Thing is, im new to the S4 and not sure what could be leaking down onto the snub mount, oil pipe, then to the bottom of the oil pan.
Here is a picture to show what it looks like:
Any help would be great, thanks guys!
06'| JHM 93 Tune | Piggies | Custom Magnaflow 2.5" x-pipe non-res | ECS Solid MM | Apikol Snub | JHM Intake Spacer | K&N Drop-in | NGK BKR6EIX| 5W-30 Castrol - SOLD BUT NOT FORGOTTEN!
00'| STOCK (for now)
VAG-COM 12.12.0
(\_/)
(o o)
00 Laser Red "stage III" S4: Sold
04 Moro Blue S4 6MT: Sold
01 Allroad 6MT: Sold
06 A4 Avant 6MT
09 C63 P30
VAG-COM 12.12.0
Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
VAG-COM 12.12.0
VAG-COM 12.12.0
VAG-COM 12.12.0
VAG-COM 12.12.0
VAG-COM 12.12.0
'18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
'05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
VAG-COM 12.12.0
-Bryan
2005 Dolphin Gray S4
19" B8 S5 Peelers
VAG-COM 12.12.0
VAG-COM 12.12.0
VAG-COM 12.12.0
VAG-COM 12.12.0
