Results 1 to 14 of 14
    Feb 12 2008
    2003 A4 1.8TQ 5-spd, 2002 Nissan Maxima SE - 6spd
    FL
    Where is alarm siren module located in 2008 B7 A4?
    All,
    I am trying to find/replace the siren module (8L0951605A) in my B6 A4 with one a wrecker has from a 08' B7 A4. They are having a difficult time finding it. From my research it should be on the d/s in the trunk behind the lining, but they pulled it all back and can't find it. This is a pic i used for reference (item1)
    On my B6 its easily found on the p/s in the trunk, but where is it in the B7? If anyone has an actual pic it would be awesome. Thanks!
    Feb 12 2008
    FL
    I was hoping to get insight, but it appears no one has removed this siren yet from a B7. I would really appreciate any help...
    Jun 27 2011
    Its on the passenger side. You have to take the trunk liners off and its below the stereo amp.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    This question should be in the dumb questions thread, but it's on topic. Do the horns work with the alarm, or is it just the beep? I am sure it is suppose to just beep when arming but when the alarm goes off is it just a continuous beeping like when you arm it?
    What ever makes sense go with the opposite and you got it
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Quote Originally Posted by Biged243 View Post
    Just the alarm siren, no horn. Kinda weak unlike the BMW which is pretty loud.
    Mar 27 2013
    Vr6 gti
    Quote Originally Posted by allstock View Post
    That's what I thought. I was hoping something was wrong and there was more to the alert system. Yes, it is very weak and actually kinda quiet. Something else to change then.
    Feb 12 2008
    FL
    So its not on the D/S, i thought it was according to the image i posted. The B6 is also on the P/S. I will the wrecker take a look tomorrow. Thanks Charles
    Jun 27 2011
    Quote Originally Posted by bg18461 View Post
    It's definitely on the passenger side on my Avant. I messed around with it a while back when I was doing my Audio install. A lot of those parts diagrams are generic so they point to a rough area but definitely aren't 100% accurate.
    -CP
    2017 Q7 3.0t
    Feb 12 2008
    FL
    Is the sedan in the same place as the avant though?
    Jun 27 2011
    I don't see why not. I haven't torn into my sedans trunk so o can't say for certain, but the siren is bolted to the car frame so I don't know why they would move it.
    -CP
    2017 Q7 3.0t
    Mar 27 2013
    Vr6 gti
    When the alarm is triggered is it a constant 12v or is it a pulsing 12v?
    Oct 24 2015
    Perth, WA
    Sorry to necro this thread, but I have looked everywhere and cannot find my alarm module? Does anyone have any experience or photos of where it is in the Australian A4 B7? Thanks
    My respray thread
    Active Member Two Rings SteveA4B7's Avatar
    Jun 16 2015
    South Africa
    Quote Originally Posted by Okedokey View Post
    Should be at the righthand side, behind the trunk lining, close to the amplifier, and the fuel filler flap.The module is fixed with a bracket, which is bent downwards slightly. Small black plastic box.
    The South African B7's shouldn't differ that much from the Aus type, as far as I know, they're all made in Ingolstadt, Germany, and exported. Or atleast mine was.
    Oct 24 2015
    Perth, WA
    Thanks mate, ive looked there, i think it is missing.
    My respray thread
