Results 1 to 40 of 41
    Junior Member Two Rings
    Jan 28 2015
    NC
    Lightbulb How much HP can the 1.8T and Quattro Manual handle?
    I'm sure this has been posted somewhere but just looking for a round about answer. How much HP can the 1.8T handle before needing forged internals? Same for the Quattro manual transmission. What usually blows first? The rods? Ringlands? Transmission? Any info would be appreciated. Thanks.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    rods go first, and not from hp, but torque, somewhere areound 300-350tq
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Jan 28 2015
    NC
    Thanks. So if I upgrade the rods, will the pistons handle more? Leaving pistons stock would be key if I wanted to have a DD.
    Do you have any figures on the transmission? I'm coming from dealing with WRX trannies and they are not great at handling extra power.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    The stock pistons are fine for most street turbo setups. Same goes for transmission. They are pretty reliable when talking street cars. And if it breaks, oh well. They generally run around $200 for a used one, so not like it is breaking the bank.
    Rods are generally the only big thing that is needed to upgrade. Obviously the clutch and other small supporting mods, but the engine and drivetrain should handle pretty much anything up to a mild gt35r setup.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    May 22 2010
    N.E. Connecticut
    Anything past a stage II is not going to be a reliable DD. Above 250-300HP you are going to be at risk. 1.8T is about 160hp so doubling that is going to strain reliability.
    There's plenty of read here on A-zine concerning the max. This should be your 1st goal. There are enough people here who have brought the 1.8T to max while retaining a reliable DD.
    Max being relative to reliable and driveable day in and day out.
    On a 1.8T, KO4, Stage II, B7 coilpacks, higher flow injectors, Catback exhaust, clutch, short shifter. Brakes should be at the front of that list. You cannot up the performance and leave the brakes stock. You have to upgrade as the stock A4's brakes were inadequate.
    At this point research is where you should be.
    May 17 2014
    Raleigh, NC
    I disagree with this. Maintenance and proper planning are more important than the power you want...
    If done properly with the appropriate parts the car should be as sound as stock (my philosophy at least). Ive had a bigturbo 1.8t for almost 3 years now... Daily Driven, HARD, and boosting 15-22 psi since I installed it. Not one Hiccup, not one problem. Main reason for this is I did My research and planned the build out, not just abunch of impulse buys.
    Only things that can question reliability is if you are getting used hardware, install incorrectly, or dont have the appropriate supporting parts. Rods and a strong Clutch are a must for over 300 if you dont want to worry about blowing stuff up and want to put the power down.
    To be honest my stock k03s and FT were FAR less reliable and too much more tweaking to get right...if anyting my BT set up now is more realiable due to everything being installed recently and EVERYthing getting checked and cataloged .
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Anything past a stage II is not going to be a reliable DD.... Above 250-300HP you are going to be at risk.... 1.8T is about 160hp so doubling that is going to strain reliability.... You have to upgrade as the stock A4's brakes were inadequate.
    Exactly how much experience do you have with b5's? Because all of this is basically incorrect information.
    My car has 320awhp. Never broken down yet.
    No b5 was offered with 160hp. AEB and ATW are 150, AWM is 170.
    My stock brakes have never failed to stop my car. It's not what is braking the car, but who is braking it.
    2000 S4- Working?
    Veteran Member Four Rings Gaberossi's Avatar
    May 12 2009
    Volcano Black Audi A4 pte5857, 2022 Outback, 97 civic ex(blew up), 95 Toyota pickup(sold)
    Parkland,FL
    I disagree as well...I was pushing 385hp on pump gas on my 5857 setup for 60k miles, now I went E85 and I'm making 460whp. Before the E85 I was daily driving this car for 2 years. For the past month I have been driving my B5 everyday because I need to fix my DD(Honda civic). Don't say its not reliable. It all comes down to how you maintain your car. I felt my car was more unreliable with a stock setup(tuned k03 and K04).
    99.5 A4 1.8TM AEB Fronttrak - Volcano Black Mica - AutoFlex'd Signal Green - E85 - Clutchmasters 725 series twindisk - ID1000cc - Precision 5858 cea Ball Bearing Turbo - JE Pistons/IE Rods - EurodyneMe - Coilovers - AWE DTS - 034 Mounts - Team Dynamic Wheels -Nitto INVO -Working @ DipYourCar.com - Usp Motorsports -
    Click>>>>>My Build Heel-Toe'n the b5 everyday =P
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Agree with everyone above me. I don't understand why people continue to say this.
    With the proper maintenance and supporting rods the b5 can easily be a 300+awhp dd as many of us here have proved.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Stock brakes are fine, unless you plan on Auto-X. It doesn't make a difference if you're stopping from 100 whether you have a K03 or GT35r.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Quote Originally Posted by mnester View Post
    Weak point on the 01A transmission is the input shaft, it can flex allowing 3rd gear to pull away from each other which can cause it to sheer. I didn't really have problems till I was making over 600hp/500tq at the wheels on my built A4 1.8t quattro, others have had problems with it while making less power then that. Running a flow control valve helps when trying to make big hp, other option is to switch to a 6 speed transmission which is stronger then the 01A 5 speeds.
    Dec 05 2007
    I also daily drive a BT setup. Car is more reliable now than it was during it's other phases. You just need to maintain it and know how to go about things. I spend so much more less now on maintenance than I did prior. Figure maybe $500-$1500 annually before. Now I don't pass $250-$500 annually. Go figure!
    Jan 28 2015
    NC
    Good info... the WRX forums would used preach don't go over 17psi on the 2L TD04 stock turbos (hot air and all that). I was running 25psi all day long no problem with awesome midrange torque, properly tuned. Later upgraded the turbo to the stock STi snail and was running 22psi no problem as well.
    How much WHP can I achieve with the stock turbos?
    Dec 05 2007
    Not much, but also depends on fueling and tune. Bolt ons and 93 tune at 22psi you can figure roughly 215chp. More depending on type of fuel and tune.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Check the FAQ under the B5 section.
    We'll never mind I can't find it. It use to be a sticky.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Feb 08 2011
    On pump gas about 170awhp. I was able to reach around 200awhp but that was on race gas. What year A4 do you own or do you plan on getting?
    Jan 28 2015
    NC
    Well I currently have a 2000 2.8L Avant with a 5 speed. Planning on selling that now that it is in really good mechanical shape. Then I was considering a similar year 1.8T but I was wondering if it was worth the effort. Looking for reasonably priced AWD fast car. Meaning that I wouldn't want to spend a ton on a new tranny or a bunch of upgraded internals. Goal is 320-350WHP.
    Dec 05 2007
    Just drop in rods can give you that power with decent sized turbo. That is what many, including myself, is putting down to the wheels. Others have my more.
    Jan 28 2015
    NC
    Any suggestions for a turbo that would be necessary to achieve this?
    Also, are the ECUs tunable or do you need a piggyback/chip?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You need to do more research. Of course we all have answers for you but yourself a favor and look through 3-5 build threads with various horsepower levels achieved. You will learn a lot. If you have more questions after that, ask.
    Here is my thread if you are interested, but it is not all encompassing on what you need to do. http://www.audizine.com/forum/showth...1195-It-s-time
    2000 S4- Working?
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    Maestro for tuning. 4.2l v8 maf, 630cc injectors(everyone prefers bosch)... There's a ton of informative threads. I have one with all the parts plus prices I'll look for.
    For the turbo get a t3 exhaust manifold then find any t3 turbo's hp rating and times it buy .23 to account for drivetrain loss and you'll have your whp. You could look at comp turbos on ringer racing. I'd say go a little bigger than you plan for, so when you get bored you can just turn the boost up. Also aem failsafe wideband/afr gauge is pretty badass. You can't do anything without a wideband really.
    Page 3 has all the parts I've bought so far.
    http://www.audizine.com/forum/showth...ne-build-parts
    Established Member Two Rings jsbs1991's Avatar
    May 19 2014
    cbr 600f3
    Snellville GA
    This is something to look at for turbo choices. well what i look at, because still debating. http://www.audiforums.com/forum/b5-m...rmation-93439/
    Dec 05 2007
    Also, simple drop in rods makes your short block 600chp capable. Weak spot in the head is the sodium filled exhaust valves. If they continually go through so much heat, they will eventually disintegrate and fuber your cylinder (imagine valve head just dropping off). Since head has to be popped off for drop in rods, lap in solid (or inconel) exhaust valves for safety measures (one of the things that is keeping me from tuning past 25psi on my current setup. but I'm currently building a head on the side to just replace my current one with). But while in there, also upgrade your valve springs to get it over with. At this point, you can just swap out more aggressive cams later on with ease (nothing left really, unless you want to get into stuff you should research instead of us spoon feeding it ). The more you want, the more $$$ you have to give up. Shop thrifty!
    Now...go search
    Jan 28 2015
    NC
    Will do thanks.
    Dec 05 2007
    No problem!
    And one more note. Get a 2001 model 1.8T. You want that engine management system. Rod wrist pins are smaller on those (19mm) than on the other B5 A4 engines. Cheap way to work around that, throw pistons in from the AEB or AMU (TT225) with the 20mm wrispins. I have an AWM and this is the route I took. 144x20 rods with AEB pistons.
    Nov 14 2011
    NW
    Lameo! It was 129 when I bought it. I think 200 is still better than anywhere else. As far as I know that's the cheapest you'll find.
    http://pages.ebay.com/link/?nav=item...355506&alt=web
    Feb 08 2011
    No problem!
    Wrist pin really isn't the weak point, so 19mm wrist pin and rods are perfectly fine.
    Dec 05 2007
    I know. But 20mm all things equal should be more stronger than 19 mm simply because it's more robust. Just an option if he wanted 20mm wristpins. I know I did. Downfall with the aeb pistons, less timing advance can be added vs awm when custom tuning before timing pull. But I'm very satisfied with my application. Now...time to maximise it or get damn close (can't be done without race fuel or e85).
    Feb 08 2011
    I don't think I have seen a A4 1.8t 19mm or 20mm wrist pin fail yet, which is why IE offers the 19mm drop in rods for the 06A owners that don't want to change their bore or compression. Only reason to go from 19mm to 20mm wrist pins is if the person is going with aftermarket pistons seeing everyone only makes them with 20mm wrist pins. Kind of a waste of time going from stock 06A pistons to stock 058 pistons just to gain 1mm on the wrist pin. If you want stronger wrist pins then go with Tool steel, but even the standard 20mm pins seem to be doing just fine in my car making the amount of power it does with boost at 40+psi.
    Mar 25 2018
    Brainerd Minnesota
    I have completely forged internals with a gtx3076r and all the supporting mods I’m sitting around 500 to the wheels on medium amount of boost lol nothing’s broken yet haha
    Feb 08 2011
    Quote Originally Posted by B00stedB6 View Post
    My 01A 5 speed told me ENOUGH when I started making over 700awhp, sheered 3rd gear while half way thru the pull with my HTA3586 pushing 47psi on race gas and 20+degs of timing. LOL
    Senior Member Two Rings hawaiian punch's Avatar
    Oct 16 2016
    2013 Z71 Hoe
    New York
    Quote Originally Posted by M-Hood View Post
    That’s awesome haha, I blew up 3rd shifting from 2-3 around 7k with my gtx2867 at 400whp lol
    Feb 08 2011
    Quote Originally Posted by hawaiian punch View Post
    That is normal since it is a torque shock issue on the 01A, running a flow control valve will fix that since it will reduce the torque shock when shifting up from 2nd to 3rd. I have been running the Clutch Masters FCV with the USP Motorsports clutch line with metal slave kit for a very long time.
    Nov 14 2011
    NW
    Accept it and put in a 2.8 transmission. And rods, injectors, don't rev over 7k. You can launch at 7k every light day in day out with Mike's full face cerametallic stage 4 full face. And that's about it. I have 100% stock brake setup with close to/around 500awhp I guess.
    Torque shifting from 2nd to 3rd will blow 3 out completely on a 1.8. perhaps you could put 3rd from a 2.8 in a 1.8, but then I'd imagine spline sizes are all off.
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    Quote Originally Posted by vrmm View Post
    The 2.8 shouldn't be any stronger, 01A is 01A.
    Sent from my GM1917 using Audizine mobile app
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
    Nov 14 2011
    NW
    Longer not stronger.. I've had a garage full of stepped 3rd gears and on my first 2.8 put in around 2015. I couldn't get 6 months out. Watch my YouTube video. I don't think it's shitty shifting.
    Veteran Member Four Rings Blazius's Avatar
    Mar 15 2018
    Europe
    They arent off, but if thats the case Id rather put the diesel 3rd in.
    Oct 16 2016
    2013 Z71 Hoe
    New York
    What’s your YouTube channel name?
    Feb 08 2011
    B5 2.8 01A isn't any stronger, the taller gears just drop the next gear further down into the RPM which for most will mean less torque as they get into the next gear, problem is that the 01A doesn't tend to break because of actual torque being made but by the amount of torque shock right as the clutch is starting to engage. Running a Flow Control Valve tends to fix this issue.
    But what is the point of putting in taller gears to make more power when all it does is make the car accelerate even slower. The 2.8 3rd gear is basically the same ratio as the 3rd gear in the B5 S4 2.7t, which is way too tall as it is I would hate to see how lazy the car would be with an even taller 3rd gear.
    If you want a stronger transmission install a 01E, but the biggest issue with the 01E is the fact that the rpm drop going from 1st to 2nd gear is horrible for a big turbo 1.8t. The 3.0 01E has slightly better 3rd/4th gear but is still a bit tall for most 1.8t cars, new option people are doing now even on the 2.7t cars is taking a Allroad 01E with the 4.375 final drive and swapping in a 4.11. Still has a larger rpm drop going from 1st to 2nd then the 01A but way tighter ratio then the other 01E's.
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Great info Mike! ^^
    I ran the 2.8 01A and the 1.8T 01A with my GT2860, and I liked the taller 2.8 trans with that turbo running 2nd gear through 60mph. Was my car faster with the 2.8 vs 1.8 trans? I never really tested it, but not shifting in to 3rd before 60 “felt” faster. But my power band with that turbo was a good street/ DD setup, vs a track car 400+whp 7000 rpm GT30xx ect.
    SOLD the GOINHAM A4 ---> GT2860 Project
