Originally Posted by
Charles.waite
Yes they're different. How different I don't know.
I know with the 1.8t, to get an Auto crank to work with a manual, you had to machine part of the crankshaft or something in order for the input shaft to properly seat or to mount the flywheel or something.
The manual-CVT crankshaft backside bore extrudes out further to accept the pilot bearing. The tiptronic crankshaft has a shorter bore in the crankshaft. I was @ my friends shop and he had both complete short blocks side by side so I seen the difference today. Ive heard of shops using the manual- CVT motors to replace the tiptronic motors. But not the other way around
Shops have told me you can use a CVT engine for a manual engine. And a manual or CVT engine for a Tiptronic engine. You just cant use a tiptronic engine for a manual engine
CVT and Tiptronic are different even thou they are automatic's in term's anyway
rongeur
I saw the same thread about the crank differences and my impression is that there was some extra material on the TIP crankshaft compared to the manual one and simply machining it some allows the flywheel to properly mount. I hope that is all that is necessary since I picked up a block from a cvt (i think) to build out. I called JHM with this same question but the guy I spoke with didn't have any information for me.
If someone posts a picture of the rear of the crankshaft of their manual, I will post one of the rear of the automatic and we can compare.
To machine the crank is alot of work
. You would have to remove the
from the block and send out to a machine shop. Its not as simple as drilling it out
. It has to be put on a milling machine and then a metal lathe.
Someone mentioned modifying the pilot bearing.. The bearing itself has a very thin wall already and grinding it perfectly round to fit it into the crank would be extremely difficult imo
