The engine did not start at first, i unplug the MAF and the car barely start and ran very rough.
The second time it started, it was as rough as the first time, and a few seconds later, i heard something dropped and bounced around in the engine. i turned the car off right the way. upon a inspection camera in the cylinder # 6, i found a broken valve in the cylinder. i then proceeded to remove the drive side head and found the following...See pictures below
My timing belt and all components were changed less than 5000 miles ago, only one cylinder suffer a broken valve, and only one broken valve in that cylinder. What cause this? this is my SECOND APB motor that has this problem.
My questions are:
1. what caused this?
2. is my head salvageable?
3. what should i do to prevent this?(Maybe change ALL of my valves to supertech valves?, should i change my springs and retainer too?)
My thoughts on my 1st question is that my motor has been sitting for a year, due to inadequate lubrication, this broken valve had a "sticky" condition, where it did not fully retract, when the piston came up and bent it at first, and after a few more times, it broke off and felt into the cylinder.
Now on to the pictures...
Thank you, I hope through this thread, we can all learn something about our valve train, and hopefully we can come up with some idea that will prevent this on our motors.
