004
    Minneapolis
    You get these symptoms with a Quattro when an axel is broken too. Ask how I know? I was sure my tranny was hosed on my dear departed B5 until I got under and grabbed the axles. I could turn one axle by hand with the car sitting still. And my symptoms were exactly as described in the first post. All the power goes to the broken axle, and it makes some noise as the broken CV joint spins around.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Aug 10 2013
    Various motorcycles
    NOVA
    LOLZ
    Aug 10 2013
    Various motorcycles
    NOVA
    Quote Originally Posted by mtroxel View Post
    Oh ok then I would def check the axle! that would explain the park pawl as well.
    Feb 24 2004
    Minneapolis
    ...that would explain the park pawl as well.
    Yea it does. It sure sounds like tranny but a broken CV joint sounds a lot like a broken P pawl. Check all four. As I understand it you can sometimes just see the CV boot all twisted up around the CV joint.
    Active Member One Ring Bavarianhd's Avatar
    Feb 19 2015
    SC
    Did you find a solution? my 06 AT quattro just did the exact same thing!! Its sitting in front of a transmission shop now waiting to be checked out monday morning. Id love to be able to tell em exactly what to look for and have a solid idea of what this should cost. hope you got your machine back up and running!
    Feb 24 2004
    Minneapolis
    Did you check the CV joints?
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Use your vcds and scan the transmission control module for fault codes, people he would have to break all 4 cv joints simultaneously for the car not move, even if he broke the rear driveshaft the car would still move as a fwd.
    OP I think your original guess is correct that the torque converter failed......or you suddenly lost all your trans fluid and destroyed it.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by o1turbo30v View Post
    Wong on both accounts. One broken CV joint and all the power goes to that axle. Had that happen personally last January on a B5. Same result with a broken drive shaft. Car won't move.
    Feb 19 2015
    SC
    what did it cost to repair?
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Bavarianhd View Post
    Mine was just $70 for a re-maned axle, and about 1 1/2 hours to change it.
    Feb 19 2015
    SC
    thank you. I guess we'll see what happens tomorrow!
    Feb 19 2015
    SC
    well its not any of my axles.. they say theyre going to have to dig into the trans and see if its the spinal drive.. 7-800 to fix that.. if not that than its a trans rebuild.
    Apr 02 2019
    Boston
    08 328xi
    Did you ever find out what was wrong with your Audi in this situation? I’m having the same exact problem with my 08 328xi. Please help
