Results 1 to 40 of 43
    Senior Member Two Rings B8SlineNate's Avatar
    Mar 15 2010
    Northern California
    Rear brakes and rotors replacement
    So I did a little search but did not find a real answer regarding the rear brake pads and rotors replacement. Will the rear require VCDS to electronically retract piston or can I do it manually the old fashion way with a piston retractor tool? Thanks!
    2010 B8 S-Line Avant Prestige w/Driver Assist
    Senior Member Two Rings eirebob's Avatar
    Apr 13 2010
    santa rosa ca
    There's a broad range of opinions about the need for the VCDS protocol in preparing to retract the rear caliper pistons. You'll still need the piston retracter tool regardless.
    I'm up in Santa Rosa, and have the Ross Tech cable if you feel you need to heed the protocol (and I would recommend it). Post this thread in the Norcal regional section to find someone else nearer if you're not close by the North Bay.
    2009 A4 Quattro, Manual, Prem Plus, Sport Package
    Mods: APR Stage II, Stratmosphere short shifter, Alu Kreuz, Tips, Tint, 034 Turbo hose, Cocomats. EC Intercooler pipe, hose kit. RS 5 pedals. Apikol rear diff kit. Vag.com mods. Stoptech slotted rotors, Akebono pads. Interior LEDs, BFI heavyweight knob, CF trim. BC BR coils. P3 Guage. ECS SS brake lines, 10/15 spacers. CR 15 brace. USP HFC.
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    If you use VCDS to retract the pistons, a retracting tool is not needed. You will find posts where people have successfully retracted the pistons and completed the job using only a retracting tool. However, others have commented on the potential for damage to the control module when retracting the pistons manually. So, it seems it is indeed possible, but you might be taking an expensive risk. I have never seen a definitive official answer to the question of possible damage. Since I have the cable, I used it when recently replacing my rear pads and rotors.
    2011 A4 Avant
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    I needed to open the rear calipers a bit more with a retractor after opening them with VCDS.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Nov 17 2010
    Quote Originally Posted by booost View Post
    I believe you can push the piston back manually with a screwdriver or clamp after VCDS has done it's retraction, similar to the front caliper. The Ross Tech video shows this and if I recall, I did this when working on mine. No special tool needed.
    2011 A4 Avant
    Aug 31 2014
    2007 335i
    Chicago, IL
    Hey for one time use, could we use this? I have this same job coming up this weekend...
    http://www.ebay.com/itm/VAG-COM-USB-..._Tools&vxp=mtr
    If not would this work?
    http://www.ebay.com/itm/Ross-Tech-He..._Tools&vxp=mtr
    Jan 03 2013
    Baltimore
    Buy the real deal. The knockoffs sometimes dont support all functions that the full VCDS does. And its nice to support a company thats actually doing really good work for our cars, not some douche in Asia.
    Aug 31 2014
    2007 335i
    Chicago, IL
    I understand the sentiment however for a one time use, one function one application Im just asking if it would work yes or no. I mean. One of those listings has like 300 sold (and there's like 15 listings) so someone has to know if it works or not. There's a big difference between spending $10 and $300 especially if the $10 works for what I'm looking to accomplish which is changing the rear brakes and nothing more. That other $290 can go to my new steering wheel fund lol
    Nov 17 2010
    The knock off may work...or it may not. There are many posts about both experiences with the various pirated versions. All you can do is try one and see.
    2011 A4 Avant
    Jan 03 2013
    Baltimore
    So you plan to replace your steering wheel as well? I bet you are going to need to do some coding with that, requiring vcds. The tool is very useful and can do lots of things. I wouldn't look at it is just using it for just the brakes. It can do quite a bit.
    Jul 17 2008
    When I did my brakes I closed the calipers with VCDS after I was done changing the pads/rotors. The ebay cables will work but as stated they are hit or miss.
    Aug 31 2014
    2007 335i
    Chicago, IL
    ok that all sounds reasonable enough. I'll look into it to see what else can be done.
    Re: the steering wheel it does require slight rewiring (changing stock for TTS wheel so need to switch connectors and create a second ground, etc) but no coding is necessary from my research.
    So you didn't need it to open them? Man there is so little literature on how to DIY these brakes. I've heard:
    1) cable needed. Would be stupid to not use it
    2) use a retractor tool, no cable needed at all. Maybe lol.
    3) take the plug off of the ebrake and connect a 12v battery to operate the ebrake manually
    i'll keep researching. Brakes came in today and the weather is good so i might change at least the fronts today. My mechanic says he can do the rears as long as i can operate the rears so we'll see how that goes.
    Jul 17 2008
    I opened them with VCDS, then had to open even more with a retractor. I closed them with VCDS when I was done. I read on the Ross Tech guide about hooking up an aux battery when doing the install but I didn't do it and had no issues.
    Aug 31 2014
    2007 335i
    Chicago, IL
    Ok so i FINALLY got around to changing my brakes this weekend. it took some time because i had a stripped lugnut that i had to twist off with a lugnut remover and also a stripped Rotor screw on the passenger rear side (i used a dremel to grind the head of the screw off and the rotor came off like butter.... vice grips to take the stud out.... bought a new stud....... just like newww)
    +1 here. I ended up getting an XTool instead of the Ross Tech cable (costs $70 on Amazon and doesn't require a computer) and was abe to complete the job exactly as booost. Front brakes are childs play, and so are the rears once you release the brake. However i had to use a C-Clamp to fully retract the piston to fit over the new brake pads. Afterwards used the XTool to reset the e brake. too easy.
    Took her for some hard driving in the snow and these brakes are fantasticccccccc. Stop Tech plays 0 games. now... on to that steering wheel....
    Ibis White B8 A4, APR Stage 2+, Volant CAI, S4 Exhaust, Spulen HFC, Front Tint 40% Rear Tint 5%, RS4 Gloss Black Grill, Plasti Dip black trim and emblems and wheels, upgraded shifter, Stop-Tech Drilled and Slotted Rotors with PosiQuiet Ceramic Brake pads, TTS Steering wheel
    Sep 20 2011
    2009 A4
    Chandler, AZ
    Quote Originally Posted by jfo View Post
    ... Since I have the cable, I used it when recently replacing my rear pads and rotors.
    I noticed in the Ross-Tech video, they connected a battery charger to the battery during this procedure. Is that part necessary?
    Nov 17 2010
    I believe it's a safety precaution to protect the electronic module. I'm not sure, but I think the idea is to avoid the possibility of the battery going dead while you have the ignition on and Vagcom connected/running while you perform the repair.
    2011 A4 Avant
    Senior Member Two Rings A4BGP's Avatar
    Oct 18 2005
    Dirt and Street bikes, '09 A4Q
    Moncton, NB
    Not so much going dead but falling below a voltage threshold. The TRW module quits below a certain voltage and is apparently damaged in the process. The actuators will run for fairly a short period but it's a good precaution to take.
    Aug 29 2013
    '06 A4 2.0T 6MT, '11 Q5 2.0t, 99 A6 Quattro Avant, 95 F-150, 73 Opel GT
    MA
    This weekend, I replaced the pads on all four corners of my wife's 2011 Q5, and have a couple questions.... I am posting here as the brake systems are exactly the same as the B8 A4 and this sub-forum is much more active than the Q5 sub-forum.
    The problem is, now the pedal feels lower than before. It doesn't feel like a leak, the pedal is not sinking at all. When I did the rears, I used a VCDS cable and followed the instructions on Ross-Tech to "open" the rear calipers, then used a pad spreader to open the caliper the remaining distance. The parking brake seems to be working correctly and will hold the car on the steeper portion of my driveway. Has anybody else had a "low" pedal after changing only the pads?
    Open Rear Parking Brake
    Prerequisites:
    Connect a battery charger as per repair manual.
    Cycle the Parking Brake ON, then OFF first.
    [Select]
    [53 - Parking Brake]
    [Basic Settings - 04]
    Group 007
    [Go!]
    The brake calipers will then open, allowing the pads to be changed.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Turn ignition off.
    It is normal for the LED in the parking brake switch and the warning lamp in the instrument cluster to blink rapidly at this point.
    The caliper pistons do not move back into the caliper, this is normal.
    Close Rear Parking Brake
    Prerequisites:
    [Select]
    Group 006
    [Go!]
    The brake calipers will then close.
    [Done, Go Back]
    My current daily: 2006 A4 Quattro 2.0T with 6MT and OEM Sport Suspension
    Wife's daily: 2011 Q5 2.0T
    Beach Car: 1999 A6 Avant Quattro 2.8
    RIP: 1995 A6 Avant
    Aug 29 2013
    MA
    https://www.youtube.com/watch?v=cHJMI4QkSy8
    I just re-watched the Ross-tech video at the link above, and it mentions pumping the brakes back up before VCDS "closing" the calipers. I'm pretty sure I electronically "closed" the calipers BEFORE pumping the brakes up. I'm hoping that I can use VCDS to "open" the calipers, then pump, then "close". Unless someone knows of a reason why I should not do that?
    RIP: 1995 A6 Avant
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    Did any of you buy new fasteners or did you simply reuse? I believe the caliper bolts are self-locking and aren't supposed to be reused. Can we simply apply some loctite?
    Did anyone clean and lube the slider/guide pins?
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Oct 23 2014
    Mississippi
    Just changed my rear brake pads and had to do the same thing. After using VCDS to retract the piston, it wasn't enough. Went to autozone and rented the piston retracting tool. And had a friend help twist the piston a little more in. Other than that the job wasn't that bad. Took about 2.5 hours for my first time doing the rear brakes on an Audi pausing to go to the autoparts store. Thanks for the DIY guys! This helped out.
    2010 Premium Phantom Black A4 with Sport Package Suspension and Wheels
    Jan 12 2012
    Quote Originally Posted by domamei View Post
    Which type of tool did you use? I'm still confused about whether the piston has be screwed back or if you can simply push back after using VCDS.
    Peter
    Oct 23 2014
    Mississippi
    Quote Originally Posted by STA4 View Post
    I used the single pronged one on the left. With VCDS the piston is retracted in but not enough for me to fit the caliper back on. You can rent it at autozone and return it to get your money back.
    Nov 17 2010
    After you have retracted with VCDS you can you can push the piston in further with a C clamp or large channel lock pliers. At this point you don't need to screw it in.
    2011 A4 Avant
    Jan 12 2012
    Much appreciated. I'd rather not have to find a tool kit (we don't have Autozone up here in Canada).
    Peter
    Jan 12 2012
    Further to this, I attempted this over the weekend and indeed a special tool is not required...not even a C clamp. With the caliper still on, simply insert a flathead screwdriver in the window on the caliper (through which you can see the rotor sandwiched by the pads) and pry between the caliper and the back of the outer brake pad and the piston will retract. This method is shown in the ROSSTECH VCDS EPB video mentioned above.
    I ended up not being able to remove the caliper carrier bolts, so I'm going to bring the car to a shop and have them change the rear brakes.
    Peter
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    Same here, anybody have any tips for removing these? I was able to get my breaker bar in there, but had no room to move/use it once it was on.
    Wondering if I should buy an impact gun, or pay a shop to do it. My biggest concern with an electric impact gun would be the size, not too sure if they would fit freely near the suspension.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by Townending View Post
    Did you try to hit them with some PB blaster? I had to use a breaker bar too, and remember it being weird angles to make it fit. You might have to jack up the axle some to get a different shot at it.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Aug 29 2014
    Haven't tried PB blaster yet, I'll start spraying that every other day so I can try again this weekend.
    Mar 15 2010
    Northern California
    Thanks to everyone's input I finally completed this task today. Pretty straight forward.
    Jun 21 2014
    2012 Grand Cherokee 5.7 L
    Santiago, Chile
    Whyu1nunno, would you please let me know which Xtool you purchased for this? I did some research on Amazon and tge one I saw did not have the B8 as one of the models supported for the rear caliber retracting operation. I then sent them an email and was told that it would not work for this model.
    Much appreciated.
    Jan 12 2012
    Quote Originally Posted by Westija View Post
    Much appreciated.
    You don't need a tool. Just pry with a screwdriver (after releasing with VCDS).
    Peter
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Much appreciated.
    Ditto to the no tool needed.
    Though I do have one of these, and it would work just fine if you want to push it in a little more after you release with VCDS:
    http://www.amazon.com/Lisle-24400-Di...s=caliper+tool
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Jun 21 2014
    Santiago, Chile
    Gents,
    Pls see above. The tool he used was one to retract the pistons since he did not have VCDS/Ross Tech.
    So I am not referring to further retracting the caliper but what XTool was used instead of VCDS to get to that point
    Thanks
    Established Member Two Rings miyagi's Avatar
    Aug 15 2012
    sydney australia
    For those with an Electronic rear park-brake, like me, I can tell you from experience that you DO NOT need any VCDS software or VAG cable, nor do you need to take it to a specialist.
    all you need is a $10 caliper tool spreader, a spare car battery, a couple wires and then watch this vid:
    https://m.youtube.com/watch?v=J-q68JIUils
    I was able to change both rear e-brakes last weekend just by following this video - and it saved me hundreds of dollars.
    NOTE: make sure your e-park brake is turned off before you commence
    [2010 A4 B8 2.0TDI S-Line]
    FRIENDS DON'T LET FRIENDS DRIVE STOCK
    Active Member One Ring bobdini's Avatar
    Jan 30 2016
    2014 Jetta se
    il
    i just did my rears
    just replaced my front and rear rotors and pads. First you need to open the parking break with a vag or the old fashioned way with batt and wire. Than the caliper piston needs to be twisted in and spread with a caliper tool or c clamp. it was a pain the first time i did it on my B8 A4.
    Jun 21 2014
    Santiago, Chile
    Miyagi,
    Thanks for the video, seems simple enough to me.
    I will try it soon. I've done the two fronts already, so rears are the next step.
    Oct 23 2006
    2022 Chevy Tahoe, 2012 Acura MDX
    Houston
    Just out of curiosity, why do we need to connect a battery charger? What happens if we don't?
    -Beck-
    2013 S5 Estoril Blue Crystal
    2003 A6 2.7T Silver
    Aug 15 2012
    sydney australia
    Miyagi,
    no probs, hope it helps you as much as it did me
    Quote Originally Posted by beckmaster View Post
    you need to connect a car battery in order to run the e-brakes and make it disengage from the disc/rotors - you need to do this in order to get the brake pads off the calipers - the break spreader will not be able to do this alone
    cheers
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    they have that tool kit at princess auto
