Results 1 to 19 of 19
    Senior Member Three Rings A4 Joe's Avatar
    Jan 31 2007
    Slight burning smell
    I have noticed a slight burning smell as I get out of the car in y garage. Have noticed this only a handful of times. Iirc I had this a few times on my 2012 S4 also. Any ideas on what this might be.??
    2019 S5 Sportback. Quantum Gray. Black Optics
    Veteran Member Four Rings Pilfer's Avatar
    Dec 13 2012
    To the Bay Area
    Could it be burning plastic? I noticed that awhile ago and traced it to a plastic bag that got caught on the downpipes after running over it on the freeway at speed.
    996
    Model Y
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Pop the hood and take a strong sniff. VW/Audi/Porsches are known to have a unique "burning" smell when their motors are hot.
    Veteran Member Three Rings bronz's Avatar
    Sep 21 2006
    Lyons, IL
    I notice that on my 11 after spirited driving
    2014 Audi S4 DSG
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    is the car new? I had this issues for the first 2K miles until the converters got broken in. Enough heat cycles
    Established Member Two Rings Mp0wer's Avatar
    Dec 21 2014
    Boston
    It's funny you mention this, I was rev lining mine through 1st 2nd 3rd and got a burning smell this morning, car has 1980 miles...she's got some pep
    2018 //S4 | Glacier White | Magma Red | 18" Double 5-Star Spoke
    2015 //S4 | Premium Plus | Ibis White | 6MT | Sport Diff | B&O | Tech Package | 19" Potato Peelers
    1995 ///M3 | Alpine White | H&R Coilovers | 18" AC Schnitzer | Vader Seats | Engine Mods
    Veteran Member Three Rings CaptSlow's Avatar
    Apr 18 2014
    NoVA
    I get it too when I rev above 5500 rpm. I've been told it's the exhaust getting hot. Not sure how it can smell right when you turn it on though
    Established Member Two Rings mdeneso's Avatar
    Sep 11 2014
    B8 S4 15 T-Reg 05 ZX10R
    I get the same thing every once and a while as well. Was starting to get a little worried but sounds somewhat common. Kind of smells like burning clutch. I have a dsg. Do you have dsg or manual?
    Veteran Member Four Rings BirdmanQ5's Avatar
    May 31 2012
    2017 Audi S3
    Toronto, ON
    2017 AUDI S3 | TECHNIK | DAYTONA GREY | BLACK OPTICS | SUPER SPORT SEATS | ADVANCED HANDLING | TECHNOLOGY PACKAGE | AWE SWITCHPATH 102MM | ED SPOILER | 034 SPRINGS + REAR SWAY | VORSTEINER VFF102 20x9 ET35 CARBON GRAPHITE | THINKWARE F770
    2016 AUDI S3, 2013 AUDI S4, 2011 AUDI Q5, 2010 AUDI A4, 2006 AUDI A4
    @IALEXSERBERT | @AUDI_TN | @SIXAUTO
    AUDITRUENORTH//
    WWW.SIXAUTOCONCIERGE.COM
    Veteran Member Three Rings zps123's Avatar
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    i get that smell too. mostly on highway ramps. it does smell like clutch though.. ive dsg
    2015 Audi SQ5
    Brilliant Black|BO|Black Nappa|B&O|NAV|KW HAS
    Past: '14 Audi S4 | '11 VW Tiguan
    May 31 2014
    Alabama
    I get it too every once in a while. I think it's more front brake dust/heat more than anything.
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
    Senior Member Three Rings acturater's Avatar
    Sep 17 2013
    philadelphia
    Quote Originally Posted by Mp0wer View Post
    This. The other day I accidentally downshifted while in 2nd gear sprinting off the line. I didn't over rev, but I did hit redline hard in 1st and smelled the burn for a few min.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Not sure if this could be the problem but I have noticed a continuous SLIGHT loss of coolant on all my 3 B8 S4s. Have not seen yet an explanation of where it goes and evaporation should not be a factor in a closed sysstem. Just wondering if slight coolant leakage could be the cause of the smell. If it was from the clutch, which I have experienced, the smell would be distictive. Not likely to happen is an DSG car?
    Senior Member Three Rings drevil2k2's Avatar
    Aug 29 2007
    GTA
    Quote Originally Posted by Dr GP View Post
    Three weeks ago, I had my coolant topped up at the dealership. A BMW tech said that most German cars (my old N55 335i) do consume coolant slightly and is expected. However, if the vehicle was Japanese, then it would be an issue. The coolant level was at the min mark but the system is pressurized and once the cap was off, the level increased slightly. After the top off, not much change in the coolant level despite noticing the slight burning smell about 2-3 times per week. Will monitor, but it there was anything major, it would be all over the garage floor.
    2019 S4 Technik Quantum Grey - black ops
    Past 2019 A4 Technik Daytona Grey - S line black
    Past 2014 S4 Technik Monsoon Grey
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by drevil2k2 View Post
    My coolant loss has been minimal but constant.
    Oct 02 2006
    Wadsworth,OH
    Could be a number of things.. Cats heating up, exhaust burning off residue, clutch, brakes.. Boosted engines tend to make exhaust parts HOT! So anything close to the headers/cats could produce a smell. Unless something is visibly smoking I wouldn't worry too much about it.
    Jason
    Aug 28 2014
    Where does our coolant go? I have no drips on my garage floor, no sweat smell of coolant vapors in the engine bay, no signs of a head gasket failure, but I slowly lose coolant in a closed system.
    2014 S4 - Moonlight Blue
    Sep 17 2013
    philadelphia
    Quote Originally Posted by vtbert3 View Post
    I believe it evaporates through the cap. I remember reading about it I think in the owners manual. If the coolant gets hot enough and enough pressure builds up within, the cap is designed to let it evaporate.
    Jan 31 2007
    As I mentioned had a similar deal on my 2012 S4. I noticed my thermostat went bad after I first and the smell. I guess there are others that have had this condition. Whatever the reason I don't like it.
