Results 1 to 10 of 10
    Mar 09 2014
    Boston, MA
    Fuel Door Cap won't lock
    When I close the gas door cap, it won't lock. Could it be the freezing cold weather that is causing this issue? Anyone know how to get it to lock? I did used a blow dryer to melt all the ice surround the cap and inside but no luck...
    2024 Audi RS5 Competition
    2024 Tesla Model Y Performance
    2018 Porsche Cayenne Turbo
    2018 C63s Coupe
    2012 C63 Coupe (P31 Package)
    2014 E350 Coupe
    2013 S4
    2006 350z
    1991 Mr2 Turbo
    2001 Civic
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    did you lock the doors and try?
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Dec 27 2014
    When it's crazy cold like it is in your neck of the woods...weird things start to happen to cars. Like you get creaks and rattles when you don't normally get anything. Steering feels tighter. Etc.
    I would still take it in to the dealership though...might as well make use of your warranty.
    Apr 09 2008
    Austalia
    Its happened to me on a B8 A4 and B8 S5, the actuator dies, its not a hard or expensive change.
    It is accessed from the boot and is located up near the fuel filler line.
    B7 RS4 Cab APR Supercharger
    C7.5 RS6
    C7 S6 - Revo, Super Sprint Exhaust - Sold
    S5 - 1740 Stage 3 with all the supporting mods - Sold
    Mar 09 2014
    Boston, MA
    So I fixed it. Heres how -
    I unlocked the car door, push the gas tank cap in and hold it in that position. Then I lock the door and the cap tank is now locked.
    I assume it was from the frigid cold weather in New England. I did spray the car down earlier at the car wash to get rid of the salt.
    2018 C63s Coupe
    2014 E350 Coupe
    2013 S4
    2006 350z
    1991 Mr2 Turbo
    2001 Civic
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by johnstah View Post
    Glad it's working for you, and it was probably related to water freezing from the car wash. That said however, you shouldn't have to lock the car doors to have the fuel door latch in the closed position. This following photos may be helpful:
    Inside the fuel door, there is a plastic latching assembly. When the fuel door is open, the latch is in a vertical position, as shown here ...
    As the fuel door is pushed to the closed position, it presses the pin of the latching assembly, which in turn rotates the latch 90 degrees counter-clockwise to the closed (horizontal) position ...
    If you push the pin of the assembly by hand, you can clearly see the latch rotating, unless of course, it's broken. Hope this helps explain the functionality of the gas door latch. Most people have a problem with the door not unlocking, not the reverse.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Mar 09 2014
    Boston, MA
    Quote Originally Posted by LYKUNO View Post
    Thanks man. Yeah i did notice that too when I was trying to get it closed. It was definitely the water freezing.
    2018 C63s Coupe
    2014 E350 Coupe
    2013 S4
    2006 350z
    1991 Mr2 Turbo
    2001 Civic
    Mar 09 2014
    Boston, MA
    EDIT - Well that didn't last long. It wont latch into the close position... It always stay on the open position. I assume the weather migght have a role in this. I will wait and will go to dealer if the issue doesnt fix itself when it gets a little "warmer"
    2018 C63s Coupe
    2014 E350 Coupe
    2013 S4
    2006 350z
    1991 Mr2 Turbo
    2001 Civic
    Oct 30 2012
    Oxford, MS
    It is a part known to break. Had my replaced under warranty already.
    Mar 09 2014
    Boston, MA
    Quote Originally Posted by chilort View Post
    yup got it replaced under warranty. It was indeed the actuator.
    2018 C63s Coupe
    2014 E350 Coupe
    2013 S4
    2006 350z
    1991 Mr2 Turbo
    2001 Civic
