Results 41 to 80 of 86
Thread: ETKA App
  1. #41
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    This is actually good news....It means we will get a new version (7.5) that will work 100% natively under Windows 7 instead of having to use an old laptop with Windows XP, bother with VMs, etc.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
  2. #42
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    That's true.
    I am currently installing ETKA on windows 7 32bit and it is taking the updates much smoother then VM.
    Waiapasi2006
  3. #43
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    I'm updating this here.
    Etka 7.4 Germany runs without any problems on Windows7 32bit.
    So far Current update for audi= last two digits 57.
    I am fairly new with this program, so with those using it, please chime in.
    Are there different ETKA's out there when it comes down to international/Germany?
    I have noticed my search showed up with updates with a ''d'' and ones without, you get a boot loop when updating manually.
    Waiapasi2006
  4. #44
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Anyone has any input with the updates containing the letter "d" when you check for updates.?
    Waiapasi2006
  5. #45
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Bumping this one up from the dead again.
    I just reprogrammed my laptop and got this far with updates
    Audi 1089
    To get the current update, you need to upgrade to ETKA 7.5
    Anyone has any light they would like to shine in here please?
    Thanks.
    Waiapasi2006
  6. #46
    Jun 27 2011
    I'm stuck on 1086 with ETKA 7.4. Haven't looked for a source for 7.5 in a while though. Could be something out there finally...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  7. #47
    Jan 06 2009
    ETKA 7.0 update 622 running on Win10 64 bit here.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
  8. #48
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by ADCS View Post
    I have Etka Germany 7.4 with update 1089
    It does run, but I can't get the current update. You have to upgrade to get 1090 and up.
    Thanks for the reply.
    Waiapasi2006
  9. #49
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    update 1089 is the most recent one I had.
    I am looking as we speak.
    Once I try to push 1090 through, it tells me I have to upgrade to 7.5.
    Question:
    Does our update files have a "d" after the number in the location when you update it?
    Thanks for he reply.
    Waiapasi2006
  10. #50
    Mar 24 2013
    Oakdale, CT
    Can someone with a working copy of ETKA look up the part numbers for the oil pump/balance shaft assembly bolts? I can't seem to find them for sale anywhere and supposedly they are TTY and need replaced after removing them.
    -Adam
  11. #51
    Jun 27 2011
    Hope that helps.
    -CP
    2017 Q7 3.0t
  12. #52
    Mar 24 2013
    Oakdale, CT
    Very much so, thanks!
    -Adam
  13. #53
    Senior Member Three Rings Khaotic's Avatar
    Feb 21 2011
    2001 Audi A4 Avant 1.8T Quattro
    Sweden
    Im on 1096 on ETKA 7.4
    When I got the notice on updating to 7.5, I had an option to "only install data/update" or something similiar and it continued as usual up to date.
    2007 Audi A4 Avant 2.0 TQ 6MT S-Line
    Exterior: Bi-Xenon Retrofit | 30% Tint | KW V2 Inox | 19" VMR 701
    Interior: LED Lighting | Black Headliner | RS4 Shiftknob | oCarbon Trim | TTS Steering Wheel | Audio build
    Engine: REVO Stage 2+ | STaSIS Exhaust | R.A.I HFC | Custom CAI | AWE FMIC | HPFP Stage 1 | RAI Catch Can | JHM Flywheel & Clutch | USP Metal Slave & Clutch Line | JHM SS Trio
  14. #54
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Quote Originally Posted by Khaotic View Post
    I'll see what happens when I update mine again. Also, have you ever paid attention to your update file in you C drive to know if the update "audi" folder has a "d" at the end of the number example 1096d?
    I don't know if that makes sense.
    Waiapasi2006
  15. #55
    Feb 21 2011
    Sweden
    Quote Originally Posted by waiapasi2006 View Post
    If I understand you correctly, my update files do not end with a "d"..
    I download my updates manually from a hosted website that some guy is running and uploading all updates to, and they are named as per usual, the last one I did is named "etupau10960.exe"
  16. #56
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    I was able to upgrade to ETKA7.5
    AUDI is now updated to 1098
    Sent from my SM-N900P using Tapatalk
    Waiapasi2006
  17. #57
    Mar 24 2013
    Oakdale, CT
    Part number for the knock sensor bolt - GO!
    -Adam
  18. #58
    Oct 16 2008
    South Florida - Ft Lauderdale
    more than one application and I do not have your PR options code so here are all the different versions that you should be able to match with yours
    Triple Square Head M8X30 N91076601
    Hexagon Head M8X35 N01033520
    Hexagon Head M8X32 N0103328
    Triple square M8X32 N10688601
    Hexagon Head M8X30 N01024425
    Phil
  19. #59
    Mar 24 2013
    Oakdale, CT
    Phil
    Hmm, a bit more involved than I thought. It was a hex head though, and not a triple square, so that narrows it down. Where would I find this info? Thanks again Phil!
    -Adam
  20. #60
    Oct 16 2008
    Hmm, a bit more involved than I thought. Where would I find this info? Thanks again Phil!
    Easy way first: do you have the old bolt?
  21. #61
    Mar 24 2013
    Oakdale, CT
    I have one of them but not the other. I'm hoping they are the same.
    -Adam
  22. #62
    Oct 16 2008
    Do you see the one you have?
  23. #63
    Mar 24 2013
    Oakdale, CT
    The knock sensor that came off the block looks like #15, but the block was from an '07 GLI. The stock knock sensors from my car (and the new ones I ordered) do not have a harness and have the clip molded into the sensor. The threaded portion of the bolt I removed is ~25mm long with the overall length being ~31 mm. The head of the bolt is stamped 8.8. I'm assuming I need to match the bolt to the block and not the car, but I wasn't aware there were so many choices.
    -Adam
  24. #64
    Jun 27 2011
    I might be able to look this up for you today. ETKA usually lists the specs for the bolts so you should be able to get a compatible bolt at a hardware store.
    -CP
    2017 Q7 3.0t
  25. #65
    Mar 24 2013
    Oakdale, CT
    I was able to find a match at Home Depot Racing. I don't see why a generic 8.8 bolt of the same size wouldn't work. They only get torqued to 15 ft-lbs.
    -Adam
  26. #66
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Bringing this back from the dead.
    It seems like we have an upgrade out there 7.5 to 8.0.
    Waiapasi2006
  27. #67
    Jun 27 2011
    Any hints on where to acquire? I haven’t been able to update my 7.5 for a while due to the versioning requirements for the latest updates. They require 8 to install...
    -CP
    2017 Q7 3.0t
  28. #68
    Sep 02 2008
    Boonies VA
    Was just trying to find a copy of this a couple days ago, trying to track down some wiring diagrams for the Avant. Hopefully someone knows where to get a copy.
    White Wagon
  29. #69
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    I ignored it, but now i'm stuck. ETKA no longer wants to open.
    Waiapasi2006
  30. #70
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    This.
    Waiapasi2006
  31. #71
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by naiku View Post
    What you after?
    My respray thread
  32. #72
    Veteran Member Four Rings TWiST's Avatar
    Jun 08 2007
    There are a couple sites I have come across that have it, the download is there and I was able to obtain it but I am waiting for a response from the OP to get the password. Just been trying to build some rep on that site so I can get the info I need and move on lol.
  33. #73
    Jun 27 2011
    ETKA doesn’t have wiring diagrams. You must be thinking ELSAWin.
    -CP
    2017 Q7 3.0t
  34. #74
    Oct 24 2015
    Perth, WA
    thus, I have elsawin, so if he wants the info.... I just shortcut that part of the logic lol :)
    My respray thread
  35. #75
    Jun 27 2011
    Quote Originally Posted by Okedokey View Post
    I have it too but it never works.
    In any event wanted to clarify that ETKA doesn’t have that so he doesn’t spend all that effort barking up the wrong tree.
    -CP
    2017 Q7 3.0t
  36. #76
    Oct 24 2015
    Perth, WA
    Why doesn't it work?
    My respray thread
  37. #77
    Sep 02 2008
    Boonies VA
    What you after?
    Trying to figure out where the trunk wiring harness in an Avant feeds into the body. I can follow it through the rubber boot and into the body at the hinge, but from there is is behind a piece of metal and I cannot see where it goes. I need to determine if it runs above the headliner or drops down behind the D-pillar. I want find where it plugs in, in order to unplug it for testing but am loathsome to have to remove the headliner in order to do it.
    Ah, thanks.
    White Wagon
  38. #78
    Jun 27 2011
    ETKA App
    I get weird errors (in Russian) during the install but then it eventually works but when it’s all installed and updated it give weird errors and doesn’t show half the info and pictures.
    I’ve been meaning to try downloading it a third time but it’s sort of a pain so I haven’t. I run it in a Windows XP VM on my Mac so while it’s fine with ETKA I’m assuming the ELSA cracks are being weird.
    -CP
    2017 Q7 3.0t
  39. #79
    Feb 15 2016
    Cambridge,Ontario
    I find it odd that anyone speaks of hacking VCDS they are immediately blasted for hacking proprietary software and banned to the outer world. But yet hacking ETKA proprietary software seems to be deemed acceptable and even supported by the community in some way.
    I don't care either way really but I just thought it was an interesting observation, and think maybe there is something I don't understand.
    just my random thought of the day .. now back to figuring out why my one year installed coolant flange is already leaking.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  40. #80
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Same for ETKA here.
    Sent from my SM-N950U using Tapatalk
    Waiapasi2006
