Results 1 to 29 of 29
    Mar 26 2012
    Charlotte, NC
    Who changed the Timing Chain and Tensioner on the 2.0T Yet? ?
    http://www.audizine.com/forum/showth...ensioner-Study
    Guess what there is an updated Tensioner because the current one is a ticking time bomb lol
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Subbed. I have been curious about this as well.
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    i would pay a good shop to do it unless you have tools and skills. if you are above 80k miles you need to do it.
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    Good I got only 50k on mine but still I'm a bit worried now
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Jan 08 2013
    New Jersey
    I just confirmed with aoa some engines got a revised part... So I'm sure there is something wrong with ours.
    Edit :
    Also confirmed that audi don't call it "lifetime" and the service should be done at 110k miles.
    Veteran Member Four Rings Dub_prime's Avatar
    Sep 10 2012
    2010 A4, 2008 Passat, 2002 GTI
    Bham AL
    When my stage 2 was done at 76k the tech found my tensioner "out of parallel" to the chain and replaced it free of charge.
    Jan 08 2013
    New Jersey
    Quote Originally Posted by Dub_prime View Post
    Do u have part # maybe?
    Sep 10 2012
    Bham AL
    o6k 109 467 k
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Quote Originally Posted by oascom View Post
    My dealer also replaced mine along with the upper chain guide. Nothing wrong with mine, but the dealer is now replacing them as part of the stage 2 fix.
    06K-109-467-K
    2011 A4 Avant
    Jan 10 2012
    Republic of Boulder
    I'll be sure to get it done at 194k miles then.
    PREVIOUS:
    1991 Audi 200TQ Avant
    2001 Audi S4 Avant
    2009 Audi A4 Avant (click)
    2014 Audi allroad
    Jan 08 2013
    New Jersey
    Quote Originally Posted by jfo View Post
    06K-109-467-K
    I had stage 2 fix done September last year... Not sure maybe they changed mine too? But I don't see this part # on my invoice so I quess not..
    Checked my invoice they did change my upper guide chain rail
    06h-109-469-t
    http://www.europaparts.com/timing-ch...6h109469t.html
    Oct 27 2010
    Norwood, MA.
    How much could one expect to pay for such a service? $1k at a decent shop?
    2016 S3
    Nov 17 2010
    Quote Originally Posted by b6Hate4 View Post
    You're probably in the right range. The part is only about $60 and I would guesstimate 6-8 hr's labour?
    2011 A4 Avant
    Jan 08 2013
    New Jersey
    Senior Member Two Rings A4BGP's Avatar
    Oct 18 2005
    Dirt and Street bikes, '09 A4Q
    Moncton, NB
    I just dumped the part numbers in the 2.0T Engine Tech forum (http://www.audizine.com/forum/showth...ensioner-Study). Some part numbers might have been superseded by now.
    Just going to leave this here... OEM chains are between 150~200+ USD and the valves don't need to be removed for a chain service.
    Mar 26 2012
    Charlotte, NC
    I would change the Chain, Tensioner and guide.
    Sep 14 2006
    Glad I fell upon this thread.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Veteran Member Three Rings John4378's Avatar
    Mar 19 2009
    Houston, TX
    I'll double-check, but I don't believe the maintenance manuals call for it being serviced at any specific interval. Side note: My water pump is showing calcification - time to get that changed out too. I'm at 97k miles on 2009 A4.
    Dearly Departed - 2008 A4 Avant 6MT S-Line w/ APR Stage 2, 034 HFC
    2006 Lotus Elise
    2005 Ducati Monster S2R
    2006 Ducati Monster 695
    2009 A4 6MT S-line w/ APR chip, AWE exhaust, AWE FMIC, Eurocode HFC
    2011 Ford Explorer - Family Swagger Wagon.
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    We do a few every month - not as many as the 4.2's though! I've seen a few fail, but they were all VW (GTI) engines if I'm remembering correctly.
    Mar 19 2009
    Houston, TX
    Found a link to Audi's 2009 maintenance guide: http://www.audiusa.com/content/dam/a...-Year-2009.pdf
    In the notes at the bottom of the page, it mentions changing the timing chain on front-wheel drive 2.0L A4's at 110k miles. No mention of Quattro equipped A4's. ECS Tuning shows the same part numbers for the lower and upper chains for both Quattro and Front Track equipped cars.
    2006 Lotus Elise
    Nov 17 2010
    Quote Originally Posted by John4378 View Post
    That refers to a belt which it appears those models use, rather than a chain.
    2011 A4 Avant
    Senior Member Two Rings nerv81's Avatar
    Sep 09 2009
    New Jersey
    Did they mention if there was a specific year they started using the revised part?
    B8 S4 / APR Stage 2 single pulley / Short shifter / ROC Auto Intake / F&R sway bars
    Apr 25 2014
    Thanks SDF1 for posting here and A4BGP for the post in the other section and parts list.
    I'll probably do this come fall so I can use the storage unit to do the work over the course of the weekend before I store the MB for the winter.
    2009 Audi A4 P+ Stock 101k Quartz Gray Metallic
    1985 Mercedes-Benz 380SL Petrol Blue Green Metallic
    Previous: W108, 123, 124, 126 and 140 MBs - E28 BMWs - ZJ Jeep GC - Chrysler Crossfire/Lebaron/300M
    Mar 19 2009
    Houston, TX
    That's what I found interesting. Maintenance guide references timing belt. However, I checked ECS Tuning for both Front Track and Quattro equipped A4's and each time it directs you to a set of timing chains. FWIW, my mechanic recommended getting it done at about 100k miles. He has already replaced 3 timing chain sets on 2009 A4's this year - 2 preemptively, 1 after it snapped. That car needed a valve job too $$$. I'll get mine done in the next month or so now that I'm at 97,500 miles. Water pump is on its way out too, so might as well just suck it up.
    2006 Lotus Elise
    Nov 17 2010
    That reference is for the TT and Cabriolet models, not the A4. For mine(2011) it refers to the TTS and A3 TDI only.
    I'm not debating the pros/cons of changing the chain, just clarifying the published maintenance schedule. It's up to you of course, if you wish to change the chain at some point.
    2011 A4 Avant
    Mar 26 2012
    Charlotte, NC
    There are no cons on changing the chain. The chain and tensionner have an updated part because they have issues.
    If you own the car and you are getting any engine work done, i would do it without thinking. If it's a lease... then don't do it.
    How many KM do you have on it and how long are you keeping the car?
    By the way, you can call the dealer and with your VIN you can see if you have the updated chain and tensionner or not.
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Had my tensioner (06k-109-467-K) replaced with my stage 2 consumption fix in July of 2014. I don't see the rail part that @oascom mentioned earlier, though.
    They also apparently replaced the cam adjuster?
    Sent from my iPhone 6 using Tapatalk
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Three Rings S-Liner's Avatar
    Oct 21 2014
    Illinois
    06h-109-469-t
    Nov '14 Stage II performed, I did see the above mentioned PN replaced....no 06K-109-467-K, though.
    I wish I got a screen shot of my Carfax report, I remember a little blurp about the timing tensioner
    '10 A4 Avant Prestige Plus S-Line w/sport pkg
    My Oil consumption results..."Oil consumption measurement found to be using 3.26 quarts per 1000 miles"
    Mar 11 2013
    Toronto, ON, Canada
    Getting the tensioner changed. With labor and a few other parts it is 1000 at an Audi vw mechanic here in Toronto, I'm getting it done.
