Results 1 to 12 of 12
    Dec 07 2012
    Shell high octane lol
    UK
    APR BI-Pipe O-ring seal kit....
    Where do you get the kit as seems my 0-ring seals have gone awol so boost-leak-a-plenty
    I noticed ECS Tuning sell them but want $40 odd dollars shipping thats just stupid!
    Cheers in advance!
    Apr 10 2010
    037 Viton 75 durometer O-rings for throttle body
    Not sure of the size for the MAP sensor
    Dec 07 2012
    UK
    Sorry what are 037 Viton O rings...is this a generic seal from a company called Viton or??
    Cheers
    Veteran Member Three Rings slowrideBC's Avatar
    Jun 10 2012
    2000 s4
    You would think that you could take the old o ring to a parts store and pickup a matching o ring
    2000 S4 - silver- RS4 OEM widebody racecar
    Apr 10 2010
    google "037 Viton 75 durometer" O-rings and you should see all kinds of sources for them.
    Viton is the material it's made from
    the size is built into the 037 number.
    If you don't know what durometer is, its the hardness of the rubber.
    Should cost less than 5 bucks for a 10 pack.
    Dec 07 2012
    UK
    Quote Originally Posted by slowrideBC View Post
    I dont have the o ring or two o rings mate or I would of lol
    Quote Originally Posted by sj6spd View Post
    Ok thanks I will look into that hopefully closer to home i.e. UK.
    Dec 07 2012
    UK
    Dec 07 2012
    UK
    Anybody know the size of the dam map sensor o ring seal please?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If the same size as the air temp sensor, 095323969 and 9x2. Might get lucky.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Dec 07 2012
    UK
    Thank you I will look into that matey :)
    Nov 16 2010
    WetSide, WA
    Not so lucky on that last post.
    I took a look at them today and they are different sizes.
    A #9 oring or 13x2.5 is what you want.
    Dec 07 2012
    UK
    What's a No. 9 O-ring?
    I ended up buying a bunch of 10pkt IMPERIAL SIZE VITON RUBBER O-RINGS....
    SIZE: BS015- 14.00MM ID X 1.78 C/S
    SIZE: BS011- 7.65MM ID X 1.78 C/S
    SIZE: BS010- 6.07MM ID X 1.78 C/S
    SIZE: BS013- 10.82MM ID X 1.78 C/S
    SIZE: BS014- 12.42MM ID X 1.78 C/S
    SIZE: BS012- 9.25MM ID X 1.78 C/S
    I assume non of these are any good then? lol
    *edit*
    I guess I should of bought these ******s:
    13 x 2.5mm Nitrile 70 O'Ring (10x)
    http://www.ebay.co.uk/itm/13-x-2-5mm...item1e87a225cf
