Hi everyone
I recently had four new tires put on my 2002 A4. Within the next week, I ended up having two flat / leaking tires and a weird clicking popping sound when turning. I brought it to a different place closer by and they found a bead leak in the driver's side front tire and another type of leak in the passenger's side rear tire but didn't address the sound. It has since gotten worse, now it sounds like a louder grinding/crackling sound.
The issue only happens when turning and is most noticeable when turning sharply and slowly, like doing donuts very slowly. It also seems more noticeable when turning sharply upwards on a hill. I found a post that made seemed closest to describing this that said "Your CV joint has likely gone bad and should be replaced." (http://www.gobluedevil.com/blog/why-...teering-wheel/)
My question is, could this have been a result of shoddy mechanic work when putting on the tire, or is this totally unrelated to that? And does the CV joint sound like what it would be? I just had new power steering fluid added about a month before this.
