Results 1 to 11 of 11
    Veteran Member Four Rings iamshayan's Avatar
    Jan 13 2010
    Toronto Canada
    DIY: B5 S4 Rear Caliper Rebuild Lucas. (pic heavy)
    Recently picked up a set of front and rear B5 S4 brakes. Had planned on rebuilding them so I started searching for a diy thread to reference.
    I Found the great HP2 Front caliper rebuild thread at A4mods.com http://www.a4mods.com/index.php?page...tml&category=2
    which was super helpful and very straightforward.
    However, I couldn't seem to find an accurate one for the rears. Many similar but nothing spot on. I just finished the process and I took a couple pictures so I figured I may as well write a DIY for anyone else out there who might be looking to do the same.
    Of course as always: I am not liable for anything that may happen as a result of this post, please use this post only as reference material and always see a professional if you're not sure.
    Assuming you have removed your carrier (13mm iirc), bleeder screw and brake line and the caliper is off the car. Lets begin.
    Tools:
    • a few picks
    • Wire brushes
    • couple small flatheads
    • pliers
    • hammer :)
    • 13mm socket
    • T27 Torx bit
    • 90* snap ring pliers (ideally)
    • Rebuild kit - P/n I used was "CENTRIC 143.33016" @ $7 CAD for 2 plus $15 shipping. -$22.00 CAD Total.
    First thing, Take your pliers and pop off the spring on the parking brake mechanism.
    Next take the T27 torx bit and remove the fixed metal arm which holds the spring. - Marked B if you look close.
    should be left with this
    take the parking brake mechanism and fit it in a vise.
    You can now rotate the caliper back and forth while leaving the mechanism in the vice. This should spin out the piston. Don't worry about the boot as it needs to be replaced regardless. Once the piston is fully extended, you may rotate it by hand and remove it. Be sure to store it in a clean environment. might even be a good idea to soak it in clean brake fluid.
    Just keep turning
    brake fluid will come out the bleeder/line holes
    Now if we look into the caliper, we are faced with a small snap-ring, (cir-clip, lock-ring, whatever you want to call it). This is the (2nd) biggest P.I.T.A of the whole job. I didn't have the proper 90* snap ring pliers so I used a pick and wedged it around the pad backing and forcing it out. ***Be sure not to lose this as the one in your rebuild kit does not match.*** Also- don't worry, there is nothing spring-loaded behind it so you wont have to watch for anything shooting out at you.
    Look on the right side of the picture.
    Snap ring removal- wedge pick around pad backing. (or buy proper tools)
    taa-daa
    Now that the clip is removed you can flip the caliper over and loosen the 13mm nut on the parking brake mechanism. You will have to hammer this piece out, so it might be a good idea to leave the nut threaded on at the end, or use a rubber mallet but be sure not to damage the threads.
    Once the arm breaks free, remove the nut, remove the arm, its notched like your wiper arms so you may have to wiggle it to get it free.
    Then replace the nut and give it another whack to remove the internals. The inside piece should pop out. Leaving you with this-
    Congrats your caliper is now fully disassembled!
    Now would be a good time to lay down some fresh paint. Be sure to tape off any openings i.e piston hole. bleeder, line, backing.
    Prep accordingly - wire wheel works great. then some primer and a couple coats of high heat paint.
    Once the paint is dry its on to rebuilding.
    Its a good idea to clean out your calipers of any corrosion or dirt on the inside where the piston goes. smooth clean walls and base are a must before proceeding. Its also a good idea to blast them out with air and brake cleaner. avoid using any cleaning materials that are petroleum based. Personally wouldn't use anything but brake cleaner or brake fluid to clean brake parts. contamination is serious.
    Your rebuild kit should look something like this (to the right of the caliper). I also opted to go with some new bleeder valves from Speed bleeder.
    Take the smallest o-ring first, and place it on the internal part, push it all the way down. Take note of the recession below the notched area. This is where the V shaped rear washer is going to seat when we slide the internal part in.
    Fit the v shaped oring in the rear slot. (sounds dirty but just do it)
    Next slide the internal part through the v shaped oring. Keep in mind there is a nipple a the bottom of the caliper and a hole on the bottom of the internal part. it only goes one way, spin it till it locks in the hole. The take the 3rd and final small o-ring and place it in and around the V shaped washer, you can use a pic to push it down all the way. Then go ahead and attach the fixed parking brake bracket with the T27 Torx.
    Then line up the rolled part of the moving arm with the bleeder screw hole. leaving a little bit behind it and fasten it on, along with the 13mm nut.
    This will hold the internal piece in place while you replace the O-ring. -Remember when I said it was the 2nd biggest pita of the job? well replacing it is the biggest. especially if you don't have the snap ring pliers. I dont have pictures but with the rear mechanism in place it should make things a bit easier.
    Finally we get to replace the pistons. You will need some brake fluid and the caliper retraction tool.
    Coat the piston seals in some brake fluid for a short while. then pop them in the lower ring.
    next I found it easiest to coat the pistons in brake fluid, slide the boots over them and then fit them to the calliper while holding the piston up.
    Then start fastening the pistons by hand untill you feel them start to thread on. You will then have to bust out the caliper retraction kit. As you start to retract the piston, it will get very difficult. you will have to stop. pump the ebrake mechanism a few times and then continue, do this as needed until the piston is fully retracted. It is best to leave the lines and bleeder screws out till this is completed.
    if you have anything to add just leave a comment and I will include it, hope this helps!
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Photobucket ruined all my posts.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    Hope that was a winning roll up
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Senior Member Three Rings 155VERT83's Avatar
    Jun 30 2009
    ‘05 Porsche 997 Carrera, '15 MBZ C300 4Matic
    Alexandria, VA
    Great thread.
    2021 Tiguan R Line (replaced 2012 A4 S Line)
    Dec 10 2013
    Borden, Ontario, Canada
    Sub'd for future caliper rebuild
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I've done this before. One tool OP doesn't mention is a second set of hand. I had one hell of a time getting the mechanism back in there even with a buddy.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jan 13 2010
    Toronto Canada
    Yeah. Extra set of hands would have been key.
    Instagram:iamshayan
    B6 @ 320awhp SOLD
    Bagged D2 SOLD
    B8S4 SOLD
    Veteran Member Three Rings harryn's Avatar
    Dec 03 2016
    2021 Audi A4, 2000 Audi S4, 1995 BMW M3
    Wow, glad I stopped by this thread, as I am getting ready to start rebuilding my rear calipers in a couple weeks. By the way, just to support what the OP wrote:
    https://www.youtube.com/watch?v=YHPX8lEHFKs
    This video gives you a visual of what the OP wrote.
    Edit: By the way, I saw that the part number for Centric 143.33016 is no longer available. Is there anywhere that still has this in stock? I'd like to order this kit soon as I am getting ready to do a major suspension overhaul on my B5.
    Veteran Member Three Rings b5v6's Avatar
    May 08 2004
    '05 Volvo S60R, B5 A4 1.8TQM Avant, '06 Toyota Tundra
    San Diego, CA
    Quote Originally Posted by harryn View Post
    Interesting, I better pick up a couple kits if a source is found
    Instagram: @oliepyle
    99 A4 1.8TQM Avant
    Stroked/Built/Elim71r/NS intake gasket/port matched head and mani/Big PNP/ECS pulley/FMIC/Relocated DV
    Full 3" stainless/relocated cat/Vibrant res & muf
    Neuspeed/Bilsteins/AWE DTS/17" Enkei/Bridgestones
    TT carriers/A8 rotors (front)/B5S4 (rear)/Goodridge hoses/PBR ceramic pads
    Rieger RS4 bumper/Painted rear valance/Valeo one-piece
    Facelift/Pioneer DA120 Apple Carplay/Infinity Reference (front/rear) (Bose deleted)
    awaiting: side skirts/paint job
    Dec 03 2016
    Quote Originally Posted by b5v6 View Post
    I got my set from Rock Auto. They were in stock, and have a few kits available. You can also get them from Centric as well.
    2021 Audi A4 S-Line Premium Plus
    2000 Audi S4 6MT
    1995 BMW M3 5MT
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    cheaper to buy rebuilt than attempt to do it yourself. I speak from experience. Just buy the rebuilt ones.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Dec 10 2013
    You can buy brand new TRW S4 calipers from germanoem.ca
    Sent from my SM-G9600 using Tapatalk
    IG: 24_et
    Sold:
    RIP:
