Results 1 to 16 of 16
    Apr 15 2014
    Ottawa/Gatineau Canada
    can someone please confirm the size of the big nut on the inner tie rod ?
    I have found posts saying 33mm and 38mm.
    Not the 18mm but...the BIG one the "ball joint" on the inner tie rod goes into.
    I want to buy the right wrench on the way home tomorrow as the biggest wrench I have is 24mm.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Aug 27 2013
    Philly
    Quote Originally Posted by Luxus Panzer View Post
    I used a large adjustable wrench on it. Im not sure what size it is. I know its big. I wanna saw larger than 24mm.
    Apr 07 2011
    I think I used an adjustable wrench when I did my tie rods too. If I remember correctly it broke loose rather easy. I mean it took some force but nothing extreme.
    Veteran Member Four Rings Pr1ce's Avatar
    Aug 11 2014
    13' prestige
    Kissimmee
    Thank you for the asnwers and the post as well Panzer. I was literally about to ask this over the weekend as i have a set in my cart ready to be shipped out. I went with the s4 tie rods...I made the right choice correct??
    Aug 27 2013
    Philly
    Quote Originally Posted by Pr1ce View Post
    Yup. S4 all day
    Apr 15 2014
    So no one knows the exact size?
    I would like a sized wrench over a adjustable wrench, but I will buy a adjustable wrench if I have to.
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Does that nut fit on any of these? Sorry for my confusion, working nights and am not thinking clearly. For what's it's worth I checked my tool box and the biggest socket I have purchased separately is a 32mm, not 100% sure if it's for what you need or some other odd job from the past.
    Daniel J
    @gtg_drives
    Apr 07 2011
    No he's going for the inner tie rod so a socket isn't going to work. He needs an open end wrench. OP you can also run by a local parts store and rent a tie rod kit that is specifically meant for doing tie rod jobs. You pay for the tool up front and get a full refund when you return it. This kit has 30, 34 and 36 so it's most likely one of those sizes.
    https://1stwebsales.com/inner-tie-ro...RzqRoCAuvw_wcB
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Ah, you are correct sir. When I did mine I rented the kit as well when I did my tie rods.
    Daniel J
    @gtg_drives
    Aug 27 2013
    Philly
    FWIW, I ran to Autozone and Advance Auto when doing my tie rods and neither had a tool for rent that was capable of doing what I needed.
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    I had to cut my tie rods in half with a sawzall to get the rented tool to work.
    Daniel J
    @gtg_drives
    Apr 07 2011
    SlickFix did this write up on tie rod replacement. Click It looks like to remove the outer tie rod he uses an 18mm box wrench and for the inner tie rod he uses the 38.4 adapter that comes in the kit. Thats the write up I followed when I did my outer tie rods. I could imagine finding a 38mm box wrench might get sort of expensive. I'd try and find the rental kit if possible. Maybe call around to a couple local parts stores.
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Just wanted to follow up as I found an old one spring cleaning. From my 2002 A4 w/sport suspension. OEM part from the factory.
    37mm
    Daniel J
    @gtg_drives
    Apr 15 2014
    Quote Originally Posted by 87supraman View Post
    37mm
    Thanks dude. I ended up using a large adjustable wrench like in your pic.
    Established Member Two Rings lowlife89's Avatar
    Jun 01 2013
    EU
    37mm
    Is there enough room to fit this big azz wrench?
    Aug 27 2013
    Philly
    Quote Originally Posted by lowlife89 View Post
    yup! just enough.
