Results 1 to 29 of 29
    Established Member Two Rings toast88's Avatar
    Mar 07 2012
    Parking Brake Malfunction Help
    So I parked my car Thursday night in my driveway, Friday morning when I went to go to work, the car would not disengage the parking brake and the warning came up parking brake malfunction. Thought maybe it was the cold weather, but it has warmed up today and it is still stuck. I was wondering if there is some way to manually disengage the parking brake, last thing I want to do is get it towed. I did a bit of searching around online but couldn't really find anything that is like my situation. Any help is appreciated
    Oct 10 2012
    Zionsville and Saint John IN
    Quote Originally Posted by toast88 View Post
    Your saying your pb will not disengage when you put it in drive? I thought I saw a similar thread where the guy put his seatbelt on and then it disengaged when he pressed the pb button?
    Jan 14 2015
    Edmond, Oklahoma
    If worst comes to worst you could always start the car, unplug the MAF sensor, and that will throw a CEL with a parking break malfunction. That may or may not release it. I dont know forsure if it would be worth a try if no one else has any good ideas.
    Mar 07 2012
    No it did not disengage when I put it in drive. Just tried it with the seatbelt buckled and it did not disengage.
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    probably try this. disconnect the battery for 10 minutes meaning the negative terminal only. then connect it back to see if that helps.
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    You could open it with vagcom easily...
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Oct 10 2012
    Quote Originally Posted by oascom View Post
    +1, that would do it.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Quote Originally Posted by richardm0025 View Post
    Assuming that the problem isn't a bad control module? Any codes?
    2011 A4 Avant
    Established Member Two Rings QuatA4's Avatar
    Feb 12 2014
    2008 Infiniti FX35 AWD
    Happened to me when I was camping and almost shat myself when I thought I was stuck there forever. I had a thread about it here.
    http://www.audizine.com/forum/showth...g-or-by-design
    I put my seat belt on, started the car, try to disengage the parking break again, if it doesn't work, keep trying different combination of these and it should let go unless the module is completely fried. Mine was intermittent and Audi just reseated the connection and it never came back.
    2016 Audi A4 Progressive Plus w/ S-Line Competition Package in Suzuka Gray
    [RIP] 2009 Audi A4 2.0T Quattro Premium-Tech in Daytona Gray
    Mar 07 2012
    Thanks, I will try the seatbelt thing again. And I don't know any one that has vagcom that would be able to do that for me, besides the mechanic and I don't believe he will make a house call
    Senior Member Two Rings Fox Fader's Avatar
    Nov 24 2014
    Columbus, GA
    The 1st time I saw a power parking brake, I thought it was way cool. Since having one, not so. Give me the ole cable anytime.
    10 A4 quattro PP 18" Sport Package 6 spd manual 60k
    SOLD! :(
    10 Ford GT 401a 5sp 17k miles
    11 KLR 650
    07 Tuono Factory
    03 F150 STX Lightning replica
    11 Kia Sorento SX (wife's)
    Slammin Tunes
    Jan 08 2013
    New Jersey
    Ordering vagcom might be helpful in the long run.
    Mar 07 2012
    Maybe, but I can't justify spending hundreds on something I will hardly ever use
    Senior Member Three Rings DJ_AudiA4's Avatar
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    I don't know how proficient you are with tools and DIY but you could try to remove the rear caliper and manually push in the brake by applying a clamp to it while tuning it. Now this isn't the recommended way but i know form first hand experience it works. Would take some time and effort. You have to take the calipers and brake pads off, push them in by twisting while having a clamp on it then reinstall the pads. i would just push it in a little fit the caliper back over then try to engage and disengage the brake to see what happens.
    09 A4 6MT Quattro Frankenturbo, Eurodyne Tune,K&N intake , SPM TP, AWE catback, CTS FMIC, ST Coilovers, Roc-Euro STS, 034 Transmount, Apikol bushing, GFB DV+, H&R sway bars, AWE boost gauge, VMR 701's 19x9.5, RS4 grille and fog light housings.
    289HP @ 6100| | 297ft lb @3900
    Mar 07 2012
    Thanks for the help, I normally would possibly try that with the help of my friend who is good with all that kind of stuff, but that seems like alot of work to do in 20 degree weather. It's looking like I am going to somehow have to get it towed, which I have a bad feeling that something will get damaged in the process. I called a local audi dealer and their service department said there wasn't really anything I could do except for get it towed in. I am going to check the fuses for the parking brake don't know if they could be a cause for a problem but it's worth checking
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    20 degrees!! Maybe they really did just freeze hahah Hopefully they find a problem with the system and the dealer reimburse you for the cost of the tow. Good luck!
    Mar 07 2012
    Thanks, yea it has been very cold here lately, although It was around 45 degrees on Sunday ( after it snowed all day Saturday) So i figured if it had been frozen it most likely would have thawed out on Sunday. I talked to my buddy who works at car max and he is going to bring over his scanner tomorrow and scan it. Others have mentioned vagcom, would it really be as simple as finding someone local who has vagcom and knows what they are doing to just come by, hook it up and click a few buttons and release the brake?
    Jan 08 2013
    New Jersey
    Yes simply as that. Try regional forum, offer somone a beer or little cash and there sure is somone who will help you. If u were closer I would
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    If it's a machines issue due to the temperature and it won't open because it is literally frozen then a VagCom won't help.
    Jan 08 2013
    New Jersey
    Quote Originally Posted by DJ_AudiA4 View Post
    But at least he can be sure it's mechanical problem. Also I don't think it could "freeze".
    Mar 07 2012
    I got my buddy to scan it with his Autel Scanner and it looks like a bad control module. He tried pressing the open parking brake button, nothing happened.
    Code 00473 - Control Module for Elect. Park/Hand Brake (J540)
    **Found this on Ross Tech http://wiki.ross-tech.com/wiki/index.php/00473
    Looks like what I suspected, sommunication is not happening could be the wiring or the module itself
    Mar 07 2012
    Figured I would just update this in case anyone has this problem in the future. It ended up being the Parking brake module that was the problem. I was able to find a "used" one on ebay for $80 compared to $400+ for a new one. I replaced my module with the new one. It was quite simple just slide the old one off and slide the new one on. Then turned the car on and pushed down the parking brake lever and the brake released. Very happy I didn't have to get the car towed, saved me alot of money.
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Good to know, thanks for the update. I try not to use mine unless parked on a big hill because I'm afraid it won't disengage. I would much prefer a mechanical handbrake...
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Nov 24 2014
    Columbus, GA
    Good info, bruh. Makes me not want to use the darn thing. lol
    SOLD! :(
    11 KLR 650
    07 Tuono Factory
    Slammin Tunes
    Mar 07 2012
    Yea, tell me about it. Now I don't want to use the parking brake again in case this would happen again
    Established Member Two Rings AOW162435's Avatar
    Jul 15 2013
    Ellicott City, MD
    Is this 'module' located at the caliper, or inside the cabin?
    Andreas
    2014 Audi A4, Monsoon Gray / Black
    2002 Toyota 4Runner, Dorado Gold
    2001 Toyota 4Runner, Dorado Gold, 575,XXX 1-owner miles :)
    1998 Toyota 4Runner, Oxidized, 5-speed
    1995 Porsche 993, Polar Silver
    Active Member Two Rings geodan's Avatar
    Jan 10 2015
    Montreal, Canada
    I have had this same issue last week, my car was in my garage for about 4 days. When I came to drive it i took off the parking brake and the light disengaged however brakes we're still on i could not move the car.
    Mar 07 2012
    Quote Originally Posted by AOW162435 View Post
    Andreas
    It is located in the passenger side compartment in the trunk, there is also a set of fuses back there as well
    The part number on mine is 8K0907801E but apparently this does not show up in the audi parts database for some reason. They show 8K0907801H which I assume is a newer version of mine and would work, but I do not know for sure.
    Mar 07 2012
    Quote Originally Posted by geodan View Post
    Not sure if you are in the same situation as me, the light on my lever was always on.
