Due to being quite busy in a new position at work, I haven't been here very often lately. But I have returned for some assistance and input. I recently completed my timing belt, water pump, and thermostat service. Thanks to Fly's DIY, it went off without much of a hitch. However, after driving the car for approximately 1.5 months (daily 60 miles), I recently had some rough idling, and sluggish running in cold weather. Upon further inspection, there was oil around the valve cover (pressure in crankcase) and oil cap (I have a catch can, so PCV is no longer installed). I then got a low oil level light (I was planning to do my 5k oil change next weekend), so I checked the dipstick and noticed that the oil appears to be quite "muddy." This is indicative of coolant in the oil, pointing me to a blown head gasket... great, right (coolant level had dropped slightly, but no sign of oil in the coolant system). I am thinking is may be on the intake side, due to pressure entering the crankcase, but I figured I should replace all gaskets. The only time that the car was reading a high temperature was just after the timing belt change, when I was working on purging the air out of the cooling system, in which case I immediately shut the car off and continued squeezing lines to make sure that the coolant was flowing as needed in all locations. Is there anything further, dealing with the timing belt change, which could cause this to happen? Any other way in which the coolant may leak into the oil? I am worried that a head gasket failure may mean that I am screwed unless I have the surface machined to be sure that there are no imperfections, which may just allow for further failures. Maybe I should just replace gaskets and sell this. But I hate to put this amount of work in with so much life left, and I am planning to keep her for a while. Also, I have not seen much in the way of good DIY's for replacing head gasket, so any suggestions there would be wonderful.
FYI... my car only has 82k on the clock. With a squeaky tensioner pulley, I decided to replace the timing belt, as the difficulty was not high.
TIA for any assistance. I will try to get some pictures this evening.
Added details: I know there is currently an air pocket in the heater core, but I know that there is no air in the rest of the system, as I bled through the top bolt on the cooling line above the motor. The heater core shouldn't cause hot spots elsewhere.
