Results 1 to 27 of 27
    Dec 01 2014
    United States
    Valve cover gaskets: to seal or not to seal . . . that is the question
    I'm a new owner of a 06 S4 Avant MT with about 66k on the clock. Really enjoying the car and now learning how to work on it! VCGs are next up. I've read a lot of posts and found some great DIYs (thanks to Jimmybones and Joeycurraco) but wondering if I should use any RTV sealant or just install them dry? Thanks!
    Veteran Member Three Rings jvitelli17's Avatar
    Apr 15 2013
    2000 Audi S4 STOCK :)
    Meriden, CT - Warwick, RI
    I have been debating as well, they were done by PO at 80K but at 111k im thinking about redoing them because i am going to get them powder coated. I will use RTV on the half moon's on each VC. I like to put a little on the major turns but i keep it off the straight parts of the gasket. This way, if you have to re-do the gasket your not scraping off old RTV for hours!
    The way our VC looks i'd say put RTV on half moons and the lower corners because the oil will likely leak out the lowest point/corner. That is just my .02
    06' | JHM 93 Tune | Piggies | Custom Magnaflow 2.5" x-pipe non-res | ECS Solid MM | Apikol Snub | JHM Intake Spacer | K&N Drop-in | NGK BKR6EIX| 5W-30 Castrol - SOLD BUT NOT FORGOTTEN!
    00' | STOCK (for now)
    VAG-COM 12.12.0
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Just did the passenger side last night on my 2008 s4 cab with 56k miles. From the factory it appeared to me they put a very small dab on the top rail corners. It looked to me like two differant pieces of metal meet there which could be slightly uneven and would explain why they gooped it. Other than that factory appeared like dry install.
    Jhm recommended a thin even layer on both sides of the gasket which is what I did with permatex ultra grey rtv. The side facing the valve cover I only covered the top surfaces not the sides.
    Rtv or not it will work. However, jhm and majority consensus seem to favor some amount of rtv as it will allow the seal to last longer although surface cleaning will be more difficult next time.
    On a side note my coil pack seats were a pita. I used a small hammer and a chisel and gently went around them til they popped out. Just pulling them out seemed impossible as they appeared cooked to the vc seat.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Senior Member Two Rings viridia's Avatar
    Apr 13 2011
    ham best meat
    Use RTV unless you want to do the job twice.
    Either the gaskets weren't manufactured thick enough or the bolt spacers are too tall - something went wrong in the design. The bolts do not provide enough clamping force on the rubber for a good seal.
    If 2mm of material was removed from the height of each bolt spacer RTV wouldn't be necessary.
    87 4k, 90 f350, 91 v8, 93 v8, 04 s4, 0a3 transmission
    Veteran Member Three Rings emcaha's Avatar
    Mar 25 2013
    '17 VW GSW
    Burlington, VT
    I RTV'd as well. Not going to hurt anything and if JHM recommends then it's probably best to follow their lead. Coil pack seats definitely take some elbow grease to get out.
    I also did IM spacers while I was in there. Nice having a little extra room to do the VCG's and thought it was a good time to give the whole topend a lookover and cleaning. Overall, pretty straightforward and wasn't very hard.
    Best of luck.
    Junior Member Two Rings
    Dec 09 2014
    Norwalk, CT
    Quote Originally Posted by milodub View Post
    I did them dry 1.5 years and about 15kmiles ago, holding up fine so far. Gasket is a thick rubbery thing, didn't make sense to me to add goop from a tube some places but not others. That said, factory used the black high temp sealant at the corners, I cleaned that off.
    Senior Member Three Rings blocke's Avatar
    Jul 26 2013
    1990 BMW 325i (sold), 2006 VW GTI (sold), 2006 A4 S-line (sold), 2014 Jetta SportWagen TDI
    Temecula, CA
    I did mine at 55k or so for the first time. The factory gaskets were leaking on the front of both heads. I scraped all the factory stuff off, and used RTV on the entire thing. Both sides of the gasket.
    Been checking them religiously since, and no sign of a leak, weep or otherwise.
    Performance: Fast Intentions 12" resonated cat back, ECS Snub Mount, JHM LTW Crank Pulley, JHM IM spacers, Optima Red Top, Dimple Oil drain magnet, 034 engine mounts,
    Suspension/Brakes: JHM LTW rotors front & Rear, Hawk HPS Pads, VMR V708's, H&R Sport springs, 034 strut mounts.
    Visual: Lamin-X on headlights, 20% tint , ZIZA city LEDs, Ziza License place LEDS, Interior LED conversion, R8 oil cap, 996 coolant cap
    Instagram: lockebrian
    Dec 01 2014
    United States
    Great info and I appreciate all the advice. I'll pick some up and take a good look when I get the VCGs off and go from there.
    Veteran Member Four Rings SpoolBus's Avatar
    Aug 07 2013
    ATL/GA
    Permatex "the right stuff" google, buy never do again
    Jan 30 2007
    2014 Lexus IS350, 1988 Porsche 944, 2008 Porsche Boxster, 2001 Audi TT Quattro
    Greenville, SC
    I did mine with a black perma-tex high temp rtv, about 3 years ago. No leakage whatsoever since. So i'm in favor of adding a very thin layer of sealant on both sides of the gasket. I do agree that it may be a bit of a bear if it has to be replaced again some day down the road, but I think it's worth it.
    I'm presently replacing the VC gaskets on my older A4 and will also use sealant.
    Tom
    2014 Lexus IS350 (present), 1988 Porsche 944 (present), 2008 Porsche Boxster (present), 2001 Audi TT Quattro (present), 2006 Audi S4 (past), 1998 Audi A4 (past), 1975 Audi Fox (past)
    Veteran Member Three Rings luvsspeed's Avatar
    May 13 2007
    04 S4
    North Carolina
    I'm planning on doing this job in the next few weeks, I did not see a point in starting a new thread. Has anyone had any experience using this sealant?
    https://www.permatex.com/products/ga...-gasket-maker/
    May 18 2012
    2005 S4
    Portland, OR
    I used this. https://www.amazon.com/Permatex-8218.../dp/B0002UEN1U
    I do highly recommend using it especially on the stepped transition between the timing case and the cylinder head. Those surfaces look like they were intended to be flush, but at least on my car, they were not. Don't go crazy with the stuff, because too much can actually cause problems plus it becomes very difficult to remove the next time. However, if you put them on dry it's very likely you'll be doing the job again sooner rather than later.
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    https://www.europaparts.com/valve-co...OtURoCeTTw_wcB
    I used RTV on the half moons, next time I will do the corners as suggested as well to help prevent leakage.
    now to just redo the oil pan gasket as well....
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Just in the corners of the 1/2 moons...
    May 13 2007
    04 S4
    North Carolina
    Hopefully I will be doing this tomorrow and I already have a second set of valve covers. I take it the general consensus is to do the corners and half moon seals on the block side of the gaskets?
    Nov 12 2015
    Oregon
    I swear by this stuff http://www.ebay.com/itm/like/1517628...&ul_noapp=true
    When I did my covers, I didn't know about it. I used RTV all around on the gaskets. Wish I hadn't.
    My build log
    Veteran Member Three Rings Fourpoint282's Avatar
    Oct 11 2015
    Atlanta, Georgia
    my thoughts:
    do the work yourself....it only builds the relationship with the car :)
    take this time to PC the VCG's. I did red and well worth the time and money. Cost is about $50-$100 depending on what they charge in your area. Really cleans up the engine and adds a nice pop of color under the hood.
    i've had to do, redo, redo and redo my VCG's because I could never get a perfect seal on the head so there was always this slow (and smelly) oil leak. I used a small bead of black RTV in key areas of the gasket to hold it in place while reinstalling on the motor and solved the oil leak problem. Also, splurge on decent gaskets...dont get cheap ones or you'll just be doing the work again in a few thousand miles...and anyone who has done this before knows there are two PITA bolts on the back of the motor that make this job VERY challenging and time consuming = frustrating afternoon, a lot of swearing, and back pain.
    Good Luck!
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by Fourpoint282 View Post
    Good Luck!
    especially when one of them was stripped, had to tap that damn thing to fit another size torx bit.. good thing I bought all new bolts, 5 total were stripped.
    Oct 11 2015
    Atlanta, Georgia
    Quote Originally Posted by Terry.Reese View Post
    Word, I had to use a cutting blade to cut the head of one off my bolts first time around. Sparks flying everywhere around an engine filled with 93 oct fuel....very fun afternoon! Total newb moment and boy did I learn that lesson.
    Jul 15 2015
    Rochester NY
    Terry, what size did you tap that hole to? It's currently an M6 I think. I have the one on the passenger side stripped (new bolt though) and it's applying "some" pressure, combined with some sealer will hopefully not leak. But I really would prefer to fix the hole so I can tighten it to the prescribed torque. Was thinking of either fitting a helicoil if they make them that small, or just tapping it to M8 and then increasing the size of the hole in the seal bushing that fits into the valve cover so I could retain the original sealing method but with a larger diameter bolt.
    Oct 05 2015
    Billings, MT
    we tapped the head of the bolt, not the hole. hammered a higher size torx bit into it and finally got it to turn correctly. the top of the bolt was stripped, sorry for the confusion.
    Jul 15 2015
    Rochester NY
    Ah got it - oh well, I shall continue on my quest : )
    Active Member One Ring Bhee7's Avatar
    Nov 27 2016
    Blairstown nj
    Just did mine last Sunday, only rtv on the lower part of the half moons, for the left side problem bolt I bent a 1/4 in aluminum nut driver a few times until I got a good angle, cracked it loose no problem right side, 1/4 extension and swivel torx did the deed for me.
    Veteran Member Four Rings Rol-co's Avatar
    Dec 12 2020
    Europe (NL)
    Old topic but anyone modified the vc bolts to get more pressure at the gasket? Want to try with stretching over a 2mm O-ring behind the rubber part.
    It should get a little more pressure at it.
    Have one leaking oil, even with a little sealant, doubt if there is enough force at it.
    Only milk and juice come in two liters, "05 S4 B7 tipt Avant phantomschwarz/schwarz
    Dec 12 2020
    Europe (NL)
    Added a O-ring behind the bolt rubber for 2mil extra pressure on it, fingers crossed! Hope no leaks anymore there.
    Oct 31 2022
    Prescott AZ
    In my experience, it seems like there is always at least one of the bolts that does not clamp well. Not sure if they are partially stripped or what but I started to use rtv around the entire circumference.
    Keep us posted if this works ?
    Which o-ring did you use ?
    So no rtv and just the larger o ring ?
    Dec 12 2020
    Europe (NL)
    Quote Originally Posted by Matthewest91 View Post
    I put a 8x2mm O-ring behind the top edge of the bushing and rubber on the bolt, stretched it gentle over that top edge. Used some rtv at the half moon's and bottom corners.
