I'm from the B5 section, but I can provide relevant help regarding your question.
Unless you have a California Legal Cat (CARB Number stamped on the actual cat), you will fail visual as all aftermarket parts on CA cars must be CARB approved.
With that being said, here is what you can do...
-Piggies are just OEM downpipes with the pre-cats gutted. Because they visually look and are oem parts, you will be able to pass visual easily. You'll just need to pass the sniffer test (more on that below)
-You can purchase CARB legal aftermarket cats (Magnaflow makes several). They cost $200-$500 each versus the 49-state legal cats which are as low as $50
I have high-flow cats on my Stage 3 S4, yet I passed smog easily. Although they are not CARB legal cats, my car was too low that they could not visually check the cats lol. In addition, I got the cats super hot (like red hot) by doing some hard driving and WOT pulls right before going in for the test. Cats work best when they're hot.
Really, there are no ways around catalytic converters in CA, but if you're smart you can get around the rules. PM me for more info
Originally Posted by
bluntz86
Hello all.
Im not trying to start exhaust system thread. It more or less about what aftermarket catalytic converter will pass CA smog. I currently have a stock system. Reason for the question is because it turns out one of the cats is plugged and i need to replace. The OEM cat is around $1300 for 1! Thats crazy. I would like a full system and i have an idea of the one i want but thats a mod for later down the road. Any suggestions or comments would be great!! This has been the issue of my misfires!
