I have a '02 S6. I was driving up a semi-deep snow filled driveway last night (12"-15" of snow) and was doing fine until there was a dip in the driveway where the snow was deeper. The deeper snow got under the front of the car so that the front wheels couldn't drive forward and the car stopped. I tried reverse, but the car was stuck and I could hear the wheel/wheels spinning - unable to get traction.
This morning, I came back to the S6 to see the front end elevated, since there was a good deal of snow underneath it, but the back was sitting on the ground with normal wheel to fender clearance. After removing snow from behind all the wheels, I tried to back it out (a friend of mine came by and plowed all around the car), but it wouldn't budge. I noticed that only the passenger, front wheel was spinning when I put the car in reverse (this is the corner of the car most elevated by the snow...so, with the least traction), but the other wheels that seemed more planted on the ground were not moving.
My understanding of the Quattro system is that it will and can transfer drive power to the other wheels that are not slipping. I've never had an issue with my S6 in any weather conditions. Also, the ASR light is blinking on the dash - so the system does know that there is wheel slip and the e-gas system is slowing down wheel spin regardless of how much gas pedal I input.
So...can someone help me understand why the other wheels are not turning or if there is an over-ride that I can input to lock the car into 4 wheel drive?
Thanks.
