It was fairly easy with a bit of patience, but it took us all day. We spent a _lot_ of time on the airbox. There's a lot of components connected to it, and I believe there's a wire/plug down below that you can't see that you'll need to pull before it'll move, as well as a couple vacuum lines and some nuts/bolts. Still, everything has to move just right, and there's a little bung on the bottom center that attaches to the frame that doesn't want to break free (I believe it was a push down then pull up motion to get it out?). Obviously you'll want to remove the air intake in its entirety otherwise you can't move your hand at all down there. Coolant tank doesn't wanna move either, we just undid the one bolt on it and moved it around still attached to the hose (which I recommend otherwise make sure the damn hose stays elevated using tape or something, otherwise there will be coolant everywhere).
The hardest part was unplugging the rail from the coils. I would recommend gloves so you don't lose chunks of your hand when they finally break lose. They may take a bit of force to break free, but the angle you pull at is the most important part. Also: BE CAREFUL WITH THE COILS.
It sounds a little amateurish, but it worked mostly. Sorry we didn't really keep track of the process so I can't be a huge help :(
edit: Oh and front passenger side was burning hot on mine, but I assumed it had to do with the way coolant was delivered. Let me know if yours is the same?
